bla124356
Dual EventListener problem
Sep 16, 2012 11:35 AM
Hello All,
I am new to these forums, and to ActionScript. I have come here to ask the following question, as I cannot find answers elsewhere.
I have the following short piece of as3 script:
import flash.display.Bitmap;
import flash.display.Loader;
import flash.events.Event;
import flash.net.URLLoader;
import flash.net.URLRequest;
var imageArray:Array = new Array();
var file:String = "xml/images.xml";
var loader:URLLoader = new URLLoader();
var request:URLRequest = new URLRequest(file);
loader.load(request);
loader.addEventListener(Event.COMPLETE, xmlReady);
function xmlReady(e:Event):void {
     var xmlData = XML(e.target.data);
     trace(xmlData);
     loadImages(xmlData);
     addEventListener(Event., traceArray);
function loadImages(images:XML):void {
     for (var i:Number = 0; i < images.length(); i++){
     var loader:Loader = new Loader();
     var request:URLRequest = new URLRequest(images.node[i].@f); // load element f (filepath/filename.jpg) out of a node element
     loader.contentLoaderInfo.addEventListener(Event.COMPLETE, imageReady);
function imageReady(e:Event):void {
     imageArray.push(e.target.content as Bitmap);
function traceArray():void{
     trace(imageArray.length);
The script does not throw any exceptions or warnings. Somehow, the script will only load one image into array imageArray, in stead of all (5) images specified in the XML document. I am certain that the XML is correct, because the XML object can load it's data and display it (i tested this). I suspect this problem has something to do with the asynchronous execution due to COMPLETE events being used. Can anyone point me in the right direction as to how this script may be rewritten in a better (functional) way and/or tell me a way to do load assets in as3 without using events? Or is this the only way possible in as3 in order to prevent browser freezes?
With regards,
bla124356
    Sep 16, 2012 11:59 AM   in reply to bla124356
    1. What event are listening to in the line addEventListener(Event., traceArray);?
    2. What do you see in traces:
            trace(images.node[i].@f);
    3. All listeners MUST BE ADDED BEFORE load is called. In local environments it is so fast that load may be complete before Flash hears the event listener to which is added.
    So you code should be something like this
    import flash.display.LoaderInfo;
        trace(xmlData);
        addEventListener(Event.ENTER_FRAME, traceArray);
        var loader:Loader;
        for (var i:int = 0; i < images.length(); i++)
            loader = new Loader();
            loader.load(new URLRequest(images.node[i].@f));
        LoaderInfo(e.target).removeEventListener(Event.COMPLETE, imageReady);
    Sep 16, 2012 12:11 PM   in reply to bla124356
    In you original code there is no Event type specified when you add event listener in xmlReady() function.
    Sep 16, 2012 12:18 PM   in reply to bla124356
    What do you see in traces output in this funcion?
    Sep 16, 2012 1:03 PM   in reply to bla124356
    You don't read nodes properly.
    Loop must be:
    for (var i:int = 0; i < images.node.length(); i++)
    not
    Sep 16, 2012 1:09 PM   in reply to bla124356
    You don't have to use for loop. Use for...each loop - it is faster:
        var loader:Loader;
        for each (var node:XML in images.node)
            trace(node.@f);
            loader.load(new URLRequest(node.@f));
    Sep 17, 2012 4:41 AM   in reply to bla124356
    I think it should be mentioned you could've, and probably should've, been using an XMLList object - it is what has the length() method and makes iterating chunks of XML easy.
    So, in your xmlReady function:
              var xmlData:XML = new XML(e.target.data);
              trace(xmlData);
              var nodeList:XMLList = xmlData.node;
              trace(nodeList.length()); //5
              trace(nodeList[0].@f); //images/1.jpg
