Advanced
Sep 14, 2012 2:35 AM
Branched to a new discussion.
Replies 1 2 Previous Next
    Sep 14, 2012 2:35 AM   in reply to Community Help
    i have flashplayer 11.4.402.265 installed only 2 days ago.  now i get a massage that i need flash player to view a video. can some one tell me what is wrong. this is not the first time it has happened. my OS is windows7
    Sep 14, 2012 2:47 AM   in reply to novice21
    Could you please go to the following page and let us know the Flash Player version installed?
    http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
    Sunil
    Sep 14, 2012 6:32 AM   in reply to Community Help
    i opened the above page it shows      NO FLASH PLAYER.   my computer control penal shows flash player version 11.4.402.265 installed on 9/11/2012.
    Sep 14, 2012 6:45 AM   in reply to novice21
    Please check if ActiveX Filtering is disabled.
    http://helpx.adobe.com/flash-player/kb/flash-player-games-video-or.htm l#main_2__Disable_ActiveX_Filtering__if_you_are_using_Internet_Explore r_9_
    I am assuming you are on Internet Explorer 9. If not, please let me know your browser.
    Sunil
    Sep 14, 2012 7:54 AM   in reply to Sunil_Bhaskaran
    thanks for prompt reply.
    i am on internet explorer 9
    x filtering is disabled
    Sep 14, 2012 11:30 AM   in reply to novice21
    Try resetting IE. Go to Tools, Internet Options, choose the last tab called Advanced, then "Reset". This will reset IE to its default functionality. This will most likely solve the problem. It will reset your default start page though, so be prepared to change that setting back. Let me know if this did the trick.
    Sep 14, 2012 11:52 PM   in reply to Geeks2You
    resetting IE has solved the problem. thanks Geeks2You thanks SUNIL. What could possibly have created this problem??????? if you have an answer that will help me in future
    Sep 15, 2012 2:32 AM   in reply to novice21
    Most likely the Flash Player add-on was disabled; see http://forums.adobe.com/thread/885448
    Sep 15, 2012 9:59 AM   in reply to Community Help
    How to I tell flashplayer NOT to run YouTube and other content without specific authorization each time? I hate having these things start on their own.
    Sep 15, 2012 11:05 AM   in reply to Pat Willener
    thanks pat.   i am wiser now
    Sep 22, 2012 5:48 PM   in reply to Community Help
    I have the latest Flashplayer installed, hen I go to games in Facebook I get a message to upgrade flashplayer.  I removed flashplayer and reinstalled it but I still can't play games and the same message appears.  I have done this 3 times with no success.  Please help.  Thankyou.
    Sep 24, 2012 1:51 AM   in reply to lyndaough@rogers.com
    Could you please go to the following doc and let us know the Flash Player version you have?
    Sunil
    Oct 3, 2012 5:13 AM   in reply to Community Help
    11.4.402.265 is the latest Flash Player installed. Runnig Mountain Lion OS X 10.8.2 (12C54). Drop down window states I need to install the latest Flash Player.
  • Chris Campbell
    May 4, 2010
    Oct 4, 2012 4:09 PM   in reply to RDDude
    @RRDude - What down down window are you referring to?  Can you take a screenshot and post it in a reply?
    Oct 9, 2012 11:46 PM   in reply to Community Help
    I have completed the follow steps repeatedly and restarted my browser but still receive the security error while trying to preview my Flash project in a browser:
    Trusted Location Settings...
    Use this tab to specify locations on your computer that containing SWF or FLV content that you trust. Trusted content is not subject to the security rules that prevent content from accessing both the Internet and your local computer’s file system.
    To specify trusted locations for developer testing
        On the Advanced panel, under Developer Tools, click Trusted location settings and then click Add.
        Enter the location on your computer that contains the trusted content, or click Browse files or Browse for folder to locate the file or folder to trust. If you specify a folder instead of a file, then all of its contents (including subfolders) become trusted as well.
        Click Confirm to add the domain, file, or folder to the list of trusted locations.
    I am using:
    Flash Player Version: 11.3.300.265
    OS: Mac OS 10.6.8 (64-bit)
    Browser: Mozilla Firefox
    Any clues?
    Wes
    Oct 17, 2012 1:44 PM   in reply to Community Help
    since updating the latest version of flash player, whenever i watch videos on youtube, even in full screen mode, my top bar is visible. how do i prevent this from happening?
    Oct 17, 2012 3:16 PM   in reply to wesleyray
    I did discover what the issue was. There appears to be a bug in Dreamweaver CS6 as the only way to get the Flash animation to display in a browser preview was to delete the swfobject_modified.js file. Dreamweaver added this file to the Scripts folder when the html file was saved. In the past these files were required to view the Flash animation.
    Oct 18, 2012 11:02 PM   in reply to Community Help
    I too am against this issue, suddenly, though I have noticed my computer struggling with playing TV the past few days.
    The note I get:
    Unable to install the Adobe Protected Content Module.
    Click here to upgrade your player.
    My Browsers: Firefox, Safari, Opera
    MacOS 10.5.8
    Version of Flashplayer: 10.3.183.29 (doublechecked on your site)
    Please advise.
  • Chris Campbell
    May 4, 2010
    Oct 19, 2012 3:05 PM   in reply to yeepoa
    @yeepoa - What URL is giving you this error?  As you noted, 10.3.183.29 is the latest version of the player available for your OS.  Was this website working for you before?
