CS5.5 :: Web document :: default [Black] CMYK error
Sep 19, 2012 2:14 AM
If I change InDesigns default color swatches with NO doument open – f.i. by adding a cmyk Gray as a tint of [Black] –  than any new InDesign Web document does not contain RGB but CMYK swatches only, default [Black] included.
Unfortunately in such a documents' exported RGB PDF any black text appears "flickering", a PDF-check with Acrobats eye-dropper tool shows such pure black as multicolered, not plain – different to a cmyk pdf from that same document.
Though the JS script line
app.activeDocument.colors.everyItem().properties = {space:ColorSpace.RGB}
does switch the color space of any plain swatch from CMYK to RGB, unfortunately a documents default [Black] can not be altered from one color space to another.
I can repeat this unwanted behave of InDesign on a fresh app installation / after log-in as a new user on my computer: At first any Web document color swatch is defined as RGB, default [Black] included – as soon the default swatches set got altered (with no document open) any further new web document contains RGB swatches only.
I do appreciate any help to fix/avoid the occurence of default [Black] to be CMYK in a web document. – Or the confirmation that this is irrreparable in my document / a bug in CS55.
OSX 10.6.8 / CS5.5, 7.5.3.333
Thank you!,
- thomas
    Sep 19, 2012 3:55 AM   in reply to thomas olbrich
    Looks to me like a bug in CS5.5, and it doesn't appear to be happening in CS6. What happens if  ytou don't add the tint swatch as a default, but instead create a balnk web doc, add the swatch to that, and save as a template? You can then use the template as the basis for new files.
  • Rob Day
    Oct 16, 2007
    Sep 19, 2012 5:32 AM   in reply to thomas olbrich
    Have you tried setting the document intent to web (Document Setup>Intent)? The web intent changes default black to RGB.
    Sep 19, 2012 5:54 AM   in reply to Rob Day
    Rob, if you follow the steps outlined in CS5.5 in the original post and add the tint swatch as a default swatch before making a nee document, setting the intent to web fails to change the swatches. That seems to be a bug.
  • Rob Day
    Oct 16, 2007
    Sep 19, 2012 6:01 AM   in reply to Peter Spier
    Sorry read too fast.
    Sep 19, 2012 6:38 AM   in reply to Rob Day
    That's my excuse.
