TinRobot44
Selecting with colour range doesn't work properly
Sep 18, 2012 10:13 PM
Tags: #color #range
Well, at least to me it doesn't work properly.  If I have elements on seperate levels and I use the colour range option to select the area, it works on all the levels, not just the level I have selected.  That's not what I want!  I only want it to select the colour range on that one level.  The work around is to manually turn off other levels, but on a  file with lots of levels, that can be tedious.  Can this be avoided?  Incidentally, magic wand works only on the selected level, but not colour range (or color range, if you are American).
    Sep 18, 2012 10:25 PM   in reply to TinRobot44
    TinRobot44 wrote:
    …If I have elements on seperate levels and I use the colour range option to select the area, it works on all the levels, not just the level I have selected.  That's not what I want!  I only want it to select the colour range on that one level.…
    "Levels"?  Do you mean Layers?
    Sep 18, 2012 10:28 PM   in reply to TinRobot44
    If you do mean "layers", check your tool options in the Options Bar.  You may be set to select all layers.
    If everything else fails, you could make the unwanted levels temporarily invisible by toggling off the eye icon to the left in the Layers panel.
    Sep 18, 2012 11:51 PM   in reply to TinRobot44
    Hiding all other Layers can be done by alt-clicking the visibility icon in the Layers Panel.
    Sep 19, 2012 9:16 AM   in reply to TinRobot44
    Look in Options bar when using Color Range. You can limit the sampling to just the currently targeted layer, as shown below:
    Sep 19, 2012 10:08 AM   in reply to TinRobot44
    Aha! You are correct. Layers above the target layer are still being sampled when sampling is at "Current Layer".
    That has to be a bug. The Eye Dropper Tool itself does work correctly, though.
    I'm about to report another problem, so I'll report this one, too.
    Edit: Looking again, I don't think there is a bug.
    It seems to not be that the higher layer is seen when sampling "Current Layer", which is correct and the same as when the Eye Dropper Tool itself is use. However, the pixels of the visible composite are then evaluated to determine the regions to be selected. I guess that's correct behaviour and you will have to do the Alt-click on eye trick to completely ignore all other layers.
    Sep 19, 2012 10:19 AM   in reply to TinRobot44
    Not sure why you are getting a different result with your eye dropper.
    I am getting the same result as you. We are interpreting the program behaviour differently.
    Sep 19, 2012 11:57 AM   in reply to TinRobot44
    I think Color Range is designed to determine the selection from the pixels of the composite of visible layers that's being displayed in the document window. It employs Eye Dropper Tool as a sampler and uses whatever result is returned by EDT. The options in the bar are options of the EDT and have nothing to do with Color Range itself.
    Sep 19, 2012 12:16 PM   in reply to TinRobot44
    I agree that options in Color Range for the layers to be considered could be useful. Development resources are limited, though, and the design team probably considered the command as it is to be good enough to be useful, which it certainly is. Spending more resources on Color Range would mean sacrificing something else.
    Sep 19, 2012 2:06 PM   in reply to TinRobot44
    You keep on typing "levels" repeatedly, over and over, when you mean layers.
    That's confusing.  Levels are an entirely different thing in Photoshop.
