Nudging very slow in CS6
Sep 11, 2012 11:15 AM
hello --
i have seen quite a few threads but no solutions yet that work for this problem. my documents tend to have quite a few of layers, using very frequently shapes with layer effects. up to a certain amount of those the app is very responsive, and then once i hit a certain level it gets very slow. strange just moving a vector shape using the direct selection tool is just fine. the regular nudging of a group or a layer brings up the progress indicator dialog.
so far i have tried:
- turn off layer previews (did improve things a tiny bit, but still unusuable with larger layer count)
- changed performance settings (cache level:2 or 4, and tile size 128k) (also no effect)
the only thing that seems to help is to break the file apart into seveal ones, which will have less layers, but that's not really a long-term workable solution for me, as i use layer comps and need a more global overview.
have others found a solution? i can't imagine being the only one with this problem.
thanks in advance for your throughts.
  • Noel Carboni
    Dec 23, 2006
    Sep 11, 2012 11:22 AM   in reply to Patrick Jean
    Have you updated to Photoshop 13.0.1 yet?  There was a specific bug fixed in that update having to do with moving layers.
    I haven't seen a problem with performance of moving layers around myself, but every document is different, and I have a PC, not a Mac, and the latter is where more performance problems seem to be reported lately.
    Is your document very large?  Can you be more specific about pixel count, how many layers, how complexly they're nested, how big it is when saved on disk, etc.?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 11, 2012 12:06 PM   in reply to Patrick Jean
    It doesn't sound too terribly large, though 300 MB isn't small.  Do you know whether you have information beyond the visible edge of the canvas (e.g., have you used the Crop Tool with [  ] Delete Cropped Pixels unchecked, or placed any large images of which you can see only a portion?
    I only have an intuitive feel for this issue, as I frequent this forum and have read a number of other reports of sluggishness, but I don't have a Mac on which to test things myself.
    There have been some reports that 13.0.1 makes things better, but it still seems there is something that pushes people's Mac systems over the edge into being sluggish, and unfortunately Adobe or other users haven't managed to find a magic bullet.
    I've heard folks say everything from running Onyx to reinstalling the entire operating system has helped, but that's second hand info as I just don't have the ability to duplicate your environment.
    There was a thread where someone posted a document with a huge number of layers to test with, and another where someone suggested documents of a certain composition, and it was pretty easy to demonstrate that some systems could work through them more quickly than others, with the difference being greater than you'd expect based on computer performance alone.
    If you have a way to post your PSD file online and would be willing to show it to others, I'll be more than happy to download it and see whether I'm seeing similar performance.  A document that can reproduce a slow-down for others might be very interesting to Adobe as well.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 11, 2012 12:20 PM   in reply to Patrick Jean
    I'm not suggesting reinstallation should be your first choice.
    Assuming you're not trying to maintain anything out there where you can't see it, try this:
    1.  Choose the Crop Tool.
    2.  Check the [  ] Delete Cropped Pixels box.
    3.  Move an edge in then back out, so that the Crop Tool thinks it has work to do.
    4.  Complete the crop.
    Does that reduce the document size or increase the speed?
    You might want to read over some of the information in the various "slow/sluggish" threads on this forum.  That will give you an idea of what's been tried.
    -Noel
    Sep 12, 2012 8:06 AM   in reply to Patrick Jean
    I was having this problem on a PC, turned out there's something wrong with the way CS6 processes thumbnails in the layers panel that really slows down documents with lots of layers. Open up the layers panel options and select "none" under thumbnail size.
  • Noel Carboni
    Dec 23, 2006
    Sep 12, 2012 8:14 AM   in reply to davemakes
    Dave, that's what's supposedly been fixed in 13.0.1.  Are you saying it hasn't been fixed?
    -Noel
    Sep 12, 2012 11:40 AM   in reply to Noel Carboni
    It was fixed for layer dragging and basic free transform use.
    Nudging is still going to be slower because after every nudge, the layers palette is going to want to redraw (can't tell if it's the last nudge or another is coming, so at idle it tries to redraw).
