Default export settings
Sep 13, 2012 6:43 PM
Tags: #cs6
Fireworks CS6 / Windows 7 / 64 bit
Casveat: I am a novice in Fireworks
Every time I export a file the export dialog box defaults to gif. I do not use a lot of gif files so I  have select another file type on virtually every export. Is there a way to set preferences on the export dialog box?
Thanks for any help from those who are more knowledgeable than me,
Joe
    Sep 13, 2012 6:58 PM   in reply to camelbreath
    That's interesting. I find Fireworks' Optimize/Image Preview settings to be “sticky”—that is, the settings of the last saved file or the last opened file are remembered for the next new file. So there is no default, per se, but if you save a file, its optimization settings will also be saved. And those settings will carry over into the next new file that you create.
    I think that's what's happening, anyway.
    I'm using Fireworks CS6 on Mac OS 10.6.8 (Snow Leopard).
    Sep 13, 2012 7:45 PM   in reply to camelbreath
    Not sure what you mean by "drag"... I do find the Export settings somewhat responsive to the original file type, so that a JPEG being opened in Fireworks will tend to default to a JPEG Export setting. (Are you opening JPEGs, GIFs, or something else?)
    But going back to my previous comment, it might be helpful to Save the file after exporting to "lock in" a preferred setting for the next file. On the other hand, I think that exporting should also serve to "lock in" a preferred setting, without the need to save. So I'm not sure about this.
    I did notice this: In the user library Application Support folder for Fireworks CS6, there's a folder called Export Settings that includes a text file called "last-settings" that apparently does nothing but record the last settings used in the Optimize/Image Preview panel. Again, I think that either saving or exporting a file should trigger a rewriting of this file's contents.
    Sep 14, 2012 2:10 PM   in reply to camelbreath
    This just reiterates what I've already suggested regarding "sticky" Optimization settings, but it's nice to see it in print:
    http://help.adobe.com/en_US/fireworks/cs/using/WS4c25cfbb1410b0021e63e 3d1152b00d6af-7ff9.html#WS4c25cfbb1410b0021e63e3d1152b00d6af-7fdf
    Note that the remembered settings will be applied to new documents. It doesn't really specify what happens when opening a pre-existing, non-Fireworks document, such as a JPEG. (Presumably this might depend in part on the application that originally created the file.)
