i was trying to update my flash player because mozilla is starting to be unable to fully view some sites. i downloaded the installer but it wont start. i double clicked and nothing happened. nothing at all, not even an error message.
i also tried uninstalling flash and try again but still wont do a thing.
can someone help me with this?
This thread was started in 2012 for a totally different issue. I'm going to lock it at this point.
If you're experiencing similar issues and the advice above doesn't help you, please start a new thread, and provide some basic details, like those outlined here:
Could you please let us know your operating system and browser?
Sunil
i have the same problem with install_flashplayer11x32_mssd_aih.exe
im using firefox windows vista 32 bit
when i upgraded it it was crashing a few times a day i had to send crash report and reload
then it would completly stop working i would have to unstall it then reinstall it would kinda work again
yesterday i did the same thing after 2 days with no problems
now it downloads when i try to open the zip nothing happens
then i tried to download it with windows exploder and it has stoped working every page crashes
today i uninstalled firefox reinstalled it and no change
how can i fix this
http://www.adobe.com/support/flashplayer/downloads.html#fp10.3
i downloaded a version from there and its working
i think the new version has a lot of problems and should be deleated and revised
Try right clicking on the file, clicking on "Properties" and then "Unblock". This particular Flash installer needs to be unblocked for whatever reason.
i did what you said mdanehy and it did indeed upload it again
however it crashed 3 minute later adobe flashplayer 11.4r402 has stoped working
a problem caused the program to stop working correctley windows close the program and notify you if solutions are available
then another page opened saying
Data Execution Prevention (DEP) is a security feature that can help prevent damage to your computer from viruses and other security threats. Harmful programs can try to attack Windows by attempting to run (also known as execute) code from system memory locations reserved for Windows and other authorized programs. These types of attacks can harm your programs and files.
DEP can help protect your computer by monitoring your programs to make sure that they use system memory safely. If DEP notices a program on your computer using memory incorrectly, it closes the program and notifies you.
Did DEP stop the installation or was it Flash Player itself that crashed? You can try reinstalling and see if it happens again.
"mdanehy: "Try right clicking on the file, clicking on "Properties" and then "Unblock". This particular Flash installer needs to be unblocked for whatever reason."
You are an angel and a genious. For weeks I´ve been trying to resolve why the exe file would not start, and your simple tip was the solution.I cant begin to express the frustration one feels over totally idiotic problems like this and the time wasted on them - why on earth would a developer put this bug in the file, no person who isnt seriously interested in computers would ever find this solution, they would just stop using flash. Ive been dealing with computers since internet and home computers became more widespread around 1995, and its problems like these (that never seems to stop appearing) that makes you just want to throw the computer out the window and go back to a type writer.
A big thanx for your post.
Also try running the official uninstaller and deleting all the contents in the Windows/Syswow64/Macromed directory to make sure that Flash is completely uninstalled and then reinstall.
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
i have reinstalled it 5 times now it works for a bit then i get crash report when load page
now when i try to retrive it adobe flash player wont evin go past 50%
ill try uninstall it completly and reload it again its starting to be very very annoying at this stage
i hope it works this time
i can get a older version to work butttt it wont open my e mails in hotmail
flash player stoped the instalition i think
i used official uninstaller
restarted computer followed everything
it is the first time the zip opened and downloaded successfully
trying to use a program with flash player now
and its crashed still wont work
thank you for your help mdanehy i just think they messed up with this flash player ill run a older version will just have to change my e maill address wich will be a pain in the backside for work
or is there anything else i can do
after installing the debuger program from the link i posted earler
everything seems to be working for now fingers crosed
ok its gone again and all the stuf i did before to fix it has stoped working
been at it for five hour now . i wiped my laptop and reinstalled vista to it
so its like a new laptop but adobe flash player just wont work
evon on normal browsing it keeps spamming
is there any staff that can help me with this am i the only person this is happening to
and how come it only happened since the new flash player was installed sighs
Try adding "ProtectedMode=0" (without the quotes) to the mms file in the windows/syswow64/macromed directory. You may have to do it within an elevated Notepad, otherwise Vista won't let you edit the file. Click the Windows start button, type in "Notepad", and right click Notepad and run as administrator. Then open and edit the mms file within that.
The protected mode in Flash Player is known to cause crashes.
thanks for the advice but i give up at this stage it works for a few hour and then crashes
ITS A JOKE OF A UPGRADE IF YOU ASK ME
My suggestion, if you don't want to try the protectedmode suggestion and you continue to run into problem with 11.4, is to revert to 10.3.183.23.
when i open notepad with run adminstraer its just a blank page cant find mms file
if i write protection mode then try to save it wont ,, but ill try a older version
Don't give up on the newer version just yet.
Run Notepad as administrator, click "File" and then "Open" and then go into c:\windows\syswow64\macromed\flash. Now on the bottom right where it says "Text Documents" change that to "All Files", or you won't see mms. Then you can edit and save mms.
i downloaded the older version it seems to be working ok for now flash 10 i think
lol when i type notebook nothing comes up anymore only ( jquery allerts) just comes up notebook is gone or hiding some ware ?
but i have to say thank you very much mdanehy for your time and patience with me + rep in the highest way posable
Well, it's "notepad" not "notebook".
But I'm glad the older version is working for you.
lol thats prob why it wont show little drunk
found it hit file then searched c:\windows\syswow64\macromed\flash.
found nothing maybe my laptop is messed up
but if its working now i think its better to not try fix something thats not broken
and really i cant thank you enough you have been very helpfull mdanehy
just an update in case any one is interested since i reverted back to the older version that Chris Campbell sent me the link to
i have not had one crash report every sight is working properly i have been streaming all day editing ect
and my son had some online program running some silly war game constant
and its working perfect
so my suggestion to people who have had the same problem as me dont install the new version again stay with the old version
do not go near the new version its a mess dose not work
stay on the old version its perfect
