I'm trying to File > Save As an Adobe Photoshop CS6 PDF and then be able to open it and edit the text in Adobe Acrobat X.
Whenever I attempt to edit the text it is a raster image and it doesnt matter what I do in the photoshop pdf settings.
I want to be able to do this so that the text is able to be searched by google / search engines when I make the PDF available online.
-Steve.
From: http://creativebits.org/photoshop/preserving_vector_text_from_photosho p
Photoshop is a superb program. But a page layout app it is not. Fuzzy bitmapped 72 dpi text isn't my idea of a good time. However there is a way that a text heavy layout can be done in Photoshop and sent to a prepress tech without them burning you in effigy.
1. Create the document.
2. Add in your text making sure not to rasterize it.
3. Save it as a "Photoshop PDF"
4. In the PDF file format options make sure to check "Include Vector Data" and Embed fonts.
5. This will produce a PDF with embedded fonts that any prepress monkey worth his salt will embrace with open arms.
Also: If you want to maintain text, you must not use any faux-stuff, like "faux bold" and/or "faux italic".
I can't help you with the embedded hot link, though. Could be a question for the Acrobat forum.
I just finished a lesson on editing in Acrobat X.
Basic advice: Edit the document in the source program. A Photoshop PDF is editable in Photoshop. Acrobat cannot edit a Photoshop PDF.
Your text should still be searchable. I did a basic word search and an advanced search on a Photoshop PDF I created when I opened it in Acrobat X.
Gene
Hi all,
The short answer is you should never depend on preserving searchable or editable Acrobat text when you save to PDF from Photoshop. It is confusing because sometimes your text will be preserved, and other times it won't.
In simple terms, Photoshop always strives to preserve image integrity, even at the expense of preserving text information. This has a lot to do with the layering model in Photoshop and the composite image that Photoshop must generate for the PDF. If a text layer is (or even may be) obscured by other layers above it, the text will be rasterized or converted to clipping paths. The reasons and specific details about this get a bit complicated, so I won't go into them here.
In practice, this means that in most moderately complicated, multi-layer Photoshop images, text will not survive into a PDF as searchable or editable Acrobat text. The cases where it will be preserved tend to be very simple, e.g. black text on a white background.
That said, text will survive into any PDF as editable Photoshop text, if you have selected "Preserve Photoshop Editing Capability" when saving the PDF. In that situation, the entire Photoshop document, with all its layers and other information, is stored as private data inside the PDF in a format readable only by Photoshop.
Hope this helps,
Paul
There have been no changes between CS 5.5 and CS 6 related to this, so I'm not sure what you're experiencing. Are you referring to vector data when you re-open the PDF in Photoshop? If so, then it's probably because you don't have "Preserve Photoshop Editing Capability" checked in the PDF settings dialog.
That what I did by using CS6 and it worked for me. Hope it helps you too
OR Select folder > Layer > Rasterize > Layer
Now I have only one Background Layer (Graphics) and a text folder
Choose settings-
Then open in Acrobat Reader and do the text changes.
