I installed photoshop and it worked fine but after restarting my computer it wont open and gives me the "Windows cannot access the specidied device,path, or file. You may not have the appropriate permissions to access the item" The only way i have got on photoshop since is on safe mode or by completely reinstalling photohop until i restart my computer again. Is there anything wrong, I don't know if AVG is blocking something or what... What should i do?
It sounds like something that is loading in Regular Mode is getting in the way.
When something works one day, but not the next, then something has changed. The task, is to find out what has changed.
Since you CAN run PS in Safe Mode, here are some thoughts (Windows):
Good luck,
Hunt
[Edited to correct typo in the MSCONFIG command]
Message was edited by: Bill Hunt
I installed it last night and it worked fine, until I booted up my computer today and it wasn't for working so I have only used it once so there has been no computer updates since I have installed it except the turning off of the computer and the turning on of the computer. Also when I first installed it before restart it worked fine on normal mode.
Here is a suggestion that may help sort out if something is interfearing.
open a command prompt and type MSCONFIG (Bill had the right idea but the wrong command)
A window will open.
click on the Start Up tab
choose the disable all button (don't worry you can re-enable everything back, this is just to get them out of the way for now)
Hit apply and reboot your system.
You will get asked if you want to open msconfig again on reboot you can choose no for now.
see if you still have the issue.
If not then start re-enabling apps till you find the problem child.
Ok well lets get some more information about your install and we can look ad see whats up from there.
First get it to a point Photoshop will work. then go to help>system info. A window will pop up copy that and paste it here in this thread. once we can look at that we can see if something is weird.
Did you install it into a network drive or anything funky like that ?
The message suggests appropriate permissions. I would try to open PS using elevated command:
Rt Click PS Icon, find "Run as Administrator" and see if that works. If it does, you need to give the entity opening PS Administrator permission.
So far as AVG blocking, I doubt it but you can disable it then try again. To be safe disabling AVG, disconnect from the internet first. If it does work, you need to ask AVG about the problem as well.
I have tried to run as administrator before and no luck, I have also checked my account has permissions in the properties file. I have not had time to reinstall photoshop today so I can't get the information, I will do that tomorrow also installed photoshop on my c drive (I don't have any others that I know of, I'm not a computer expert )
You potentually have a failing hard drive.
One thing you may want to do is do a scan disk.
click start>Computer
Right click on C drive and choose properties
Choose the tools tab
click Check Now
Leave the Automatic Fix checked but do not check the scan and attempt recovery of bad sectors
It will basicly say it cant do that unless it reboots do you want to schedule it. choose YES
When you reboot your PC the next time it will come up with a black screen and check your hard drive for problems and hopefully repair them for you.
Here is the system info, I havn't had time to scan disk yet.
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Operating System: Windows 7 64-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:5, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2128 MHz
Built-in memory: 3950 MB
Free memory: 1460 MB
Memory available to Photoshop: 3358 MB
Memory used by Photoshop: 60 %
Image tile size: 128K
Image cache levels: 4
The GPU Sniffer crashed on 15/09/2012 at 20:10:42
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Mobility Radeon HD 5145
Display: 1
Display Bounds:= top: 0, left: 0, bottom: 900, right: 1600
Video Card Number: 1
Video Card: ATI Mobility Radeon HD 5145
OpenCL Unavailable
Driver Version: 8.723.8.2000
Driver Date: 20100920000000.000000-000
Video Card Driver: atiu9p64.dll,aticfx64.dll,atiu9pag,aticfx32,atiumd64.dll,atidxx64.dll ,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Video Mode: 1600 x 900 x 4294967296 colors
Video Card Caption: ATI Mobility Radeon HD 5145
Video Card Memory: 512 MB
Video Rect Texture Size: 8192
Serial number: Tryout Version
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\BENAND~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 455.1G, 301.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2012/01/18-15:07:40 66.492997 66.492997
adbeape.dll Adobe APE 2012/01/25-10:04:55 66.1025012 66.1025012
AdobeLinguistic.dll Adobe Linguisitc Library 6.0.0
AdobeOwl.dll Adobe Owl 2012/02/09-16:00:02 4.0.93 66.496052
AdobePDFL.dll PDFL 2011/12/12-16:12:37 66.419471 66.419471
AdobePIP.dll Adobe Product Improvement Program 6.0.0.1654
AdobeXMP.dll Adobe XMP Core 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPFiles.dll Adobe XMP Files 2012/02/06-14:56:27 66.145661 66.145661
AdobeXMPScript.dll Adobe XMP Script 2012/02/06-14:56:27 66.145661 66.145661
adobe_caps.dll Adobe CAPS 6,0,29,0
AGM.dll AGM 2012/01/18-15:07:40 66.492997 66.492997
ahclient.dll AdobeHelp Dynamic Link Library 1,7,0,56
aif_core.dll AIF 3.0 62.490293
aif_ocl.dll AIF 3.0 62.490293
aif_ogl.dll AIF 3.0 62.490293
amtlib.dll AMTLib (64 Bit) 6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00) 1.000000
ARE.dll ARE 2012/01/18-15:07:40 66.492997 66.492997
AXE8SharedExpat.dll AXE8SharedExpat 2011/12/16-15:10:49 66.26830 66.26830
AXEDOMCore.dll AXEDOMCore 2011/12/16-15:10:49 66.26830 66.26830
Bib.dll BIB 2012/01/18-15:07:40 66.492997 66.492997
