AS3 bargraph tutorial without XML
Sep 18, 2012 2:45 PM
Finishing up a project and need to add a basic vertical bargraph to visually display 2 score results. Have extensively searched online and have only found AS3 combined with XML, which for me with limited scripting skill is difficult to separate out in order to just have AS3.
The bargraph would have only 2 vertical columns that can rise up proportionate to the positive score (s) and 2 vertical column (mirror image of the up columns) that would become visible only if there is a negative score (s), and starting at mid-screen, go down proportionate to the negative score (s).
Scores are available in the project as 2 variables.
Has anyone seen a bargraph tutorial like this in AS3? (Need to create a basic building block to get started, then can adapt, add to from there.)
Any help appreciated.
  • kglad
    Jul 21, 2002
    Sep 18, 2012 3:03 PM   in reply to saratogacoach
    there's not enough substance to merit a tutorial.  you would simply y-scale two movieclips (with top reg point) based on those two scores.
  • kglad
    Jul 21, 2002
    Sep 18, 2012 4:47 PM   in reply to saratogacoach
    my bad.  the reg point should be at the bottom.  if a scaleY of 1 corresponds to a score of 100, you can then use:
    import fl.transitions.Tween;
    import fl.transitions.easing.Strong;
    var m:Number;
    var b:Number;
    var score:int = 50;
    paramF(0,0,100,1);
    var t:Tween = new Tween(mc, "scaleY", Strong.easeOut, 0, m*score+b, 2, true);
    function paramF(x1:Number,y1:Number,x2:Number,y2:Number){
        m = (y1-y2)/(x1-x2);
        b = y1-m*x1;
  • kglad
    Jul 21, 2002
    Sep 18, 2012 10:55 PM   in reply to saratogacoach
    you're welcome.
  • kglad
    Jul 21, 2002
    Sep 20, 2012 2:34 PM   in reply to saratogacoach
    what's Dprime?
  • kglad
    Jul 21, 2002
    Sep 20, 2012 9:17 PM   in reply to saratogacoach
    so Dprime1 and Dprime2 are variables with values between -1 and 1, correct?
    if yes, use:
    var m:Number;
    var b:Number;
    paramF(-1,-1,1,1);
    var t1:Tween = new Tween(bar1_mc, "scaleY", Strong.easeOut, 0, m*DPrime1+b, 2, true);  // where bar1_mc is your bar display for DPrime1
    var t2:Tween = new Tween(bar2_mc, "scaleY", Strong.easeOut, 0, m*DPrime2+b, 2, true);  // where bar2_mc is your bar display for DPrime2
        b = y1-m*x1;
  • kglad
    Jul 21, 2002
    Sep 21, 2012 6:50 AM   in reply to saratogacoach
    yes.  you just need to determine what is the minimum value (that will be displayed as a bar with scaleY=-1) and the maximum value (that will be displayed as a bar with scaleY=1.  then use those numbers in paramF:
    paramF(minimum,-1,maximum,1);
  • kglad
    Jul 21, 2002
    Sep 21, 2012 8:19 AM   in reply to saratogacoach
    nothing needs to be re-written.  just use paramF() twice if you want to apply different scaling to the two bars:
    var m:Number;
    var b:Number;
    paramF(dprime1_min,-1,dprime1_max,1);
    paramF(dprime2_min,-1,dprime2_max,1);
        b = y1-m*x1;
  • kglad
    Jul 21, 2002
    Sep 21, 2012 9:07 AM   in reply to saratogacoach
    so, if dprime1 is equal to the mean you want the scale to be zero?  ie, no bar seen??
  • kglad
    Jul 21, 2002
    Sep 21, 2012 10:59 AM   in reply to saratogacoach
    then the code i suggested should work.  you're normaling your variable so the min=-max and therefore if your variable is equal to the mean, scale will be zero.
  • kglad
    Jul 21, 2002
    Sep 21, 2012 12:29 PM   in reply to saratogacoach
    use:
    paramF(mean-3*sd,-1,mean+3*sd,1);
  • kglad
    Jul 21, 2002
    Sep 21, 2012 2:21 PM   in reply to saratogacoach
    no problem (and, you're welcome).
  • kglad
    Jul 21, 2002
    Sep 21, 2012 2:28 PM   in reply to saratogacoach
    yes, use:
    paramF(mean-3*sd,1,mean+3*sd,-1);
  • kglad
    Jul 21, 2002
    Sep 21, 2012 2:57 PM   in reply to saratogacoach
    you're welcome.
