Saving Input TextBox entry to variable, using in textbox on another frame
Sep 14, 2012 10:30 AM
Have been trying without success to save user input in a input text box, save to variable, then use this variable to populate text in a dynamic textbox on another frame.
First frame:
var a:String;
var b:String;
var c:String;
aName1.addEventListener(Event.CHANGE, inputCapture1);
function inputCapture1(e:Event):void{
a = aName1.text;
bName1.addEventListener(Event.CHANGE, inputCapture2);
function inputCapture2(e:Event):void{
b = bName1.text;
cName1.addEventListener(Event.CHANGE, inputCapture3);
function inputCapture3(e:Event):void{
c = cName1.text;
Then on another (later) frame
dynamictextbox1.text = a;
And so forth on other frames.
So far have crashed the debug preview. If I take out the script on first frame and later frame, no crash.
Any help appreciated.
    Sep 14, 2012 10:53 AM   in reply to saratogacoach
    You need to have the layer with the code above extended as far as the later frame so that those vars are available there.
    Sep 14, 2012 11:43 AM   in reply to saratogacoach
    I don't see any such variables in the code you offered, so I can't say what the problem might be there.
    Sep 14, 2012 11:51 AM   in reply to saratogacoach
    You'll need to show the code.  That line alone as shown ( aName:String  ) is an error, either a "var" belongs in front of it, or the ":String" needs to go away
    Sep 14, 2012 12:11 PM   in reply to saratogacoach
    You seem to be changing things with every posting without telling the whole story.  I can't follow that.  I see no "aName" in that code, so I cannot answer for the error you ask about.
    Sep 14, 2012 12:58 PM   in reply to saratogacoach
    What's the problem?
    Sep 14, 2012 1:50 PM   in reply to saratogacoach
    You're welcome
