PTTAresearch
A realistic assessment of your experiences of hardware needed for the type of editing I do please.
Sep 15, 2012 8:02 AM
Introduction:
I apologise for the length of this post but from experience of reading here, I'm working on the principle of the more I explain about myself now, the less anyone willing to help me will have to ask later.
I have lurked around this forum on and off for a few years, read the various threads in the FAQ section, particularly PPBM5 and What PC to build thread and other related topics around what system to build.  I have found them very useful and in particular have enjoyed reading about Harm Millaard's experiences First Ideas for a new system.  For about about 12 months I've been delaying upgrading my PC but in Mr Millard's latest updates on his PPBM6 site he talks about new systems and  provides a link to Intel's time line which suggests they are in no rush to replace the i739xx series CPU chip - which has I believe amongst other things 2 cores disabled.  Normally bitter experience has taught me not to rush out and buy the latest technology but let others "test" it first and then benefit from reduced prices as that model is replaced.  However, it now seems like last years technology is going to remain as this years technology and probably the first 2 quarters at least of next year and, if anything, the price of the i739xx series is at best staying at it's existing launch price or even rising.  So it's time to take the plunge for me and upgrade.
My current hardware for editing:
I started with Premier 6.5 after I bought it as part of a bundle with a Matrox RTX 10 card - one of the most temperamental pieces of hardware I've had the misfortune to work with.  I later upgraded to Premiere Pro 1.5 and edited with that using a Pentium 4 2.6 (overclocked to 3.2), 3 hard drives (no raid) and 4G of memory.  The video footage used was avi recorded using a Canon MVX 30i and Panasonic NVGS27 and now I've added the Casio Exilim EX -FC100 (mpeg format) and a Panasonic HDC S90 (AVCHD).
My PC coped with the editing I did with avi footage but couldn't handle AVCHD format and this convinced me to upgrade to Premiere Pro CS5.5.  At the same time I switched to editing on a Dell XPS M1530 (Centrino duo chip) - I upped the memory to 4GB, put Windows 7 64 bit home edition on and replaced the existing hard drive with a faster one.  In addition I use a SATA Quickport duo attached to my laptop via an eSATA card.  However, either the Quickport, eSATA card or XPS is extremely temperamental - I never see two external hard drives, 50% of the time see 1 external drive or none at all - when that happens I edit around it doing things I can with just the one internal drive - but this problem is not my question.
The type of editing i do:
I know people usually say around here not to try editing on laptops and believe me, I understand why, but using this setup I have been able to edit lots of videos  - see here for examples of the type of editing I currently do:
http://www.youtube.com/user/PathfinderPro
The equipment test videos place the biggest strain on the hardware when editing.  And, to do this editing I have to convert my AVCHD footage in to it's YouTube format before editing and even after I've done that it can be tediously slow to edit and playback even with premiere set to play at 1/4 normal quality.  To convert the AVCHD footage to the YouTube format I edit in has to be done over many nights.
Now I am not a professional, I typically edit with up to 4 tracks of video with additional tracks for titles and my target audience is YouTube - which is why I can get away without editing in my prefered option of native AVCHD video format.  However, I'm tired of all the waiting, stuttering, and many many days and hours of converting videos into a format I can use so I'm looking to upgrade.  My problem is though I'm uncertain what path to take.  The PPBM results are dominated by overclocked chips, and whilst the motherboard make and model is listed, the hard disks used, graphic card makes and models and memory modules are not.  This is not a criticism of the PPMB tables (big thank you to Bill Gehrke & Harm Millaard for taking the time and effort to pull this much information together) but for me, I am not interested in being in the top 1000 in the world, nor overclocking like mad, and having had horror experiences of using matrox products and compatibility and stability issues with other hardware I'm more interested in compatability and practicality than speed when deciding what to build.  I've also read the threads about marvel controllers, dual and quad channel memory support, the pro's and cons of SSD or standard drives, raid setups, the heat problems with overclocking the newer ivy bridge chips and general build advice etc so I'm not coming here without having done some reading first.
