Firstly,
how do I set the buttons to only be selected ONCE , if another button is clicked .. it will give no response.
Secondly,
what do i do to clear the image from the UrlRequest from the selected buttons (image will be displayed) with removeChild
As you can see below, all the buttons can be selected .. all at once. which is wrong.
and also, the removeChild will only work without error #2025 if two buttons (and two images) were shown. which is also wrong.
stop();
aa1.addEventListener(MouseEvent.CLICK, ona1Click);
bb1.addEventListener(MouseEvent.CLICK, onb1Click);
cc1.addEventListener(MouseEvent.CLICK, onc1Click);
next1.addEventListener(MouseEvent.CLICK, onNext1Click);
home1.addEventListener(MouseEvent.CLICK, onHome1Click);
var Q1a:Loader = new Loader();
var Q1b:Loader = new Loader();
var Q1c:Loader = new Loader();
var Q1next:Loader = new Loader();
var Q1home:Loader = new Loader();
//the name of the function has to match what you're calling from the event listener
function ona1Click(evt:MouseEvent):void {
var myQ1a:URLRequest=new URLRequest("wrong.png");
Q1a.load(myQ1a);
addChild(Q1a);
Q1a.x=320;
Q1a.y=180;
function onb1Click(evt:MouseEvent):void {
var myQ1b:URLRequest=new URLRequest("tick.png");
Q1b.load(myQ1b);
addChild(Q1b);
Q1b.x=320;
Q1b.y=260;
function onc1Click(evt:MouseEvent):void {
var myQ1c:URLRequest=new URLRequest("wrong.png");
Q1c.load(myQ1c);
addChild(Q1c);
Q1c.x=320;
Q1c.y=340;
function onNext1Click(evt:MouseEvent):void {
removeChild(Q1b);
removeChild(Q1a);
gotoAndPlay(2);
function onHome1Click(evt:MouseEvent):void {
gotoAndPlay(17);
HELP me.
1. you can use the mouseEnabled property of your buttons to disable them all when one is clicked.
2. use unloadAndStop() (if publishing for fp10+) or unload (if publishing for fp 9) applied to your loader.
p.s. just use one loader. you have no need for the others if you're disabling the buttons that would use the other loaders.
thanks a lot kglad. helped a lot.
still another problem though. i would like to disabled the other two buttons if one button has been selected. so, im guessing there should be an if else statement .. which i am also not sure how to execute.
for example : i clicked button A .. and button B & C will be disabled.
----------- first button --------------------------
Q1a.load(myQ1a);
addChild(Q1a);
Q1a.x=320;
Q1a.y=180;
----------- second button --------------------------
Q1b.load(myQ1b);
addChild(Q1b);
Q1b.x=320;
Q1b.y=260;
-----------third button --------------------------
Q1c.load(myQ1c);
addChild(Q1c);
Q1c.x=320;
Q1c.y=340;
so .. i would to only click ONE out of the three, and disable the other two.
none of those code for buttons.
the last two are event listener functions associated with two buttons (bb1 and cc1). the first is part of an event listener function for aa1
this is your button listener code where you define button behavior for 5 objects:
if you want to disable all but the clicked button for aa1,bb1 and cc1 in your ona1Click, onb1Click and onc1Click functions add:
disableF(evt);
and add the following to your code:
var buttonA:Array=[aa1,bb1,cc1];
function disableF(e:Event):void{
for(var i:int=0;i<buttonA.length;i++){
if(buttonA[i]!=e.currentTarget){
buttonA[i].mouseEnabled=false;
