lyav18
How to clear or reset a combo box field
Sep 19, 2012 8:54 AM
I have a 2 combo boxes. The user selects a value for combo box 1, when the combo box 2 is selected I have a custom validation, in which I want the combo box 2 field to reset to default if the selected value is greater than the value in combo box 1. Here is the tested code:
if (event.value > this.getField("combo box 1").value) {
event.value = this.getField("combo box 2").defaultvalue;
this.getField("comb box 2").setFocus();
I've tried the following codes to try to reset the field, but none has worked:
this.resetForm("combo box 2");
this.getField("combo box 2").value = this.getField("combo box 2").default value;
event.value = " ";
event.value = "None";
(where " " is the value of the default)
(where None is the export value of the default value)
I tried this.getField("combo box 2").setItems(["value 1"]); which does work, but I would then have to put the entire list of options in. I'm not sure if this is the ideal approach. I was sure that there is a simple code for this simple problem., but I googled till my eyes hurt, and am out of ideas, does anyone have any other suggestions? Thanks.
Using Acrobat X Pro - Windows
~LV
  • George Johnson
    Aug 11, 2002
    Sep 19, 2012 10:12 AM   in reply to lyav18
    I haven't tested it, but see if this works:
    if (+event.value > getField("combo box 1").value) {
        event.value = event.target.defaultvalue;
        event.target.setFocus();
  • George Johnson
    Aug 11, 2002
    Sep 19, 2012 10:28 AM   in reply to George Johnson
    There was a typo in my code. It should be:
    event.value = event.target.defaultValue;
  • George Johnson
    Aug 11, 2002
    Sep 19, 2012 11:00 AM   in reply to lyav18
    That's weird, I'll have to look into that to see what's going on...
    The following doesn't reset, but it does reject the new value:
    if (+event.value > getField("cb1").value) {
        event.rc = false;
