Hello, I am unable to get the points to show with the camera tracker. The tracking points show only when I check render track points but I am unable to move my mouse pointer over them to interact and assign anything to them. I have everything on the highest quality settings.
I attached a screenshot in case someone can see any setting I missed clicking on.
I have an iMac with:
Processor 2.4 GHz Intel Core 2 Duo
Memory 4 GB 667 MHz DDR2 SDRAM
Graphics ATI Radeon HD 2600 Pro 256 MB
Software Mac OS X Lion 10.7.4 (11E53)
Thank you,
Scott
Look at this....
...and this...
...and this, too....
...and as a reference, keep this handy.
Most AE features aren't very intuitive, and you need to get trained up.
I just took a second look at your computer specs, and you only have 4 gigs. That's nothing in AE terms. You need to trick that thing out with memory. I suspect you're tracking a clip that's longer than ever attemped before, and you're running out of RAM as AE analyzes the clip, leaving no track. points.
For now, turn off multiprocessing if it's on -- there's no way you can use it -- and you shouldn't have to worry about AE using Open GL; it's not an option any more. Additionally, you should make sure your Radeon driver is fully updated; it too is a cause of AE not performing as advertised.
My Graphics Card is updated but still these points dont show. The video clip is not long at all- 37 seconds and the project does not bog down the machine at all with 4GB of Ram. I have had some massive projects loaded in here before with like 25 to 30 layers and it would work quite well. I love this camera tracker if this iMac would allow it to work. Will Adobe be looking into this problem anytime soon?
Thank you,
Scott
Scott, I had the same issue yesterday . I have had lots of experience using (beta testing) the AE Tracker as well as Syntheyes and The Foundry Tracker. I tracked a clip and NO tracking points or targets were visible. I deleted the clip and the comp and created a new comp from the clip. It worked that time
I have an HP Z820 with 64 GB of ram so I dont think ram is my issue. Im also up to date with the Nvidia drivers for my GTX 570 card. I know Nvidia has been the source of lots of different CS6 issues recently so my money is on that.
