RoyaFuze7
How can I resize a shape tween without it looking wonky?
Sep 14, 2012 1:25 AM
Tags: #resizing #adobe #flash #animation #tween #resize #shape #stage
Hi! I'm a beginner in flash animation, although I have used it to draw several years before.
I have a simple problem that I can't seem to find the answer to. I've been looking in many places.
Anyways, I have a stage at its default size of 550px x 400px. I thought it would be easy to change later on so I didn't bother making it larger in the beginning. Now that my design is complete, I want to make the stage bigger (to 1024px x 768px) AND stretch the graphics/ contents on the stage as well to more properly fit the larger stage. And I want this centered too as it is aligned to the left side now when I preview it in my browser. This would be a piece of cake if I didn't have a shape tween that looks like wind blowing hair in it!
The dilemma is that when I resize the graphics, the shape tween ends up following those movements, thinking that it is part of the animation when it isn't supposed to be. My question is...how can I resize a shape tween without the keyframes following the movements I make? I just want a bigger version of the shape tween I already have set up and do not want it growing bigger/ changing position to be part of the animation!
Please help. Thank you!
  • kglad
    Jul 21, 2002
    Sep 14, 2012 4:05 AM   in reply to RoyaFuze7
    you can use shape hints (modify>shape>add shape hints) to control shape tweening: http://www.adobe.com/devnet/flash/learning_guide/animation/part12.html
    Sep 14, 2012 12:07 PM   in reply to RoyaFuze7
    One of these three things should work:
    1. Try clicking the wrench next to stage height and width, and entering your new width and height there, then clicking "Scale content with stage."
    2. In your Publish setting, select "Percent", and pick a percentage larger than 100.
    3. Follow the steps here http://flashthusiast.com/2009/10/06/scaling-and-moving-new-motion-twee ns-in-flash-cs4/
    Good luck!
    Sep 16, 2012 10:59 PM   in reply to RoyaFuze7
    Select the option Modify> Document settings, then change the dimensions and click the check box "Scale the content with stage". The content in the stage will be enlarged proportionately based on document size.