  • Noel Carboni
    Dec 23, 2006
    Sep 12, 2012 11:58 AM   in reply to Chris Cox
    I just tried to nudge a layer in a large, deep test document that was provided by another forum member over on the Photoshop.com site, and it takes 45 seconds to complete.  I have a fairly rompin' stompin' 8 core PC here.   I can drag the very same "white dots" layer group around with the Move Tool with a frame update rate of something like 5 frames per second, with at most 1 second between drag operations.
    Chris, I'm sure you have a copy of this file already.
    The exact same operation completes in Photoshop CS5 in under 5 seconds repeatably, without a progress bar, even though it's a good bit slower to drag the layer group around in Photoshop CS5 (it drags at something like 2 FPS in Ps CS5).
    I don't know how to put this more gently:
    You have another bona fide bug here, Chris.
    Don't forget that I once asked you if you needed a software engineer who knows what they're doing on staff.
    -Noel
    Sep 12, 2012 12:34 PM   in reply to Noel Carboni
    I'm also having this issue daily, my files are not godly large but my machine should be able to handle what I'm working on.  iMac OSX 10.7.4 3.1GHz i5 w/ 8GB DDR3
    Please issue a fix for this!
    Sep 12, 2012 1:47 PM   in reply to Noel Carboni
    Alright, I'm doing more investigation now (because I was already profiling related issues with a large number of layers).
    Sep 12, 2012 2:00 PM   in reply to Chris Cox
    Yes, related to layer thumbnails. If you disable layer thumbnails, or change them to "entire document" instead of "layer bounds", the problem goes away.  CS5 defaulted to "entire document" for layer thumbnails, so didn't show the problem.
    And the good news is that it is related to a fix I already have in testing.
    Sep 12, 2012 3:44 PM   in reply to Patrick Jean
    Not "turning off the layers palette", but turn off layer thumbnails in the layers palette or set the layer thumbnails to show the document bounds intead of layer bounds.  Both are settings in the layers palette options dialog.
    On your test file in Photoshop 13.0.1, nudging a group gets a spinning cursor for about 3/4 of a second after the nudge - but that's all.
    Nudging a single layer is almost instantaneous.
    That's nothing like what Noel and others are reporting (many seconds, progress bars, etc.).
    Sep 12, 2012 4:35 PM   in reply to Patrick Jean
    That sounds like you haven't installed the 13.0.1 update.
    Sep 13, 2012 5:16 PM   in reply to Patrick Jean
    Yes, the slowdowns I've seen are very much dependent on the number of layers. Most need a large (300+) number of layers before they become visibly slow.
  • Noel Carboni
    Dec 23, 2006
    Sep 14, 2012 9:41 AM   in reply to Patrick Jean
    That memory usage characteristic, where Photoshop allocates then holds RAM, is normal for Photoshop.
    Regarding this issue, it sounds as though he's already solved it, Patrick, noting post number 12 above...
    Now it is up to us to wonder how soon 13.0.2 will be coming out.
    Last iteration leading to 13.0.1 took almost 4 months, but now we have the "cloud" fogging our view of the future:  Adobe has threatened to stop releasing problem corrections to the fine folks who have sent in their hard-earned money for a license up front, and only roll some things out to folks paying a premium for monthly subscriptions.  We shall see how well that works out.
    -Noel
    Oct 8, 2012 4:24 AM   in reply to Noel Carboni
    I have been using Photoshop for years on PC and now most recently Mac, and have always found it hellishly slow. No matter the version or platform it has always been slow with layer-laden psds. For years I have just accepted this as the way things are.
    I have always used ‘Clip thumbnails to layer bounds’. Having just read this thread I only now realised that if you turn thumbnail previews off or to document bounds that yes, performance is significantly increased. Scrolling and zooming is smoother and moving groups of layers is now the difference of 5 seconds and 1 minute or longer depending on the number of layers.
    However turning off ‘Clip thumbnails to layer bound’ may be a fix but I find it leaves you flying blind, unable to navigate efficiently through your thumbnails. Layer bound thumbnails are an extremely productive and essential tool that I personally cannot go without.
    I’m using the latest 13.0.1 version with 8gb memory.
    I reckon this is something that will not be sorted with an update as it has been present for years.
