Why do my images look soft in Bridge?
Aug 28, 2012 9:12 AM
  Latest reply: Yammer P, Feb 13, 2013 2:08 AM
Replies 1 2 3 4 Previous Next
    Sep 19, 2012 1:39 AM   in reply to randalqueen
    I think I may have just made a breakthrough.
    After looking at Omke's screenshots, even though there was no fit/fill comparison, it is clear that his previews are pretty sharp, especially the church. A selective crop of fit/fill comparison at 100% would be the ultimate test, but I now think this wouldn't matter...
    I've just tried the "Use Software Rendering" Bridge preference for the first time. It's in the Advanced tab, and you must restart Bridge after changing it. Also, just to be sure, I purged the test image's cache. I then did another cropped screenshot, similar to the one above, of the Fit to Screen preview. Comparing it to the hardware-rendered Fit preview, it is noticeably sharper, but still not as sharp ast the Fill preview.
    I suggest that you try this setting, Randal. It may help. Let us know.
    Meanwhile, I want to know why hardware rendering is producing a softer preview. I shall have to investigate my graphics card properties, and do some googling.
  • Omke Oudeman
    Nov 27, 2004
    Sep 19, 2012 1:56 AM   in reply to Yammer P
    The difference between the trees and the church should be significant, the trees are DNG, Raw from camera with ACR set to only sharpening to preview and the PSD file is a finished file with applied complex sharpening
    That setting is needed when your graphic card (especially the VRAM amount) is not sufficient
    See above, you might be on to something. Minimum requirement for CS5 is:
    102 4x 768 display (1280 x 800 recommended) with qualified hardware-accelerated OpenGL video card, 16-bit color, and 256 MB of VRAM
    And for CS6 they are the same but with addition to VRAM: 512 MB recommended.
    I bought a new Graphic Card this year ( ATI Radeon HD 5770 with 1GB VRAM) My older one (from Nvidea, don't remember which type) had only 256 MB and I wasn't able to use Open CL in CS6.
    The new ATI did speed up things a lot
    Sep 19, 2012 4:01 AM   in reply to Omke Oudeman
    I am using an ATI Radeon HD 5670 with 1GB of RAM, which is a less powerful version of the 5770, but well within system requirements, so I doubt this is the problem. I am also using the latest driver, although I have witnessed this preview softness issue for at least a couple of years.
    Does Hardware Rendering let the graphics card do the Fit to Screen resizing, I wonder? Certainly, setting software rendering improves preview sharpness. I'm leaving this on for the time being.
    I have installed ATI Catalyst Control Center and changed all user settings to their highest quality, but none of it seems to make any difference to hardware-rendered preview sharpness.
  • Omke Oudeman
    Nov 27, 2004
    Sep 19, 2012 4:19 AM   in reply to Yammer P
    Well, upgrading Grading Card as the easy solution of the problem did indeed sounded to good to be true
    I have no knowledge about that subject.
    Here we part again, my only action for latest drivers is upgrading Mac OSX and I have to say that is an easy job
    And how about an other easy solution, since I'm under the impression you use Windows why not switch to Mac...
    (I know, also to good to be true but nevertheless it was worth a try)
    Sep 20, 2012 12:03 AM   in reply to Omke Oudeman
    I posted this problem to the Photoshop and ATI Graphics forums. No one from the Photoshop forum replied, but the ATI users commented that they would expect hardware rendering to be inferior, as it's built for speed not quality. It was also suggested that I might have to spend a lot more on a fancy graphics card to place the emphasis on quality.
    Jan 14, 2013 6:15 AM   in reply to Yammer P
    I just came across this thread, and have the same experience as Yammer P and others - full screen previews are often fuzzy, and inadequate to assess proper focus, requiring a click for 100% preview.  I have enabled full-screen, High-Quality, etc. to obtain the best quality.  I have seen this for quite some time, both with CS5, and now with CS6, and have often speculated to myself that it's a mismatch between the resolution of the full-screen preview, and how it is 'scaled' on a particular display.  I have not tried disabling hardware rendering, but will try that when I'm home.
    And I haven't experimented with this systematically, so can't be sure, but it seems that the softness issue is worse after I crop an image (despite the fact that I do see that the preview image is re-created).
    I'm just wondering if any other solution has been found to this issue?  As many have commented, this is a pretty crucial, fundamental area for photographers use of this program, and it really needs to be definitely fixed and addressed for any who encounter this problem.
    I would have PM'd Yammer P on this, but that doesn't seem to be an option in this forum?
