spl00
Difference in TIFF and RAW import with ACR (how to fix)?
Sep 19, 2012 8:10 AM
Tags: #raw #conversion #tiff #acr
I'm experimenting with a workflow, so whilst this may seem like an odd thing to want to make work, I have a geniune reason for doing what's described below:
I have Canon CR2 RAW files from a 7D, Photoshop CS6 13.01 64bit, with ACR 7.1.0.354, running on Windows 7 64bit.
1. I import a CR2 image via ACR, with no changes to any sliders; opening it as Adobe RGB (1998); 16bit
2. I then save the image as a TIFF file, leaving "ICC Profile: Abode RGB (1998)" selected in the Color section of the file save dialog
3. If I then close all files, and reopen the CR2 and TIFF image, they (as expected) appear to be identical
4. After closing all files again, I then open the CR2 and make an exposure adjustment (e.g. -1.00)
5. Using Bridge, I select the TIFF file, right click and select Open in Camera Raw. I make the same exposure adjustment as for the CR2
6. Now, the adjusted CR2 and adjusted TIFF are different. A colour shift is noticable, and for a severe exposure change (i.e. +4.00) the shadow detail in the CR2 is a lot lighter
Here are two cropped areas from the files (with a 4 stop push), showing some branch/leaf and grass detail respectively. The TIFF has a greener colour cast for the grass, but much darker shadows:
TIFF
RAW
I appreciate that the CR2 is still a RAW file, and as such has the original Bayer pattern data, but is there any way I can make ACR adjustments to a TIFF (taken from a CR2) to behave in the same way as the original CR2?
    Sep 19, 2012 9:11 AM   in reply to spl00
    No...your TIFF is hitting the gamut limits of Adobe RGB. The TIFF has been gamma encoded in the Adobe RGB color space which is a far more clipped color space than what the raw file can have. You should be adjusting the raw image for optimal tone & color. While you can open a TIFF in ACR, you will NEVER have the full capability of adjustment the raw file had. If you are trying to come up with a workflow that doesn't adjust the raw file but applies all the tone/color to the TIFF I would say that would be a very poor workflow.
    Sep 19, 2012 10:24 AM   in reply to spl00
    Start by creating a ProPhoto profiled TIFF from the CR2 and you may have better results.
    Sep 19, 2012 3:24 PM   in reply to spl00
    ProPhoto RGB is the exact equivalent of Camera Raw's internal color space.  It doesn't get any wider than that.  It contains even stuff beyond that which the human eye can see and recognize as color.  It is, in effect, the "impossibly wide gamut" you envision.
    Colors cannot exist outside a defined color space.  Having no defined color space (profile) is an impossibility within the laws of physics.
    What seems to escape your grasp is that a demosaic'ed, converted image can never ever have the latitude of a raw file.
    Sep 19, 2012 3:31 PM   in reply to spl00
    http://dpbestflow.org/color/color-space-and-color-profiles
    Excerpt:
    ProPhoto RGB - This color space was designed as a universal standard for high-bit image editing, and includes all the colors that the human eye can see. ProPhoto RGB is a very popular color space for experienced Photoshop users. Because the space is so wide, it's not appropriate for 8-bit images. ProPhoto RGB is not always the best choice for a working space. Because 15% of the color space is beyond the range of human vision, color mapping is happening in ways that are impossible to see…
    Sep 19, 2012 3:34 PM   in reply to spl00
    Sep 19, 2012 7:10 PM   in reply to spl00
    spl00 wrote:
    …The RAW file has, as I understand it, no inherent colour space, as it's the recording of the cells in the camera's sensor…
    That would be, of course, nonsensical.  The raw image exists within the color gamut of the sensor.
    Unfortunately, I don't have either the time or the stamina—due to serious medical conditions—to continue this discussion.  But there are are many misconceptions and errors in your approach.
    I can only recommend that you do a lot of reading on the subject and that you take any further discussion to the Adobe Camera Raw forum, where gurus like Jeff Schewe, Thomas Knoll (creator of Photoshop and of Adobe Camera Raw) and Eric Chan contribute from time to time:
    Adobe Camera Raw
    Sep 19, 2012 4:54 PM   in reply to spl00
    spl00 wrote:
    …I guess there must be some limitations caused by the profiles that's affecting the results when a TIFF is brought back through the ACR plug in…
    The limitations are not caused by any "profiles" but by the nature of the TIFF file itself:  It is no longer a raw file!  That's what we've been trying to tell you all along.