    Oct 24, 2012 2:36 PM   in reply to Community Help
    I have spent several hours trying to install flash player.  I have completed all of the steps recommended by Adobe Flash Player Help/Installation/Windows to no avail.  I have as a result uninstalled and reinstalled multiple times and am told that my download is successful.  I am on Windows 7 Home Premium and have 64 bit op system.  Can someone please help?  Thank you.
    Oct 24, 2012 7:13 PM   in reply to Community Help
    i always fail downloading flash player update; checked the Flash Player Settings Mgr. under Advanced tab: Active X version : 11,0,1,152 , Pug-in version : Not Installed.
    Checked on the Version Information: 9,0,124,0 installed
    What should I do?
    Oct 26, 2012 3:10 AM   in reply to noelnunez
    @cadesro@comcast.net
    After downloading, you need to install Flash Player. Close the browsers and double-click the downloaded file.
    In the following page, you have step-by-step information: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#main-pars_heading_5
    Could you please confirm, if you have done the same.
    Also, ensure that you have disabled ActiveX Filter if you are using Internet Explorer 9:
    @ noelnunez
    What's your operating system?
    If you have download issues, download Flash Player from the following link: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-pla yer-windows.html#main-pars_header
    After downloading, close browsers and double-click the downloaded file.
    Sunil
    Oct 26, 2012 7:56 AM   in reply to Sunil_Bhaskaran
    Thanks for your help Sunil.  After I disabled the Active X  filter it is working!   Great forum!
    Sent from my iPhone
    Dec 4, 2012 8:28 AM   in reply to Sunil_Bhaskaran
    ok
    Dec 10, 2012 8:01 AM   in reply to Sunil_Bhaskaran
    If I read his question correctly, the very first thing he said is, "installed version XXXX." Didn't your read the question?
    Dec 11, 2012 3:33 PM   in reply to Community Help
    Hi, I have 64 bit windows 7 ultimate and my main browser is google chrome, but tried with the other and won't work!
    Since yesterday that I'm with trouble to see stream videos, I can watch videos on youtube.
    I tried several times to uninstall and make a new installation, and one of the times it worked, but that happened one time and when I restarted the labtop the problem appeared again!
    The problem is when the instalation reaches the 7% stops every time and says download timetout!
    I tried restoring the system, download directly from links that I saw in this forum, installing with the antivirus shutdown, but nothing works!
    Dec 19, 2012 12:08 AM   in reply to Community Help
    Hi
    I have installed the last version of FlashPlayer on my Macbook Pro and now I cant use my cam. Do someone now whats wrong?
    Dec 19, 2012 12:10 AM   in reply to Community Help
    I have installed the new version of FlashPlayer on my Macbook Pro and now my cam do not work.
    What can be wrong?
    Dec 21, 2012 10:08 PM   in reply to novice21
    Facebook is just so slow, and I need help. My computer runs great, but Facebook is way to slow
    Jan 10, 2013 12:38 PM   in reply to Community Help
    I have repeatedly downloaded the upgrade Flash player. My Mac has version 11.5.502.146  on it, and states that there are no more updates. Some Youtube videos play and others don't, and say the latest version must be installed. This is very frustrating.
    Jan 15, 2013 1:53 AM   in reply to Community Help
    how do i disable video autoplay?
    Jan 16, 2013 4:20 PM   in reply to Community Help
    i am a developer and my SWF and FLV are not opening from local location , and i did as told to do and change security settings and added the file i want to open , but still it shows me the same error and says Adobe Flash Player has stopped a potentially unsafe operation , the following local application on your computer or network :
    C:\Users\.........\untitled1.swf
    is trying to communicate with this internet -enabled location :
    to let this application communicate .............
    as i said i clicked the settings...
    then add the file to the global security settings .
    and try to open the file again but shows me the same thing again !!
    im using windows 7 32 bit
    and the Adobe Flash Player -
    You have version 11,5,31,137 installed
    Feb 5, 2013 8:59 AM   in reply to Community Help
    I have downloaded Flash player ten times and it will not work for me, I have tried the proper versions for my system and it is not running at all. I get to the point of it downloads but does not save.
    Mar 16, 2013 3:03 AM   in reply to Community Help
    Why do changes to the settings made in the Flash Player preference pane in OS X (10.7.5) not 'take'? I've seen this same behaviour in several different recent versions of Flash. Very irritating to see that there'sat least nominallyoptions to control what Flash does/allows, but that the minimal interface to those options fails utterly to work. Not particularly confidence-inspiring, all things considered.
    Mar 17, 2013 6:42 AM   in reply to tempidunavailable
    in mozilla firefox install add-ons : Flashblock
    Mar 17, 2013 6:50 AM   in reply to kerrwill
    Apr 17, 2013 6:19 PM   in reply to Community Help
    I have this error in this site..
    http://pse.ph/stockMarket/companyInfo.html?id=233&security=140&tab=0
    Flash Security Error: AnyChart can not be launched due to Flash Security Settings violation
    I need help, I already re-install the latest Flash Player and Google Chrome still I cannot view stock charts.
    Apr 28, 2013 6:54 AM   in reply to Community Help
    I've installed firefox 4 plugins, adobe air, flash player, flash activeX, shockwave. but sometimes I can not play an online video, why? enlightenment please ...... thank you
    May 9, 2013 2:44 PM   in reply to Community Help
    I am using Internet Explorer 10 and I get no video only sound on website videos. I went to the adobe flash player help page and it tells you "The Settings Manager that you see above is not an image; it is the actual Settings Manager." but there is nothing shown above this comment. and I cannot find any help anywhere that is able to solve this problem. Any suggestions on how to fix this is appreciated.
1 2 Previous Next
