VideoError: 1000: Unable to make connection to server or to find FLV on server
Sep 12, 2012 5:18 AM
Tags: #flvplayback #videoplayer #1000 #videoerror:
Hello there,
I am using a simple FLVPlayback control in my AS3 document. In that I invoked FLVPlayback's methods like play, seek, and stop. Whenever I use these methods I get "VideoError: 1000: Unable to make connection to server or to find FLV on server" error while publishing the file. If I remove these method call then I am not getting this error.
Note: If I load above published file in another file then I'm not getting this error, however same is not working on LMS.
It will be of great help if someone help me resolve this issue.
  • kglad
    Jul 21, 2002
    Sep 12, 2012 7:35 AM   in reply to Athang
    copy and paste your relevant code and highlight the problematic line of code.
  • kglad
    Jul 21, 2002
    Sep 13, 2012 6:42 AM   in reply to Athang
    that code must be on your movieclip's timeline.  is it?
    and, what works well with no code?  does you flv play?
  • kglad
    Jul 21, 2002
    Sep 13, 2012 6:59 AM   in reply to Athang
    just above your code, what does the following show:
    trace(vPlayer.name);
    trace(vPlayer.source);
  • kglad
    Jul 21, 2002
    Sep 13, 2012 8:10 AM   in reply to Athang
    that can't be.
    did you change the trace() statements in any way?
    what is your url and what needs to be done to (try and) play sampleVideo_01.mp4?
  • kglad
    Jul 21, 2002
    Sep 13, 2012 11:14 AM   in reply to Athang
    in your first frame, replace:
    vPlayer.stop();
    with:
    if(vPlayer.playing){
    vPlayer.stop();
  • kglad
    Jul 21, 2002
    Sep 14, 2012 3:42 AM   in reply to Athang
    you don't need anything different in your 2nd frame but you don't need to execute the play() method if your video is already playing so you could use:
    if(!vPlayer.playing){
    vPlayer.play();
    p.s. please mark helpful/correct responses.
  • kglad
    Jul 21, 2002
    Sep 14, 2012 4:49 AM   in reply to Athang
    remove vPlayer.playheadTime=0;
    and, if message 9 resolved your problem, mark it as the correct answer.
  • kglad
    Jul 21, 2002
    Sep 14, 2012 5:25 AM   in reply to Athang
    it doesn't appear you're getting any help from me so let's see if someone else can help you.