The type of system I'm thinking of:
So far based on what I've read here, I've come to the conclusion - but I'm open to suggestion:
- Chip - regrettably due to the cost and unlikely successor anytime soon - a 39xx (with appropriate cooler) because I want to edit in native AVCHD which seems to require the warrior type chip as opposed to the "economical" build regardless of what my target audience is and this suggests
- X79 motherboard (which must have an old PCI slot such as the Asus Sabertooth and which has room for the cooler I'm considering).  As I will be carrying over my old terretec DMX 6 fire 24/96 soundcard - all my videos have their audio mastered in Audition using this card - best piece of advice I read was the audience will watch a bad video with good sound editing but not the other way round)
- 4 hard drives plus additional hard drive for operating system using onboard raid controllers (not sure whether the operating system drive will be WD caviar black or SSD and can't justify cost of external raid controller for either my type of use or number of hard drives being used)
- Video card - I can now buy a GTX 580 for less than the 670 - so not sure on the card especially based on Harm Millards observations that memory bandwith seems to be as important as CUDA cores
- Case - I have an Akasa 62 case with room for 5 hard drives - I won't be exceeding that, and if I overclock it will only be by a little so is it really necessary to replace it for a Tower Case - although I would prefer a case with a front connection for esata so I may have to change the case regardless
- Maximum memory 32G - so is it necessary to upgrade to windows 7 professional?
- Power source - I'll work out when I've decided on my components.
Help please:
For me it's video source/dictated software chosen and hardware/audience(youtube) dictates format edited in.  As I don't intend to change my camcorders format (AVCHD or mpeg) in the next couple of years and I'm not interested in having the "fastest" system around what I'm really interested in learning is:
  • what system setups people use now for doing similar editing to me
  • what make/models of the component parts in your system work well together
  • and if you do have a bottle neck in terms of hardware, where is it and what hardware would you change to  (not a dream model change, just a practical and realistic one)
I have deliberately not given a budget for the changes I'm intending because budget should not be the deciding factor in determining what I "need" to upgrade to for the "type of editing I do" - especially bearing in mind I've got by so far (admitedly at a tortoise pace) with by todays standards a standard spec laptop.  Basically I don't want a Rolls Royce to go shopping at Wallmart but I'm tired of walking there and carrying everything back by hand!
Thank you very much for any help / experiences people can share.
    Sep 15, 2012 9:33 AM   in reply to PTTAresearch
    Nicely documented question, well done. I watched your PTTA link and if that is typical of your editing projects, it leads me to several conclusions:
    • Single camera operation, shot from a tripod in a controlled environment, relatively long clips.
    Thus no multicam, no warp stabilization, no (significant) CC work, single track video plus some titles and other stuff. In all, pretty straightforward editing and very limited effects. It is also good you did not mention budget, because that allows me to suggest some different approaches for editing these kind of movies with AVCHD as the source. You mentioned no dedicated raid controller.
    If this premise is correct, the i7-3930K on a X79 platform may be somewhat overdone and an i7-3770K on a Z77 platform may be the best BFTB for this kind of editing. Whichever way you turn, 32 GB is nice to have and 4 disks is also very good. There is always a drawback to saving some pennies here or there. If you opt for the more affordable Z77 platform, you also foreclose the use of a dedicated raid controller in the future, unless you accept a 10-15% performance degradation with the video card. For 32 GB memory, you need Win7-64 Pro. Home cannot access more than 16 GB.
    If you go to Planning & Building a NLE system you can see what my choices were and where I stand. Take your time to read all those pages and I hope you can find some answers to the doubts you are feeling, just as I have my doubts from time to time.
    I don't know about your monitor setup, but performance wise there is hardly any difference between the 580 and the 670. The main difference is the ability to steer 4 monitors with the 6xx series versus only 2 with the Fermi range of 5xx cards.
    Accepted, your correct criticism of the lacking hardware info on the PPBM5 website. That is the overriding reason that for the new site http://ppbm7.com/ we want to use Piriform Speccy .xml results to gather more, more accurate and more detailed hardware info.
    Hope this helps.
    Sep 15, 2012 9:44 AM   in reply to PTTAresearch
    You have provided lots of details in your post, good job!
