fullScreen problem
Sep 12, 2012 6:38 AM
I'm calling swf file (video player) through URL Loader. all controls are fine.
but i facing problem at fullscreen mode.
*my player is into a movieClip called as content_mc .
*that movieClip registration point is middle.
how can i solve this problem without changing registration point?
problem:
    Sep 12, 2012 6:59 AM   in reply to Venkom
    Center registration often requires positioning with negative x/y values.
    Just calculate the size of the video player and divide its height and width by 2 (half). The number you get is the amount you need to move into the negative. To negate the number just multiply it by -1.
    e.g.
    videoPlayerMC.x = int(videoPlayerMC.width / 2) * -1;
    videoPlayerMC.y = int(videoPlayerMC.height / 2) * -1;
    If your videoPlayerMC was 640 width, 480 height then the numbers returned would be x = -320, y = -240. I wrapped it in int() casting to make sure it's a whole pixel with no fraction.
    There's other ways but this is most verbose and easiest to understand.
    Sep 12, 2012 6:50 AM   in reply to Venkom
    What code are you using for the x/y placement of the video player?
    Sep 14, 2012 9:11 AM   in reply to Venkom
    On your first frame script update the y position of the contentBox like you are the x position:
    function updateSize(e:Event)
        //Set background's size
        backgroundMC.width = stage.stageWidth;
        backgroundMC.height = stage.stageHeight;
        contentBox.x = stage.stageWidth/2;
        contentBox.y = stage.stageHeight/2;
    Inside the contentBox frame script you use the stage's dimensions rather than the videos:
    if (e.fullScreen)
        pLoader.x = int(stage.stageWidth/2)*-1;
        pLoader.y = int(stage.stageHeight/2)*-1;
        // rest...
    Sep 17, 2012 6:59 AM   in reply to Venkom
    You're welcome and good luck!
