BenCotter
Photoshop worked until I restarted my computer, now it only works in safe mode.
Sep 15, 2012 3:02 PM
Tags: #photoshop #working #computer #i #cs6 #stopped #when #restarted
I installed photoshop and it worked fine but after restarting my computer it wont open and gives me the "Windows cannot access the specidied device,path, or file. You may not have the appropriate permissions to access the item" The only way i have got on photoshop since is on safe mode or by completely reinstalling photohop until i restart my computer again. Is there anything wrong, I don't know if AVG is blocking something or what... What should i do?
Replies 1 2 Previous Next
    Sep 16, 2012 10:02 AM   in reply to BenCotter
    It sounds like something that is loading in Regular Mode is getting in the way.
    When something works one day, but not the next, then something has changed. The task, is to find out what has changed.
    1. Have you installed any new hardware?
    2. Have you installed any new software?
    3. Have you made any system changes?
    Since you CAN run PS in Safe Mode, here are some thoughts (Windows):
    • Create a new System Restore Point for now, then boot to Safe Mode. Choose System Restore, and choose a System Restore Point from when things DID work correctly, and reboot, when directed. Test. At the worst, you have only wasted a few minutes, since you have your System Restore Point for today.
    • Open MSCONFIG [Edited to correct command] and look in the Startup and Services Tabs. Do you see anything, that is not necessary? If so, uncheck those, reboot (do NOT chose "Do not show this screen again," or similar syntax, and test everything. At the very worst, you just reboot, and at that information dialog, go in and recheck the Startup programs, or Services, that you unchecked before.
    • Go to Event Viewer, and look for any error, or warning messages in Applications and System, and if any have links, follow them. Most will likely be just bunches of code, and even some of the links might be only code, but maybe not - they might hold clues as to what is happening, when PS fails to launch.
    Good luck,
    Hunt
    [Edited to correct typo in the MSCONFIG command]
    Message was edited by: Bill Hunt
    Sep 15, 2012 3:52 PM   in reply to BenCotter
    Then I would look into the other suggestions, regarding the Startup and Services that are loading, and also the Event Viewer for error, or warning messages in Applications, or System.
    Good luck,
    Hunt
    Sep 16, 2012 3:11 AM   in reply to BenCotter
    Here is a suggestion that may help sort out if something is interfearing.
    open a command prompt and type MSCONFIG  (Bill had the right idea but the wrong command)
    A window will open.
    click on the Start Up tab
    choose the disable all button (don't worry you can re-enable everything back, this is just to get them out of the way for now)
    Hit apply and reboot your system.
    You will get asked if you want to open msconfig again on reboot you can choose no for now.
    see if you still have the issue.
    If not then start re-enabling apps till you find the problem child.
    Sep 16, 2012 7:29 AM   in reply to BenCotter
    Ok well lets get some more information about your install and we can look ad see whats up from there.
    First get it to a point Photoshop will work. then go to help>system info. A window will pop up copy that and paste it here in this thread. once we can look at that we can see if something is weird.
    Did you install it into a network drive or anything funky like that ?
    Sep 16, 2012 12:54 PM   in reply to Joprysko
    You are correct! I mis-typed the command. Duh!
    I have edited that reply, to make the correction that you so kindly pointed out.
    Thanks for that correction.
    Hunt
    Sep 16, 2012 12:54 PM   in reply to Bill Hunt
    The message suggests appropriate permissions. I would try to open PS using elevated command:
    Rt Click PS Icon, find "Run as Administrator" and see if that works. If it does, you need to give the entity opening PS Administrator permission.
    So far as AVG blocking, I doubt it but you can disable it then try again. To be safe disabling AVG, disconnect from the internet first. If it does work, you need to ask AVG about the problem as well.
    Sep 16, 2012 2:46 PM   in reply to BenCotter
    You potentually have a failing hard drive.
    One thing you may want to do is do a scan disk.
    click start>Computer
    Right click on C drive and choose properties
    Choose the tools tab
    click Check Now
    Leave the Automatic Fix checked but do not check the scan and attempt recovery of bad sectors
    It will basicly say it cant do that unless it reboots do you want to schedule it. choose YES
    When you reboot your PC the next time it will come up with a black screen and check your hard drive for problems and hopefully repair them for you.
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 9:12 AM   in reply to BenCotter
    One thing I can see right off the bat is that you need the 13.0.1 update.
    Choose Help - Updates to get you started.  If that doesn't work it could be another clue why things aren't functioning properly for you.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 9:14 AM   in reply to BenCotter
    Also, your ATI display driver is 2 years out of date.  I'm not sure what the newest for your system is, but seek out the latest version available from your computer manufacturer or the AMD web site.
    -Noel
    Sep 17, 2012 9:16 AM   in reply to Noel Carboni
    I would be surprised if that got him out of the mess.
    I hope it does.
    Sep 17, 2012 9:34 AM   in reply to BenCotter
    One thing I see is for some reason its truncating your User name and it really should not be in windows 7.
    Temporary file path: C:\Users\BENAND~1\AppData\Local\Temp\
    I am not on a PC with photoshop on it at the moment but you may want to try to point your temporary directory into something simple like c:\temp and see if that helps.
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 10:14 AM   in reply to BenCotter
    I doubt that the TEMP path is the problem, but it can't hurt to make it shorter and simpler.
    Excerpted from my Configure the Windows 7 "To Work" Options book:
    Set Up a Short, Simple TEMP Folder Path
    Many applications use temporary storage on your hard drive, and it's a long-standing convention to use the value of the TEMP or TMP environment variable to locate a suitable folder for temporary file storage.