BIBUtils.dll BIBUtils 2012/01/18-15:07:40 66.492997 66.492997
boost_date_time.dll DVA Product 6.0.0
boost_signals.dll DVA Product 6.0.0
boost_system.dll DVA Product 6.0.0
boost_threads.dll DVA Product 6.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.0.5.19287 2.0.5.19287
CoolType.dll CoolType 2012/01/18-15:07:40 66.492997 66.492997
data_flow.dll AIF 3.0 62.490293
dvaaudiodevice.dll DVA Product 6.0.0
dvacore.dll DVA Product 6.0.0
dvamarshal.dll DVA Product 6.0.0
dvamediatypes.dll DVA Product 6.0.0
dvaplayer.dll DVA Product 6.0.0
dvatransport.dll DVA Product 6.0.0
dvaunittesting.dll DVA Product 6.0.0
dynamiclink.dll DVA Product 6.0.0
ExtendScript.dll ExtendScript 2011/12/14-15:08:46 66.490082 66.490082
FileInfo.dll Adobe XMP FileInfo 2012/01/17-15:11:19 66.145433 66.145433
filter_graph.dll AIF 3.0 62.490293
hydra_filters.dll AIF 3.0 62.490293
icucnv40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
icudt40.dll International Components for Unicode 2011/11/15-16:30:22 Build gtlib_3.0.16615
image_compiler.dll AIF 3.0 62.490293
image_flow.dll AIF 3.0 62.490293
image_runtime.dll AIF 3.0 62.490293
JP2KLib.dll JP2KLib 2011/12/12-16:12:37 66.236923 66.236923
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 10.0
LogSession.dll LogSession 2.1.2.1640
mediacoreif.dll DVA Product 6.0.0
MPS.dll MPS 2012/02/03-10:33:13 66.495174 66.495174
msvcm80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcm90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcp100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcp80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcp90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
msvcr100.dll Microsoft® Visual Studio® 2010 10.00.40219.1
msvcr80.dll Microsoft® Visual Studio® 2005 8.00.50727.6195
msvcr90.dll Microsoft® Visual Studio® 2008 9.00.30729.1
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CS6 CS6
Plugin.dll Adobe Photoshop CS6 CS6
PlugPlug.dll Adobe(R) CSXS PlugPlug Standard Dll (64 bit) 3.0.0.383
PSArt.dll Adobe Photoshop CS6 CS6
PSViews.dll Adobe Photoshop CS6 CS6
SCCore.dll ScCore 2011/12/14-15:08:46 66.490082 66.490082
ScriptUIFlex.dll ScriptUIFlex 2011/12/14-15:08:46 66.490082 66.490082
tbb.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 3, 0, 2010, 0406
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 6.0.0.24
WRServices.dll WRServices Friday January 27 2012 13:22:12 Build 0.17112 0.17112
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Accented Edges 13.0
Adaptive Wide Angle 13.0
ADM 3.11x01
Angled Strokes 13.0
Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Bas Relief 13.0
BMP 13.0
Camera Raw 7.0
Chalk & Charcoal 13.0
Charcoal 13.0
Chrome 13.0
Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Color Halftone 13.0
Colored Pencil 13.0
CompuServe GIF 13.0
Conté Crayon 13.0
Craquelure 13.0
Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Crop and Straighten Photos Filter 13.0
Crosshatch 13.0
Crystallize 13.0
Cutout 13.0
Dark Strokes 13.0
De-Interlace 13.0
Dicom 13.0
Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Diffuse Glow 13.0
Displace 13.0
Dry Brush 13.0
Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Embed Watermark 4.0
Entropy 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Extrude 13.0
FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Fibers 13.0
Film Grain 13.0
Filter Gallery 13.0
Flash 3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Fresco 13.0
Glass 13.0
Glowing Edges 13.0
Google Earth 4 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Grain 13.0
Graphic Pen 13.0
Halftone Pattern 13.0
HDRMergeUI 13.0
IFF Format 13.0
Ink Outlines 13.0
JPEG 2000 13.0
Kurtosis 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Lens Blur 13.0
Lens Correction 13.0
Lens Flare 13.0
Liquify 13.0
Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Maximum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Mean 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Median 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Mezzotint 13.0
Minimum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Mosaic Tiles 13.0
Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Neon Glow 13.0
Note Paper 13.0
NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Ocean Ripple 13.0
Oil Paint 13.0
OpenEXR 13.0
Paint Daubs 13.0
Palette Knife 13.0
Patchwork 13.0
Paths to Illustrator 13.0
PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Photocopy 13.0
Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Pinch 13.0
Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Plaster 13.0
Plastic Wrap 13.0
PNG 13.0
Pointillize 13.0
Polar Coordinates 13.0
Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Poster Edges 13.0
Radial Blur 13.0
Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Range 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Read Watermark 4.0
Reticulation 13.0
Ripple 13.0
Rough Pastels 13.0
Save for Web 13.0
ScriptingSupport 13.0
Shear 13.0
Skewness 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Smart Blur 13.0
Smudge Stick 13.0
Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Spatter 13.0
Spherize 13.0
Sponge 13.0
Sprayed Strokes 13.0
Stained Glass 13.0
Stamp 13.0
Standard Deviation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Sumi-e 13.0
Summation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Targa 13.0
Texturizer 13.0
Tiles 13.0
Torn Edges 13.0
Twirl 13.0
U3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Underpainting 13.0
Vanishing Point 13.0
Variance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Water Paper 13.0
Watercolor 13.0
Wave 13.0
Wavefront|OBJ 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
Wind 13.0
Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
ZigZag 13.0
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash: NONE
Installed TWAIN devices: NONE
Thanks, I will scan disk when I have time!