    AVCHD is rather nasty, but you are not doing lots of effects, 4-channel multicam, or anything else that really taxes an editing session. So, for a sub-$1500 outlay you would be able to build a system that would edit native AVCHD single track really, really well with CS5.5. I'm putting suggestions below for a desktop, but if you would prefer to go with a massive, heavy laptop the ASUS 17" solutions with quad-core i7, 16GB, dual drive bays, plus an external USB 3.0 or eSATA drive can also do pretty well for around the $1500 price point.
    I would say you need:
    i7-2600k, recommend OC to at least 4.2GHz if you are OK with that
    good cpu cooler; yest, even if you don't plan on OC'ing, keep your CPU cool (included Intel cooler is lously)
    16GB RAM
    boot drive (128GB really sweet; existing older HD from your current system would work though)
    GTX 570 or 670
    2x1TB RAID 0 (for all your files)
    A more powerful system for about $500 to $1000 additional would be:
    128GB SATA for boot drive; does not help Premiere Pro CS5.5 at all, but it really makes a PC feel a whole lot faster and fun
    i7-3930k; this is a really strong CPU and would keep you happy for years
    32GB RAM
    GTX 580 or 680
    (2) 2x3TB arrays; more storage space, faster having one array for media, projects, and scratch, 2nd array for media cache, media cache db, and render outputs
    Jim
    Sep 15, 2012 1:14 PM   in reply to PTTAresearch
    As I said in the Intro, the main codecs I use vary from simple ones like DV and HDV up to RED and EPIC 4K and 5K material, but the majority is HDV, AVCHD, XDCAM-EX 4:2:2 and Canon MXF 4:2:2.
    The biggest project I have ever done included around 27 hours of source material, three different cameras, up to 12 video tracks with a lot of chroma keying and color correction and with the codecs in use that led me to my choice of the 3930K, but also because I'm a speed freak.
    However, it appears you needs are not as big as that and that is why I suggested the more affordable i7-3770K for you. Of course, you are more future proof with an i7-39xx but at a price. That is for the CFO, your wife, and your wallet to decide.
    Just this afternoon I received my EVGA GTX 680/4G Classified and it is huge. Not a problem with my Magnum TH-10 case, but with smaller cases it may become a problem. Just check the dimensions carefully and hope that the video card of your choice will not get in the way of some of your drive bays.
    The choice of a 570/580 or a 660/670 will not impact your performance in a major way, and your two monitors can be handled easily both by Fermi and Kepler cards. One thing to consider is that exporting to YouTube may entail scaling, going from 1920 x 1080 to a smaller size and in that case the video card can have a distinct impact on your export times. If you keep everything at 1920 x 1080, then the video card has no impact on the export times.
    The choice of platform of 1155 or 2011 is more fundamental. The 1155 platform is limited to effectively 16 PCI lanes, the 2011 has 40 PCI lanes, so you can add a dedicated raid controller, a second video card for other applications like Resolve, or add a BM, AJA or Matrox card without negatively influencing the performance of the video card. Additionally, you can expand memory to 64 GB. But they come at a price...
    The i7-2600K Sandy Bridge Jim mentioned has been succeeded by the Ivy Bridge i7-3770K, newer technology, smaller scale manufacturing and less power consumption, but mainly pretty comparable in performance. They use the same motherboards. Both are unlocked versions and can be overclocked easily.
    Unfortunately, I can't tell you which is the wisest decision in your specific case, you have to weigh to pro's and con's yourself.
    As to using names here on the forum, I very much like people using REAL names, instead of all kinds of convoluted and nameless screen names like 'grrr01' or 'adobehater' or whatever they can come up with. As to your screen name, PTTAresearch, I can place that name on the basis of your link, but it does not tell me your real name. And adressing me as Mr. Millaard is something that I think my father would have liked very much. He had a tendency for decorum and practiced that till his death on Christmas Day last year, but I have a preference for being called Harm, which I usually don't do.
    Sep 15, 2012 3:49 PM   in reply to PTTAresearch
    GTX 660 Ti versus GTX 580
    150 watts versus 244 watts
    9.5 inches versus 10.5 inches
    1.5 GB memory versus 2 GB (standard config)
    $300 versus ???
    While I do not own and have test data on the GTX 660 TI it is what I would buy if I needed another graphics card.  Here is my current test data on an unpublished benchmark.  I would guess it might be better on this very intensive hardware accelerated  MPE test than my GTX 580.
    Message was edited by: Bill Gehrke