    Oct 12, 2012 10:23 AM   in reply to Patrick Jean
    This problem has been plaguing me as well. I found that initiating the Transform command (CMD/CTRL+T), and THEN nudging helps tremendously!
    Nov 26, 2012 3:39 PM   in reply to Chris Cox
    Is there any progress on this bug?
    The conversation stalled at someone mentioning that transforming items helps the performance lag of moving items - however that's not an adequate solution as an avid layer comps user transforming a layer (say) 100px to the right will cause that item to be moved 100px to the right across ALL your layer comps.
    I'm a web/interface designer that's been using photoshop every single day for about 15 years & I don't think I've ever been so frustrated with poor performance or Photoshop.
    And yes - I use ALOT of layers - because that's how I have always worked.
    Only in the last couple of years have I had to start digging around in PS's settings to try & tweak performance - ironically when I've been using top of the line PC's to do my work (currently a core i7 MBP with 16gb of ram & a USB3 SSD scratch disk.) & moving a simple text layer 10 pixels takes about 10 seconds.
    Come on Adobe - this is getting ridiculous.
    If you like I'll construct a list of features I couldn't give 2 sh1t5 about if you dropped everything & concentrated on optimising performance for the basic use of photoshop (for interface designers)
    Nov 26, 2012 4:14 PM   in reply to stinkbowler23456
    Yes, there is progress. Just nothing I can tell you about right now.
    For the time being, turning off layer thumbnails is still the best workaround.
    Dec 13, 2012 2:12 PM   in reply to Chris Cox
    Guys, Adobe released an update for Photoshop CS6 13.1 that seems to have fixed the nudging problem to a large extent. It still not as fast as earlier versions (Photoshop CS4 fastest, CS5 fast) - but now its less than a second delay (as opposed to being several seconds) in nudging large groups of layers with thumbnails on. With All panels off (Tab shortcut key) its superfast. Also I have set the performance settings to match earlier versions of Photoshop (CS5, CS4) - History & Cache - Tall and Thin - 20,4,128K. Please try the update and let us know your experience.
    Dec 13, 2012 5:14 PM   in reply to kalaga1
    13.1 and 13.0.2 have about half of my fixes for documents with a large number of layers.
    Some of the fixes needed further review and testing (changing core VM code is kinda risky), and I just got another test file this week that shows even more problems in odd areas of the program (and I'm working on fixes for those).
    Apr 21, 2013 7:00 PM   in reply to Chris Cox
    Most recent update to CS6 is an improvement, but transform tool is still VERY slow for me. 2-3 second delay between each refresh state, even on relatively simple images.
    CS5 on the same computer was fine.
  • Noel Carboni
    Dec 23, 2006
    Apr 21, 2013 9:21 PM   in reply to Dr Missile
    Check to ensure you have not got Cache Levels set to 1 in your Performance Preferences, Dr Missile.
    -Noel
    Apr 24, 2013 3:14 AM   in reply to Patrick Jean
    I've since moved over to fireworks. So far, I'm not looking back.
    With Fireworks, there's no need to rely on the layers panel to find layers, as you can easily select them on the canvas.
    The interace and rendering is pixel sensitive and intended for web output. Creating and resizing elements and moving them is never a problem and there is no delay like Photoshop.
    Photoshop has always been slow, and I do not expect this problem to be solved. So don't hold your breath.
    I reckon that since Photoshop is Adobe's flagship application, they are spending too much time on adding new features to sell newer versions, instead of improving basic functionality.
    CS6 promised improvements of their base functionaility, and to a degree they acheived this, but it's not enough. I find in it's current state it is almost unusable. Everything is too slow and frustrating.
    There's a yuppie stigma attached that says that designers should use Photoshop for design. I never considered Fireworks, recalling it as being a simple gif animator.
    But Fireworks is faster that Photoshop, creates smaller file sizes and is more accurate for interface and web design. The tools are far more intuative.
    It's taken a bit of readjustment, but for web and interface design, Fireworks seems to be superior in every way.
    It's not perfect and it has it's own quirks as all Adobe products do but I'd recommend anyone having issues with Photoshop to give it a try.
    Leave Photoshop for it's intended purpose - photo manipulation.
    Cheers
    Andrew
