Ok,
First off, i'm a student in said class. So i'm a begininer in In-design.
The problem i'm having is taking a text i typed out, for example, 2 capital JJ's ,out of the bounding box.
Or the text box. Anyways, I need help, and will be looking perodically for an answer.
The reason i want to take them out is so i can select them, and resize the J's , is there a way to do this.
Note i allready type out the body copy and caption. Any help would be appreciated.
Antisane
Not a lot...
Type must be either in a text frame or on a path. It can't exist in a vacuum, so to speak.
You can set the letter in its own frame, or on a path, then group with other frames, or anchor into the text flow in another frame (read about anchored objects in the help files). If the text befgins a paragraph you can style it as a drop cap, and of course you can select text anywhere and apply formatting, either as a character style or a local formatting override.
