Some assistance with Spry Rating Widget
Sep 12, 2012 6:58 AM
Hello, everyone.
I have downloaded the Spry library from the repository, and am playing with it, trying to learn it.  So far, so good.
I have written a page that is using both the Spry Accordion Panel (I have 8, so far) and the Spry Rating Widget (one in each panel.)
I am displaying (below the stars) a tally of ratings for each panel (I'm keeping track in an XML file.)  The 1-5 Star title, the number of times each is clicked, and a green bar (img) indicating percentage.
When a star is clicked, the XML is updated, but you have to refresh the page to see the new values.  How can I dynamically, and in real time, update the value display when a star is clicked?  (Once I have that, I can figure out how to dynamically change the img size/percentage.)
Thank you,
^_^
    Sep 12, 2012 7:19 PM   in reply to WolfShade
    Not sure whether you are aware that Adobe has stopped developing Spry and only the volunteers and enthusiasts will keep it going.  I would strongly, recommend that you should start using something else.  To read the Adobe Blog, click at this link:
    <http://blogs.adobe.com/dreamweaver/2012/08/update-on-adobe-spry-framew ork-availability.html>
    Good luck.
    Sep 12, 2012 8:35 PM   in reply to WolfShade
    Sure, SPRY is still supported but the experts are normally in this forum:
    <http://forums.adobe.com/community/labs/spry>
    Unfortunately, it is not very active. and so you will get some replies here; it is a question of waiting until Gramps is around
    Good luck.
    Sep 13, 2012 6:50 AM   in reply to WolfShade
    WolfShade wrote:
    And I'm just starting to learn it, just because.  It's something different.  I'll probably never use any of it in any paid projects, but it's still nice to get a feel for it.
    I have never used the rating widget, but I do have the Spry example files from when they were originally released. I assume that you have managed to download the same files from GitHub.
    Open widgets.html in the widgets folder. Scroll down to the bottom, and click the Ratings > Overview link. Close to the bottom is a section titled "Update the Ratings Value Dynamically". The example code looks like this:
    <body>
     <span id="spryrating1" class="ratingContainer">
     <span class="ratingButton"></span>
     <input type="text" id="ratingValue" name="dynamic_rate" value="2"/>
     </span>
    <script type="text/javascript">
     var rate = new Spry.Widget.Rating("spryrating1", {ratingValueElement:"ratingValue", afterRating:'serverValue', saveURL:'SpryRating.php?id=spryrating5&val=@@rw_Rating@@'});
    </script>
    </body>
    Notice that the options object contains this: afterRating: 'serverValue'. Unfortunately, the sample files (at least the ones I've got) don't include a copy of SpryRating.php. However, I assume that it probably saves the selected value, calculates the average of all saved values, and then uses echo to output "serverValue=4.5" (or whatever the average is).