    …a demosaic'ed, converted image can never, ever have the latitude of a raw file.
    YES, the adjustments are performed on the raw data, and, YES, the Adobe Camera Raw team must have a precise determination of the individual characteristics of each sensor.   It's a gargantuan task performed by the ACR team and it explains why new camera models are not supported right out the gate!
    I repeat: Colors cannot exist outside a defined color space.  Having no defined color space (profile) is an impossibility within the laws of physics.
    Again:  Adobe Camera Raw
    Sep 19, 2012 5:45 PM   in reply to spl00
    The numbers from a sensor are linear with the number of photos hitting them as attenuated by the color of the filter in front which generally matches the maximum color-sensitivity of the three different color receptor cells in the retina.
    Human vision is very non-linear, being much more sensitive to dim variations than bright variations, so to convert the photosite photon-linear numbers, even after debayering, to human-vision-linear numbers requires a color profile (determined by Adobe for each camera specifically) and very non-linear gamma curve be applied along with a white-balance formula that adjusts the relative RGB numbers of the raw data.
    So RAW numbers after debayering to RGB are linear with numbers of photons within a particular color (R, G or B), while TIF numbers are assumed to be linear with human-vision sensitivity.
    If you look at a raw file data that has been stretched from black to white, without applying the gamma curve it will look dark:
    http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/products /photoshop/pdfs/linear_gamma.pdf
    It is probably possible to reverse-engineer camera-sensor numbers from TIF numbers given a particular camera profile, gamma curve, and white-balance, and mid-tone exposure value, but this is never done in photo-editing program.
    Sep 19, 2012 7:19 PM   in reply to spl00
    spl00 wrote:
    Ignoring the colour profile, it should be feasible to have, say, a TIFF file that contains RGB samples whose values are the same as those used in the ACR stage for a RAW before the effect of the sliders - however, I guess there must be some limitations caused by the profiles that's affecting the results when a TIFF is brought back through the ACR plug in.
    You are forgetting that the raw data is linear and a TIFF in ProPhoto RGB has a gamma 1.8.
    The bottom line is a raw file and rendered file will have differences when processed through the ACR algorithms…so the exact same settings when applied to a raw file will be slightly different when applied to a rendered file. Nature of the beast…what you are trying to do is simply suboptimal.
    You would be better served doing the majority of the tone and color corrections on the raw file in ACR. If you then want to do slight or sublet adjustments back in ACR, ok…but just understand that ACR was designed first and formats as a raw image processor. Yes, you can also process JPEG and TIFF with useful adjustments, but I think it's an unreasonable expectation that you can achieve EXACTLY the same adjustment on a raw file and a TIFF…I think you need to rethink what you think you are trying to do.
  • JJMack
    Jan 9, 2006
    Sep 19, 2012 8:17 PM   in reply to spl00
    You stated you have a geniune reason for doing the above. Would changing
    1.) Opening the RAW file through ACR as a Smart Object instead of a Raster layer.
    and Changing
    2.) Saving the Image as a Layered Tiff file instead of a flat file
    be the same to you. If its the same to you still have access to the images RAW data in the Smart Object layer.  When you reopen the Tiff File in Photoshop you can reopen the embedded RAW File smart object in ACR by double clicking on the smart object icon in the bottom layer in the layers palette.  ACR will be working with the Images RAW data and not a raw conversion that has had white balence and other post processing processes applied.  You should be able to make the same exposure change you made when you reprocessed the RAW file. When you comit the change the embeded smart object will be updated in the opened tiff file document in Photoshop. Remember from bridge open tiff file in Photoshop then reopen the smart object in ACR.
  • Noel Carboni
    Dec 23, 2006
    Sep 20, 2012 1:54 AM   in reply to spl00
    spl00 wrote:
    I'd hoped to be able to convert (without edits) the RAW images into TIFF (or some other lossless RGB container that I can read programmatically), do the blending to produce a single TIFF, and then bring that back into ACR.
    I think the misconception here may be that Camera Raw can be employed as a cog in the machine, when it's more like a complete machine in itself.  It's moved well beyond making some kind of simply defined rendition of the raw file - in other words it's far beyond a "debayering" tool.  It's an end user tool.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 20, 2012 3:42 AM   in reply to spl00
    FYI, Jeff Schewe is an insider, though not an engineer who works on the product directly I don't think.
