Ronny Jaeger
Push a button to reset dps
Sep 13, 2012 5:18 PM
Tags: #dps #reset #unread
hi
i'm looking for a solution to unread my folio. on the last site i have a button. if i press this button i jump to the first site. at the same time i wish the unread/reset folio function.
found this site.
http://blog.gilbertconsulting.com/2012/01/how-to-reset-dps-ipad-app-as .html
is there another solution? would be great.
thanks
    Sep 17, 2012 11:01 AM   in reply to Ronny Jaeger
    To Rodger Jaegar,
    ? What do you mean by unreading your folio.
    The app you viewed can use Swipe Control, The Scrub Bar at the bottom, and the Table of Contents to the left hand side, or you can visually browse horizontally through the table contents on the right tapping any of these areas will take you back to any page you may have read within the folio.
    "Tap somewhere on the screen to reveal the DPS "Chrome" (the interface elements provided by Adobe Digital Publishing Suite). Locate the name of the app in the title bar at the top of the screen.
    Tapping once on the name of the app will bring you to the first screen of the app. But tapping three times rapidly on the name of the app will reset the view to the top screen of every section. You must get the timing of the "triple tap" correct for it to work. This is a handy tip for reading DPS-created apps. I wish there were a more obvious way to do this!"
    To my knowledge the feature of jumping between folios Is not available, but maybe someone else would care to offer comments on a possible workaround, maybe even a feature request if possible.
    Regards
    Vividi
    Sep 17, 2012 11:03 AM   in reply to vividi
    Sorry should have been Ronny
    Vividi
    Oct 11, 2012 6:04 AM   in reply to Ronny Jaeger
    hi Ronny
    I have the same problem and our client wishes exactly a button like this.
    have you found some solution by now?
    Regards
