sanchousf
How get the mesh vertices of the effects "Puppet"?
Sep 12, 2012 5:17 AM
Tags: #problem #effects #after_effects #scripts
How, in a script, get the mesh vertices of the effects "Puppet"?
    Sep 12, 2012 7:05 AM   in reply to sanchousf
    I'm not sure what data you want to extract. Puppet pin keyframe data looks like this:
    Adobe After Effects 8.0 Keyframe Data
              Units Per Second          29.97
              Source Width          318
              Source Height          52
              Source Pixel Aspect Ratio          1
              Comp Pixel Aspect Ratio          1
    Effects          Puppet #7          arap #3          Mesh          Mesh #1          Deform          Pin #2          Position
              Frame          X pixels          Y pixels
              51          289.175          21
              59          289.063          17
              64          287.032          1
              66          287.023          -3
              70          287.018          -7
              74          287.009          45
              82          287.001          59
              83          287.001          57
              84          283.002          49
              88          283.001          17
              90          277.001          -1
              96          277          -5
              101          279          25
              103          279          39
              110          279          43
              118          269          -86.6667
              121          269          -266
              122          271          -256
              129          273          -236
    End of Keyframe Data
    This is all yoy get when you copy the keyframes. Since this is a scripting question, I'd move the post to the that forum. You'll find it on the AE Forum home page in the right column.
    What are you trying to do with the data?
    Sep 12, 2012 7:25 AM   in reply to sanchousf
    The mesh is internal. There is no data that you can simply snatch in a script or expressions. As Rick illustrated already, all you ever get are the pin coordinates relative to the layer.
    Mylenium
    Sep 12, 2012 8:08 AM   in reply to sanchousf
    I don't think that's going to work.
    Sep 12, 2012 8:21 AM   in reply to sanchousf
    I agree with Rick. You're betting on the wrong horse if you hope to export this kind of stuff from AE. If you need UV texturing on a mesh, then use a mesh in a 3D program and export it. Due to how the Puppet Mesh is generated, the distorsioss will be quite uneven, anyway and only get worse at lower (texture) resolutions, nothing what I would like to see in a game....
    Mylenium