    -Noel
  • JJMack
    Jan 9, 2006
    Sep 20, 2012 6:09 AM   in reply to spl00
    spl00 wrote:
    I did look briefly into opening the RAW as a smart object, but sadly I didn't think that'd help. The goal I'm trying to achieve is an experimental idea to blend parts of images together from multiple exposures; but to achieve a single RAW file with that data as if it came from the camera (thus it could be brought into ACR to get the benefit of - from my point of view - the useful and intuitive adjustment sliders). Clearly that would require reverse engineering the particular RAW format for the camera being used (and each and every camera you'd want to support) - thus, it's not really practical.
    That seems to be what others do with independant smart object layers.  First you open the RAW file through ACR into Photoshop as a smart object layer. Then you use menu Leyer>Smart Objects>New Smart Object via Copy.  That creates a second independant smart object layer that is identical to the first smart object layer.  You then double click on the senond layers smart object icon in the layers palette to open it in ACR. It will open with the same settings as in the first smart object layer in ACR. You change these settings in ACR and click on the OK button. When you do that Photoshop will update the the embedded smart object in the second smart object layer. You will then have two conversion of the RAW file in Photoshop you can add Layer mask and smart filters to. You can use all of Photoshop Layer adjustment and blending options to bring out more detail in you images.   Do not just dupe the smart object layer, dups share a common smart object. You need to create additional versions with independant smart object layers. Create as many as you need use menu Layer>Smart Objects>New Smart Object via Copy....
    Sep 20, 2012 10:59 PM   in reply to spl00
    Sorry, spl00.  I meant no offense or disrespect, but if you found my post objectionable, it was my bad and I apologize.
    Sep 20, 2012 11:08 PM   in reply to spl00
    spl00 wrote:
    …only the guys that actually work on the ACR code would be able to answer the questions, but I don't know if any of those guys lurk there.
    As I typed in post #9 above:
    I can only recommend that you… take any further discussion to the Adobe Camera Raw forum, where gurus like Jeff Schewe, Thomas Knoll (creator of Photoshop and of Adobe Camera Raw) and Eric Chan contribute from time to time:
    Adobe Camera Raw
    I would also recommend that you access the forum through its web interface with your web browser rather than through email.  One of the disadvantages of accessing the forums through email is that you never get to see any edits to the posts, as edits are not broadcast.
    Another disadvantage i that you cannot attach or upload any images through email.
    Oct 31, 2012 11:05 PM   in reply to spl00
    I found this whole thread very helpful.  I wanted a stronger understanding of more detail about RAW files and did a search and stumbled upon this.  I knew the general concept and textbook explainations that you search and find and the basics they teach you of the differences of RAW vs TIFF vs JPG.  My question before searching, and what led me here, was that I thought that a RAW file and a TIFF created from that RAW file were essentially the same in terms of overall information or fidelity .  I had just learned in doing some tutorials about opening a RAW file into Photoshop as a smart object.  Thus when the smart object RAW file is clicked on to be edited that the original RAW file is edited/accessed in Camera Raw and then thrown back into Photoshop.  I took from this that there (forgive me for any ignorance) that RAW files had more 'fidelity' than a TIFF made from that RAW file.  From what the original poster questioned in step 6 that there was a difference in color shift from the CR2 adjusted file to the RAW adjusted file is due to adjusting of the TIFF file is adjusting clipped or discarded info that the original RAW file has to it.  SOO something must happen in the creation of the TIFF from the RAW file.
    I have a question on on opening RAW files as smart objects in Photoshop if someone can answer or redirect me properly I would appreciate it.....Is there any limitations that you have by opening RAW as smart object in PS?  Can you not do certain things to smart objects, like use certain filters or adjustment functions in Photoshop? Thanks!
    Oct 31, 2012 11:56 PM   in reply to Neal_Alan
    As far as I can tell, you can already do in ACR what the OP  wants to do with some kluge software. Or at least acieve all the exposure and emphasis tricks tat anyone could want.
    Nov 1, 2012 4:03 AM   in reply to Neal_Alan
    You can not paint or clone stamp etc. on a Smart Object directly but would have to do it on a new Layer with the appropriate Tool settings.
