My Adobe Premiere Pro CS4 keeps on crashing, giving me the message "Adobe Premiere Pro Not Responding." I've tried cutting, pasting, and relinking my clips, which isn’t working. I seem to be having trouble keeping other projects open as well. I've got plenty of space on my C drive, as well as the external drive that the project is on. (My Recovery drive has only 1.15 GB out of 14 GB free, but I heard it's normal for that to be full.)
I looked on another forum, which said the problem might also be electricity. I am in China right now so the voltage is different, but the program worked with my laptop and power cord for quite a while before it started quitting on me. (Also, I have tried opening Premier projects just working off the battery and they still crashed.)
Any suggestions?
More information needed for someone to help... click these links and provide the requested information
-http://forums.adobe.com/message/4200840
Here are the specs on my computer and project:
Model: Dell Studio XPS 16
Operating System: Windows 7 Professional (64-bit), Service Pack 1
Rating: 5.9
Processor: Intel (R) Core (TM) Duo CPU P8700 @2.53 GHz 2.53 GHz
RAM: 4 GB
C Drive: 215 GB free of 450 GB
My Passport 0740 USB device (on which my project files are located):
400 GB free of 465 GB
USB 3.0 compatible with USB 2.0
Video Files: 1920 x 1080 .MOV files taken with Canon 5D Mark 3
Data rate: 48787 kbps
Total bit rate: 50328 kbps
Frame rate: 23 frames per second
Audio bit rate: 1540 kbps
channels: two (stereo)
Audio sample rate: 48 kHz
As for details of the crash, it the screen simply goes gray and says (Not Responding).
If you need any more information, please let me know. Thanks again for your help.
Karuna
1st, CS4 and Win7 "sometimes" means you must right click the PPro (and Encore) icon and set the program to run in WinXP compatibility mode
2nd, have you installed any Adobe updates?
All Adobe updates start here and select product, read to see if you need to install updates in number order, or if the updates are cumulative for the individual product http://www.adobe.com/downloads/updates/
For CS4 you must update the Roxio component http://forums.adobe.com/thread/400484
More on Encore and Roxio http://forums.adobe.com/thread/528582 or direct to
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/ 000070GN&PARAMS
Also, right click the PPro/Encore icon and select Run as Administrator, which is NOT the same thing as running the computer with the Administrator account, and which fixes several "odd" problems... http://forums.adobe.com/thread/969395
Also, a general comment that Win7 64bit and only 4Gig of ram is barely giving any ram for program use... is there any way to increase the ram?
I ran Windows 7 in XP compatibility mode and ran Premiere Pro as administrator, and it worked like a charm! Thank you so much. Once I get back in the states I'll update the programs (though I don't think there is any current update for Premiere Pro CS4), as well as update from 4 GB of RAM to 8 or 16. Much gratitude for the help!
Excellent news!
If that DID fix things for you, you might want to look over this article: http://forums.adobe.com/thread/1058744?tstart=0
I see that you have already done part of that with the "Helpful" mark for John T's Reply.
Good luck,
Hunt
PPro CS4 is up to version 4.2.1 - which is a FREE download (if your Internet connection is fast enough)
http://www.adobe.com/support/downloads/product.jsp?product=98&platform =Windows