    Windows installation sets up a TEMP area for you, but as time has gone on, its location has evolved.  With Windows 7 it defaults to a folder deep under your Users folder, and since it's kind of long, and usernames can have spaces in them, you might end up with a temporary file path that some applications simply can't deal with.
    To ensure the greatest likelihood of all your applications being able to use your TEMP variable and do proper temporary file storage without problems:
             Create folder: C:\TEMP
             In Windows Explorer, right-click C:\TEMP, choose Properties, Security tab, and grant Full Control permissions for all intended users.
             Right-click Computer, choose Properties.
             Click the Advanced System Settings link.
             Click the [ Environment Variables... ] button.
             Change user TEMP and TMP variables to: C:\TEMP
    -Noel
    Sep 17, 2012 10:21 AM   in reply to Noel Carboni
    I think you misunderstood Noel.
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      Startup, 455.1G, 301.6G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
    The temp here would be the scratch disk directory... I think, am I wrong?
    To change that its open Photoshop then go Edit > Preferences > Performance
    A window should pop up where you see a section called scratch disk. Point that at c:\temp
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 10:28 AM   in reply to Joprysko
    You can only point Scratch at a disk, not a folder.
    The TEMP folder will be used if the Scratch disk is the startup volume.  So my advice is exactly on point.
    -Noel
    Sep 17, 2012 10:30 AM   in reply to Noel Carboni
    Ohh didn't know that. Good information.
    Sep 17, 2012 10:57 AM   in reply to Joprysko
    I don't think that's correct. The scratch in any case needs to be on a separate drive from C but in any case, C is the default drive when Photoshop first starts up after installation. Since I never engage C for scratch it's not checked in the drive sequence so I don't know where PS put it on C. The optional drives are  entirely used unless you partition it and assign the partition to scratch.
    Tip: If you partition a drive for scratch (other than C), make sure it's the first partition on that drive as it will be the fastest.
    Message was edited by: Hudechrome
    Sep 17, 2012 10:35 AM   in reply to Noel Carboni
    Looks like I'm wrong about C and scratch.
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 10:38 AM   in reply to Hudechrome
    It makes sense to use C: for scratch if you have a fast disk array.
    -Noel
    Sep 17, 2012 10:41 AM   in reply to Noel Carboni
    I still would likely put the array on it's own drive. After all there would not be any possible conflict with paging.
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 10:45 AM   in reply to Hudechrome
    Nope.  Paging and Photoshop scratch access can coexist no problem if there is essentially no seek time, which is true of any SSD.  The rules we all have come to know are changing as the technology changes.  I can put up test results proving this if you'd like to see them.
    Another good reason for using the startup volume for scratch would be if you don't actually have more than one volume.    And note that partitioning a disk just to separate the startup volume from Photoshop scratch is a supremely bad idea.
    -Noel
    Sep 17, 2012 10:57 AM   in reply to Hudechrome
    Yes Normally you would prefur it on a seperate drive, but thats not always an option for some people.
    I think the issue here is the truncated file path, Windows 7 64 bit would not normally truncate a file path unless the path was over 1024 characters long. so the temp path just seems hinky to me.
    If that path is not valid, guess what message they would get.
    Sep 17, 2012 10:58 AM   in reply to Noel Carboni
    I edited my comment to reflect the caution about C
    Sep 17, 2012 11:00 AM   in reply to Joprysko
    I know, but also, some folks don't necessarily know that an option exists to install a separate drive and dedicate it to scratch, partitioned if you choose.
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 11:01 AM   in reply to Joprysko
    That's just a short pathname (the technical term Microsoft uses is actually called "mangled").  It's normal for software using ancient code internally that's limited to 8.3 filenames, though I'm not sure why Photoshop would be showing that.
    It's actually possible to turn off 8.3 filename support entirely in NTFS to gain a little efficiency (I do that, and I've documented how in my book).  Photoshop seems to have no problems with that, but in my own case I have a short username and no spaces in it, and even beyond that I've taken my own advice and set up C:\TEMP as my temporary folder.
    -Noel
    Sep 17, 2012 11:46 AM   in reply to Noel Carboni
  • Noel Carboni
    Dec 23, 2006
    Sep 17, 2012 11:51 AM   in reply to Hudechrome
    Whenever you are logged-in, a User variable will override a System variable (except for PATH, which combines), so you only need to change the User variable.
    In fact it's preferable to change only the User variables, as Windows does use TEMP for a few things before you log in, and keeping those things completely separate from the files you and your applications create is generally good.
    -Noel
    Sep 17, 2012 11:54 AM   in reply to Noel Carboni
    Sep 18, 2012 8:57 AM   in reply to BenCotter
    Ben, please post a screen shot of your System Properties.
    Sep 18, 2012 9:21 AM   in reply to BenCotter
    Thanks. Noel would hopefully have an answer to the path not there.
    I did check another machine here and it also has no User Variables path, however it is an XP machine. It runs fine.
    Sep 18, 2012 10:19 AM   in reply to BenCotter
    User variables are the two top ones.
    Just edit those and point it at the c:\temp
    Make sure you have a c:\temp as well
  • Noel Carboni
    Dec 23, 2006
    Sep 18, 2012 10:55 AM   in reply to BenCotter
    BenCotter wrote:
    My user variables dont have a PATH could that be a problem? also what should i set that? if that could be a problem. also my TEMP and TMP are the same (%USERPROFILE%\AppData\Local\Temp
    No, that's not a problem unless there are things you need in the path that aren't there.  You just don't have any user-specific path definitions.
    -Noel
1 2 Previous Next