    Thanks.
    Jan 14, 2013 6:45 AM   in reply to DLC-Photography
    The problem is very dependent on screen dimensions and graphics card. Some different shapes and sizes of images will render sharper than others, depending on your circumstances. The same applies for crops. Just change a crop by one pixel and you'll see a difference in sharpness.
    I found the speed of Software Rendering to be unacceptable on my four year old Core2Duo. I have since splashed out on a new graphics card, and I can't say I have noticed much difference in hardware rendering quality. The jury is still out for me.
    Jan 14, 2013 7:01 AM   in reply to Yammer P
    Thanks for the quick reply.  Unfortunately, it's what I was expecting - no definitive solution.
    The important thing, as you've pointed out in a prior post, is to be aware of this, and make sure to check at 100% before discarding an image because it appeared soft on the full screen preview.
    Jan 27, 2013 3:05 AM   in reply to DLC-Photography
    Jan 27, 2013 3:47 AM   in reply to infos@guewen.net
    I have set up an "idea" at photoshop.com feedback. Please support this by adding your +1s.
    http://feedback.photoshop.com/photoshop_family/topics/generate_monitor _size_previews_to_fit_in_bridge
    Jan 27, 2013 5:58 AM   in reply to Yammer P
    yes i did it
    Jan 27, 2013 11:06 AM   in reply to infos@guewen.net
    I don't know if i have understand well,
    Presently, Bridge generates "monitor size previews" based on the longest dimension of your display. This causes poor sharpness with full-screen 3:2 and 4:3 landscape-format images on widescreen displays and projectors, due to resampling to fit.
    It would be better if it generated a preview size which fits the display exactly (e.g. 1200 pixels tall on a 1920x1200 display), or, even better, a user-defined display window (e.g. 1400x1050 for a projector). This way, a cached preview could be displayed at 100% and retain sharpness.
    but is this feedback just talk about widescreen display, my two screen are old but realy good screen and format 4:3, and i always have the matter in all of my pictures
    Jan 28, 2013 2:54 AM   in reply to infos@guewen.net
    The issue here is how the "monitor-size" preview is resized. What are the pixel dimensions of your primary display, and what are the pixel dimensions of your camera images?
    Jan 28, 2013 7:40 AM   in reply to Yammer P
    Ok thanks.
    It realy is amazing, that choice of adobe is totaly inapprehensible, because if i understand well, it is a choice.
    It is just a lost of time in the picture work and select process. I was thinking that  adobe photoshop and bridge were developped to increase the product.
    Am I wrong ????????
    You says that the picture is soft and not sharp, but my hq preview are always not just soft but realy fuzzy and not a little. It is realy not acceptable that we have to display the picture at 100% to know if it is realy sharp or fuzzy.
    Photoshop isn't a freeware, and it is expensive... I like it but it is a little too much, i can't believe this choice.
    Jan 28, 2013 8:17 AM   in reply to infos@guewen.net
    One of the problems with discussing softness and fuzziness online is that it is totally subjective. What might be acceptable to some, might not be to others. Also: HOW soft, HOW fuzzy? All we can do is attach examples, like I did, earlier in this thread (#34).
    I have also seen Bridge produce HIDEOUSLY fuzzy previews (very blocky/pixellated)—which were clearly a temporary fault with Bridge, and was fixed with a purge/restart. So, you see, we need to be careful about what it is we're discussing, and check we're talking about the SAME thing/problem.
    By the way, I asked: "What are the pixel dimensions of your primary display, and what are the pixel dimensions of your camera images?" I would like to check if you should be seeing the same issue as I am.
  • Omke Oudeman
    Nov 27, 2004
    Jan 28, 2013 8:20 AM   in reply to infos@guewen.net
    Am I wrong ????????
    Here is the problem, I say you are wrong because I have tack sharp HQ previews (see my screen shots in post 35 -page 1- of this long thread) but for some reason you still don't have this behavior.
    You says that the picture is soft and not sharp, but my hq preview are always not just soft but realy fuzzy and not a little. It is realy not acceptable that we have display the picture at 100% to know if it is realy sharp or fuzzy.
    If you are sure you have the latest update for Bridge (at this time 5.0.2.4) and your Graphic card drivers are al up to date I would try to reset Bridge totally.
    As a Mac user I don't know the same locations on Windows but you can see this location in the preferences of Bridge (cache / location and inhere you will see the path to find it).
