Torrez1
Adobe Touch non responsive after ICS update on Xoom 2
Sep 8, 2012 4:56 PM
It seems after doing a update to ICS on my Motorola Xoom 2 has broken Adobe Touch the app is no longer responsive and will cause screen flickering when trying to select folders has anyone experience this issue.  Prior to this the Honeycomb OS worked well with Adobe Touch.
Also the latest update from Adobe Touch does not resolve the problem...
  • greule
    Oct 14, 2010
    Sep 10, 2012 1:18 AM   in reply to Torrez1
    I'm sorry to hear that you have trouble running PS Touch. Have you tried PS Touch after a reboot of your device.
    -Guido
  • greule
    Oct 14, 2010
    Sep 11, 2012 12:49 AM   in reply to Torrez1
    Have you tried to re-install PS Touch?  Are you experiencing the problems while being connected with your desktop computer?
    Guido
    Sep 14, 2012 10:07 AM   in reply to Torrez1
    Torrez1 wrote:
    Yes, I've tried numerous methods,  resetting, clearing cache etc...nothing seems to work, prior to getting my ICS update I had no issues when running HoneyComb after the update to Ice Cream 4.1 I notice PS Touch was not responding to touch commands for example the folders do not open then at times the app will flicker the screen and hitting the back button is useless to escape I have to tap the home button to get back to the home screen from there I go to settings to force close..any ideas ? Please let me know I purchased this app to tweak my graphics while on the go for my Android apps in development..
    Connected by Motorola
    SoftTech Apps
    Do understand it correctly:
    You have a device that was upgraded to ICS, you installed the never version of PS Touch and that's when you see the error?
    And you have rebooted the device at least once after installing PS Touch?
    Are you an application developer, if so: did you edit the development settings?
    Ignacio
    Sep 15, 2012 1:01 PM   in reply to Torrez1
    Using a Xoom (Wi-Fi model; 1st generation) here running Jelly Bean 4.1; no outstanding problems to report with PS Touch 1.3.
    Oct 28, 2012 12:18 PM   in reply to Torrez1
    I updated my Xoom2 to ICS 3 weeks ago.  Bought PS TOUCH yesterday.  Did all tutorials OK.  But cant open any photos as buttons dont respond.  Even tried going via Gallery to 'Share' - but PS TOUCH not listed - trick mised there as well I thought!
    Looks like it could be a great App!
    Oct 29, 2012 6:56 AM   in reply to Torrez1
    That workround is great!  I was scratching my head as to how to even open a photo.
    I was wondering if it had something to do with Xoom2 not able to open Flash (or is it Shockwave)
    Nov 9, 2012 2:40 AM   in reply to Torrez1
    Hi again,
    to be sure about having fixed this I need some steps on how to get to the flickering part.
    I'm using a Xoom2 a.k.a. Xyboard 10.1 with ICS and I do not see any flickering.
    I installed PS touch and upgraded it. Even tried resetting device and installing from scratch.
    As I understand it you see flickering right away on this devices?
    Which folders are you trying to select?
    Inside PS touch or on the device (images)?
    How many images do you have on the device?
    Are you trying to select images on a network?
    Are there any other applications that you use while working with PS Touch?
    Does a restart of the application help?
    Does a restart of the device help?
    Ignacio
    Nov 12, 2012 2:32 AM   in reply to Torrez1
    thanks for the reply, I do have some more questions inline though
    Torrez1 wrote:
    This seems to only happen after you enter PS for example once the app Splash screen is complete you have choice to open a existing file on the tablet
    Q: I assume you mean an existing PS Touch file (psdx)?
    now this next part is hit or miss
    Q: Can you please explain what you mean by hit or miss? Are you working with a stylus?
    try opening a existing graphics file on your tablet your system may seem like its locked up but if  you hit the Home key this will take you out to the main Home screen now re-enter the app by selecting the Icon,
    Q: What kind of graphics file is this? Does it always occur on the same kind of image, the same image? Are you inside of the existing PSDX file when doing this, .ie. Document mode?
    now try opening up a existing file again your screen may start flickering at this point..
    Q: Is this once more an existing PSDX file? Are you still in `Document mode? We need to know exactly where you are when you try to open the files.
    It seems the screen flicker happens only if you persist on trying to open a graphics file.
    Q: Does this mean that you cannot open any graphics files?
    Also my unit did not have this issue with Honeycomb only after my update to ICS 4.0 did I notice this problem.
    Xoom 2 or (Xyboard)
    ICS 4.0
    SoftTech
    tw39@webmail.us
    Ignacio
    Message was edited by: ibarrien