    Liquify does not work on SOs by default, but there used to be a plug-in available that enable this – don’t know if it’s been updated for CS6 and in any case it seemed not very useful as the Mesh would not be saved automatically.
    If you have read up on RAW you may have read that RAW-files are one-channel files with 14-bits depth (or thereabouts) and each pixel basically only records one of the three colors (the patterns for which one may vary).
    From that the 3-channel-color information for all pixels has to be interpolated, so something has to happen indeed.
    Nov 1, 2012 6:51 AM   in reply to spl00
    What happens in PS when you open as RAW as smart object and then rastorize?  What file format does it render it to?  You technically haven't saved it as any thing so I am wondering what does it do at the rastorize point.  In respect to color space, when you open RAW as smart object does Adobe PS assign it to what you have you defaults setup as?  I would assume that is the case but am not totally sure because if you can then go in and edit the smart object RAW and it goes into Camera RAW then it must still be in Pro Photo color space.  I am just curous how PS default color space settings affects this process of opening RAW as smart object.  Thanks for responses and info, this is giving me a lot more understanding on everything.
    Nov 1, 2012 4:57 PM   in reply to Neal_Alan
    What would be gained by blending multiple RAW image portions?
  • Noel Carboni
    Dec 23, 2006
    Nov 2, 2012 2:14 PM   in reply to spl00
    How would fooling with the raw file data be better than converting a number of images and combining them afterward?
    Astronomers combine multiple exposures all the time to average out (or statistically reduce) the noise in any one exposure.
    Since banding is often positionally dependent (not to mention cameras moving between frames being common, even with good tripods) are you thinking you'll be aligning the multiple exposures?  Given that lens responses are often non-linear that could prove more difficult than you might think.
    Astronomers often dither images - moving each sub-exposure some pixels this way and that - to overcome these issues, and they have special alignment processes that transform each of the sub-exposures to achieve alignment before combining the data (called "stacking").
    Given what you've described, I think you're attacking this in the wrong place.
    Oh, and by the way, you can generally overcome most of the banding noise via the Camera Raw noise reduction that's already implemented, and for what's left I actually have created a good banding noise reduction tool in my dSLR Tools actions set.  Feel free to post a sample raw file showing what you're talking about.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Nov 2, 2012 3:50 PM   in reply to spl00
    I raise the brightness of shadows in my Canon EOS-40D images all the time without trouble.  Yes, I can cause banding noise, but I deal with it.  Your presumption that there's no good way to deal with it may be wrong.
    Like I said, please post a raw file as an example; I'd love to help advise on ways to do NR effectively.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Nov 2, 2012 5:15 PM   in reply to spl00
    spl00 wrote:
    I'm not in front of a machine with my data at the moment, but here's an example of the kind of thing I'm talking about: http://www.fredmiranda.com/5DIII-D800/index_controlled-tests.html
    I'd suggest that if you could make 5D3 pushed shadows (from a single exposure) look like those off a D800 you'd win yourself a lot of friends amongst Canon shooters! I'm using a 7D, and the banding is significantly worse than the 5D3.
    Let's get something straight right off:  No amount of noise reduction is going to equal an image in which less noise is captured.  Unfortunately (for Canon owners) the Nikon technology has just leapt ahead sufficiently far that it's simply making less noisy images with more megapixels.  Canon will either respond with something new or fold.  I hope the former, as I'm a Canon shooter myself.
    However, I'm here to tell you the banding noise, specifically, can be mitigated.  Very few folks have figured out how as I have.  This is one of the images from the page you linked to untouched (top) and after the run of my Vertical Banding Noise Reduction action (bottom).
    But this image would have benefited greatly from more noise reduction dialed-in during raw conversion, perhaps enough not to need my action at all.  Unfortunately, the raw file isn't available.  People sometimes don't realize just how good the noise reduction in Camera Raw actually is.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Nov 3, 2012 9:31 PM   in reply to spl00
    It's part of my commercial dSLR Tools actions set.  There's also a version of it in my Astronomy Tools set, as astroimages tend to get pushed to where pattern noise shows.
    It's a bit tough to balance the aggressiveness of the action so that it gets all the noise but leaves the detail, but I've made a stab at it.
    For larger banding I've been working on an update to that set that does things on a larger scale, and somewhat more aggressively.  I should have that update out in the next few months.
    -Noel