    Quit Bridge and delete the cache file for Bridge manually by dragging it to the trash. Reset the preferences again by holding down control key and choose reset preferences.
    Then when Bridge has started first reset your workspace and try a folder with a few images (best prepare this before) and see if works correctly this time. By default Bridge is set to always HQ preview and this should also be the case after resetting preferences.
    Also check if your central cache file is on the same disk as the application (your start up disk).
    Export cache to folder is not the best way to use cache and it is preferred for full screen to set the option for monitor sized previews to on but not all users do profit from this as Yammer P already stated.
    Jan 28, 2013 8:42 AM   in reply to Yammer P
    The first screenshot is a part of the fullscreen view whith bridge
    the seconde screenshot is the same part of fullscreen view with another soft.
    And a part of the screenshot after zoom 100% whith bridge
    I have describe my problem in this topic :
    http://forums.adobe.com/message/5025502#5025502
    I had tested many times to change settings and clear the cache and rebuild it... in just one directory or picture or all the cache...
    The matter is the same whith many sort of picture, jpg, cr2(canon raw), psd, tiff
    Display resolution : 1600 / 1200
    Pictures : with canon 40d (10 Mega Pixels) : 3888 x 2592
    with canon 7d (18 MP) : 5184 x 3456
    with canon 1ds Mark ii (16 MP) : 4992 x 3328
    Jan 28, 2013 8:32 AM   in reply to Omke Oudeman
    Here is the way I see it.
    As I have already shown, hardware rendering of full-screen previews can produce poor results, and make it difficult to judge image sharpness. The 'poorness' varies with resampling amount (in a chaotic way, due to quantisation effects), and graphics hardware.
    This would not be a problem if Bridge produced true "monitor-sized" previews. But it doesn't. It produces previews based on primary display pixel width, THEN makes the graphics chip resample (on the fly) to fit the display exactly. This is where the error is introduced in some cases.
    It's difficult to tell how sharp Omke's full-screen preview is because it was resampled for this forum, and there is no fill-screen version for comparison. So, I'm still not 100% convinced that Macs are immune.
    Jan 28, 2013 8:34 AM   in reply to Omke Oudeman
    Omke Oudeman wrote:
    Am I wrong ????????
    Thanks for the reply, i post my last message before i saw it.
    I have to go for now but I will examine it later and try your advices.
    Jan 28, 2013 8:48 AM   in reply to infos@guewen.net
    Wow! They are very soft. Much worse than mine, but not so bad it looks like a cache problem.
    Having said that, I'm not quite sure what I'm looking at. Are the first two images actual-size pixel-for-pixel sections of full-screen previews (shrink to fit)? Is there any/much difference with Software Rendering (preferences/advanced)?
    By my calculations, your monitor-sized previews will all be 1600 x 1067 pixels, which should fit in your 1600 x 1200 display exactly. You can verify this by looking in subfolders of this folder:
    C:\Users\-username-\AppData\Roaming\Adobe\Bridge CS6\Cache\1024
    (the path is shown in Bridge preferences/cache settings)
    If they are not this size, then something is wrong. Try looking at them using your other photo viewer, full screen. Are they just as bad?
    Jan 28, 2013 9:01 AM   in reply to Yammer P
    The screenshot 1
    The screenshot 2
    Exactly the same part of the picture in fullscreen view.
    I don't know now the difference whith software rendering, the other is fastone image viewer
    Sorry i realy need to go, see you later.
    Jan 28, 2013 10:26 AM   in reply to Yammer P
    I have pretty much stayed out of this discussion as "fuzzyness" seems so subjective.  The some of the pictures shown exhibit fuzzyness but what is the "standard".  And the pictures themselves may or may not be sharp to start with, or just difficult to see the less than sharp intpretation.  I would be more inclined to use a standard test imagae which everyone could download and then send in a test shot at XXX magnification on full screen.  Here is a link to one I tired.  It is a 1.8 meg jpeg.  http://www.gpsinformation.org/jack/photo-test/pics/iso-rag.jpg
    Here is a screen save taken at full screen using space bar.  I use embedded thumbnails, 100% previews off.  Is this fuzzy?
    Message was edited by: Curt Y  Here is the website if the above does not work.  http://www.gpsinformation.org/jack/photo-test/pics/lens-tests.html
    Jan 28, 2013 10:59 AM   in reply to Curt Y
    Absolutely, yes, and quite a lot worse than my display, which coincidentally is also 1920 x 1200.
