Hello I was wondering if it is posible to create numbered/bulleted text in photoshop, with indentation as it is done in MS Word.
I tried the paragraph palette but I cannot do indentation per single line:
I wanted to do something like this:
Just something like the text that appears to the left of the image of that house. The image displayed shows the various components of a water distribution system for a single home which collects rain water and deposits it in a storage tank. The only text that I have written in photoshop is the title and the web address.
This is for some course notes but I wanted to replace the original scanned text (which is in dark blue) for some photoshop text in black colour. But I want the text with the same indent format. Can this be done in Photoshop?
Could anyone please help?
Thank you for reading my inquiry.
Photoshop can't automatically generate a numbered list. As stalion_two mentioned, you're probably better off using a word processor.
Try entering a negative value for the first line indentation as shown below. You may have to adjust this number according to which font size/type/weight you're using. You can see that it replicated the indentation in the screenshot you provided.
Of course you can use a pair of pliers to drive a nail, but it's the wrong tool for the job.
Photoshop is not a page layout application nor a word processor. In this case Photoshop is the wrong tool for the job.
Oops the image did not upload properly.
Here is my message again:
Thank you very much Kendallplant,
I will try your solution.
But would that work if the whole 3 points where in a single text box?
Or, would I have to draw a single text box per point?
Just curious.
Apart from that, you can try InDesign for this. You're only placing a house image and adding text to it. You could use Photoshop for more complex purposes. InDesign can do this for you very easily. Have you tried it out?
http://help.adobe.com/en_US/indesign/cs/using/WSa285fff53dea4f8617383751001ea8cb3f-6da6a.html
You can place all the text in a single text box 🙂
I'm not sure if this is the kind of effect you're looking for, but you could try this indentation trick: http://www.ianhoar.com/2008/04/12/photoshop-tip-3-bullets-in-photoshop/
