moksc
AS loops
Sep 18, 2012 9:12 PM
Tags: #as #loops
ActionScript is particularly weak in handling loops. A simple loop like this exits prematurely.
for (var i:uint = 0; i < 12000; i++) {
  t.appendText(i);
Any workaround please? (This loop is perfectly fine in Java.)
  • kglad
    Jul 21, 2002
    Sep 18, 2012 10:48 PM   in reply to moksc
    there's no problem with that loop in actionscript either.
    you should change i to an int (it's more efficient) and you may need to increase your script time limit (file>publish settings>swf) if the host computer cannot complete that within your default time limit.
    p.s. if you're using strict mode you'll need to cast or convert i to a string to append it to your textfield.
  • kglad
    Jul 21, 2002
    Sep 19, 2012 6:27 AM   in reply to moksc
    i don't see a problem.  here's the code i used.  the for-loop completes in just under 6 seconds on my computer:
    var startTime:int=getTimer()
    t.text=""
    for (var i:int = 0; i < 12000; i++) {
        t.appendText(i.toString());
    trace(getTimer()-startTime);  // 5931
    p.s. here's the populated textfield though i'm not sure if there's a problem with your host computer that will cause a problem:  www.kglad.com/Files/forums/main_1.html
  • kglad
    Jul 21, 2002
    Sep 19, 2012 1:19 PM   in reply to moksc
    you're welcome.
    p.s.  please mark helpful/correct responses, if there are any.
  • kglad
    Jul 21, 2002
    Sep 19, 2012 9:10 PM   in reply to moksc
    you're welcome.