One thing I see is for some reason its truncating your User name and it really should not be in windows 7.
I am not on a PC with photoshop on it at the moment but you may want to try to point your temporary directory into something simple like c:\temp and see if that helps.
I doubt that the TEMP path is the problem, but it can't hurt to make it shorter and simpler.
Excerpted from my Configure the Windows 7 "To Work" Options book:
Set Up a Short, Simple TEMP Folder Path
Many applications use temporary storage on your hard drive, and it's a long-standing convention to use the value of the TEMP or TMP environment variable to locate a suitable folder for temporary file storage.
Windows installation sets up a TEMP area for you, but as time has gone on, its location has evolved. With Windows 7 it defaults to a folder deep under your Users folder, and since it's kind of long, and usernames can have spaces in them, you might end up with a temporary file path that some applications simply can't deal with.
To ensure the greatest likelihood of all your applications being able to use your TEMP variable and do proper temporary file storage without problems:
• Create folder: C:\TEMP
• In Windows Explorer, right-click C:\TEMP, choose Properties, Security tab, and grant Full Control permissions for all intended users.
• Right-click Computer, choose Properties.
• Click the Advanced System Settings link.
• Click the [ Environment Variables... ] button.
• Change user TEMP and TMP variables to: C:\TEMP
-Noel
Scratch volume(s):
The temp here would be the scratch disk directory... I think, am I wrong?
To change that its open Photoshop then go Edit > Preferences > Performance
A window should pop up where you see a section called scratch disk. Point that at c:\temp
I don't think that's correct. The scratch in any case needs to be on a separate drive from C but in any case, C is the default drive when Photoshop first starts up after installation. Since I never engage C for scratch it's not checked in the drive sequence so I don't know where PS put it on C. The optional drives are entirely used unless you partition it and assign the partition to scratch.
Tip: If you partition a drive for scratch (other than C), make sure it's the first partition on that drive as it will be the fastest.
Message was edited by: Hudechrome
Nope. Paging and Photoshop scratch access can coexist no problem if there is essentially no seek time, which is true of any SSD. The rules we all have come to know are changing as the technology changes. I can put up test results proving this if you'd like to see them.
Another good reason for using the startup volume for scratch would be if you don't actually have more than one volume.
And note that partitioning a disk just to separate the startup volume from Photoshop scratch is a supremely bad idea.
-Noel
Yes Normally you would prefur it on a seperate drive, but thats not always an option for some people.
I think the issue here is the truncated file path, Windows 7 64 bit would not normally truncate a file path unless the path was over 1024 characters long. so the temp path just seems hinky to me.
If that path is not valid, guess what message they would get.
That's just a short pathname (the technical term Microsoft uses is actually called "mangled"). It's normal for software using ancient code internally that's limited to 8.3 filenames, though I'm not sure why Photoshop would be showing that.
It's actually possible to turn off 8.3 filename support entirely in NTFS to gain a little efficiency (I do that, and I've documented how in my book). Photoshop seems to have no problems with that, but in my own case I have a short username and no spaces in it, and even beyond that I've taken my own advice and set up C:\TEMP as my temporary folder.
-Noel
Whenever you are logged-in, a User variable will override a System variable (except for PATH, which combines), so you only need to change the User variable.
In fact it's preferable to change only the User variables, as Windows does use TEMP for a few things before you log in, and keeping those things completely separate from the files you and your applications create is generally good.
-Noel
BenCotter wrote:
My user variables dont have a PATH could that be a problem? also what should i set that? if that could be a problem. also my TEMP and TMP are the same (%USERPROFILE%\AppData\Local\Temp
No, that's not a problem unless there are things you need in the path that aren't there. You just don't have any user-specific path definitions.
-Noel
