Spry menu bar changed since I tried to split cells in a table! Help!
Sep 12, 2012 7:22 PM
Tags: none (add) #spry #menu #bar #problems #cells #splittingI am VERY new to web design, so I apologize in advance for being ignorant. I am trying to learn!
I had inserted a spry menu bar that looked fine and even tested fine!
I subsequently tried to split a section of my table in the web page in order to have 3 columns of centered text. The first time I did this, the spry menu bar became vertical even though it is listed as horizontal. I looked up a forum answer, copied the code from the suggestion, and that seemed to fix the problem (although I still don't know what EXACTLY happened)
I tried to split the table again (I had undone everything prior to this), only this time, the spry menu bar is located outside the page in the left hand corner where my background (I have a wrapper) is. I tried opening another page where I already had a nice spry menu bar, and it did the same thing!! This makes me think it is the CSS sheet for the menu bar that was modified somehow when I split the table. I'm pasting the CSS here below, so if anyone sees any issues that might cause this problem, please let me know!! I have been working for the most part in design view, and haven't really modified the code other than to put a wrapper in and a facebook like button, which I've now lost in the slitting cells catastrophe. Thanks in advance!!!
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - Revision: Spry Preview Release 1.4 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
margin-top: 0;
margin-right: auto;
margin-bottom: 0;
margin-left: auto;
padding: 0;
list-style-type: none;
font-size: 12pt;
cursor: default;
width: 60%;
float: left;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 12pt;
position: relative;
text-align: left;
cursor: pointer;
width: auto;
float: left;
background-color: #99CC66;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
margin: 0;
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: auto;
position: absolute;
left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
width: auto;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
position: absolute;
margin: -5% 0 0 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
padding: 0.5em 0.75em;
color: #333;
text-decoration: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #336600;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
background-color: #33C;
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDown.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDownHover.gif);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
