I have CS5 installed in my computer ,can i install cs6 and maintain cs5 until i get used to cs6 ?
I have Photoshop 7.x through 13.0.1 installed on my machine. On the Mac I can even run more than one version of Photoshop simultaneously; all I have to do is launch the older version(s) first. Out of an abundance of caution I do assign different volumes as scratch disks to each of them.
@ Larry: When the wrong version of Bridge launches on your PC, you must have the option to launch Bridge at login set in prefs.
That is because on PS's only the CS5 or CS6 bridge can be run at any given time. Bridge sometime get setup to run automaticly on machines and there is an icon in the task bar on windows machines. Bridge that is running and it may not be the one you currently want. You need to change you system so that the Bridge does not start automaticly and also terminate when you exit bridge and not just minimize to the task bar.,
Yes, I know that. However, if you have both versions available, you may sometimes want Bridge to open either version, but that choice isn't available (AFAIK!). So forgetting to change back and in any case, having to mess with resetting prefs adds to the work load so I simply uninstalled CS5.
The only reason I held on to CS5 was for the saner crop tool. I absolutely HATE cs6 crap crop tool. The fact that the stupid crap crop frame doesn't go away after committing the crap crop is unconscionable! Every time I use it I have to use a dark gray background color to be sure I didn't miss the edge, something I rarely screwed up in earlier versions.
Did I mention I hate the CS6 crap crop tool?
Every Windows user ought to be running Autoruns occasionally to review what's starting and running on their systems (Mac users too, though it's not done with the same tools). You should know every single program that's using your resources. In the case of Bridge there's a configuration seting in the Bridge preferences to control it, but when it's set you'll see an entry in Autoruns.
Personally I've turned off most of the crap Adobe starts, and lo and behold Photoshop CS6 still runs perfectly. Beyond Bridge, you've gotta wonder why they feel it necessary to run AdobeCS5ServiceManager and the SwitchBoard service when they don't do much for Photoshop. Maybe they're needed when you have the whole suite in, I dunno. Beyond those things, for Photoshop CS6, I have even more stuff from Photoshops CS5 and CS4 disabled.
-Noel
