CQ5
AuthenticationSupport service missing after building index.
Sep 12, 2012 5:50 AM
Tags: #service #unavailable #503
I got an error on browser console after starting the CQ Author instance saying that "Service Unavailable AuthenticationSupport service missing. Cannot authenticate request. "
I just started all the bundles and also rebuit the index but still am getting the same error message.
When i logged in to system/console(OSGI Console) One thing i just noticed Authenticator tab is missing.
Help out to solve this issue
Thanks in Advance...
Mahesh
    Sep 12, 2012 6:36 AM   in reply to mahesh1222
    In my case sometimes it just needs 20-30 minutes to get started. So first thing I would try is to wait a bit more than usually. Also you may find it useful to find AuthenticationService in "Services" tab of Felix Console and a component that corresponds to the service. Then you should go to "Components" tab of Felix Console and find that component and check if it's running or not. If it's stopeed then what are unresolved dependencies.
    Max.
    Oct 16, 2012 7:15 AM   in reply to mahesh1222
    Was this ever resolved Hahesh? I am having the same errors in a new environment that is running inside a JBOSS 5.1 application server.
    Oct 16, 2012 10:27 PM   in reply to steve_dayman
    The error indicates the service is missing. Analysing the logs file during the start up should give you exact cause.
    Could you please
    *   Stop the instance
    *   Rename <cq_home>/crx-quickstart/logs folder
    *   Delete the index tar files at
       -   <cq_home>/crx-quickstart/repository/tarJournal/index*.tar
       -   <cq_home>/crx-quickstart/repository/version/index*.tar
       -   <cq_home>/crx-quickstart/repository/workspaces/crx.default/index*.tar
    *    Start the instance
    If issue still persist file daycare with all the logs file & zip file from http://<host>:<port>/system/console/config