    I'm quite pleased that I splashed out on a new graphics card recently. There's not much difference between hardware and software rendering on my computer now. Software still has the edge, but not by much. Using your test image, there's some banding with the fine lines in hardware mode, but which is more even in software mode. Have you tried the screen cap using software rendering, Curt? (set, restart and purge cache first)
    Jan 28, 2013 11:44 AM   in reply to Yammer P
    I don't see any difference with or without software rendering.  But then I am probably not as critical as you.
    Jan 28, 2013 1:08 PM   in reply to Yammer P
    the previews are all 1600 x 1067
    Yes they are just as bad
    I am happy to read that and i also think that it's about a cache problem but i can't solve it until now.
    Jan 28, 2013 1:10 PM   in reply to Omke Oudeman
    yes i did it about 3 days ago
    i did it
    ?? I don't understand how you reset preferences
    i did it
    Nothing has changed
  • Omke Oudeman
    Nov 27, 2004
    Jan 28, 2013 1:14 PM   in reply to infos@guewen.net
    Sorry, restart Bridge holding down control key provides you with a menu window, choose reset preferences.
    If you do this together with the manual delete of the central cache this would mean Bridge needs to recache all the files which might take some time.
  • Omke Oudeman
    Nov 27, 2004
    Jan 28, 2013 1:31 PM   in reply to Curt Y
    Here are my screenshots, converted to PNG and from my 30" Cinema display (2560 x 1600 pixels, looks very sharp to me, hope the DNG on this page will reflect what I see on my system
    Preview panel:
    And full screen (option to generate monitor sized preview set to on and my 1024 cache folder shows files with 2560 pixels at the longest side ):
    Jan 28, 2013 1:58 PM   in reply to Omke Oudeman
    ok i did it but...
    Jan 29, 2013 1:42 AM   in reply to infos@guewen.net
    The screenshot 1
    The screenshot 2
    The first screen shot is pretty awful. I thought mine weren't so good, but yours and Curt's make mine look fantastic.
    One observation: your "screenshots" are 1601 x 1068 pixels. You already said your screen was 1600 x 1200 pixels. Something is not quite right there.
    Jan 29, 2013 1:49 AM   in reply to Curt Y
    Well, the key word here is "critical". I am using Bridge full-screen to critically assess image quality, as the first stage in vetting a photographic shoot, which might be hundreds of images.
    The problem people are reporting is that the full-screen preview is too soft. So it is impossible to tell if the photographic image is sharp, blurred, or poorly focussed, without zooming to 100% and scrolling around the image—a major inconvenience with many images to check.
    Jan 29, 2013 2:15 AM   in reply to Yammer P
    because it is a screenshot of 2 screens, i let one pixel of the second display when i cut it.
    Jan 29, 2013 2:43 AM   in reply to Yammer P
    100% agree, it is exactly my problem...
    Jan 29, 2013 2:55 AM   in reply to Omke Oudeman
    Omke, the most effective way to show sharpness is to compare your 'spacebar preview' with a 'Fill slideshow'.
    Try Ctrl/Cmd-Shift-L first, and set to "Scaled to Fill", then "Play" the image and do a screen capture. This effectively displays the '1024' cached jpeg at 100%.
    You can then compare the sharpness of the 1024 jpeg and the full-screen preview. In a perfect world they should look exactly the same.
    I must admit though, that I'm more than a little jealous of your 30" 2560 x 1600 display, and suspect that you may have a natural advantage with such a high resolution.
    Jan 29, 2013 6:59 AM   in reply to Yammer P
    Yammer,
    I used embedded thumnails and then just pressed the spacebar to get the image.  Does Bridge generate the same image whether you do as I did or start with a HQ thumb?
  • Omke Oudeman
    Nov 27, 2004
    Jan 29, 2013 7:25 AM   in reply to infos@guewen.net
    Meaning you have bridge running on 2 screens??
    This is a whole different matter because there ave been more issues with dual screens. Have you tried to exchange screens, On a Mac there is a setting to make one the main screen, must be also something in Windows I would think, can you try to change them or view the panel on the other screen to see if this has the same result?
    Jan 29, 2013 9:02 AM   in reply to Curt Y
    If you are displaying a raw file, as I am, Bridge will display the embedded JPEG, which in my case is a full-size undeveloped highly compressed version of the image produced by the camera at capture. If you decided to go 100% for any reason, the HQ previews are generated.
    If you are displaying a JPEG, then all bets are off, and I'd guess that you are displaying the real thing.
    This might be related to Guewen's problem. If Guewen has HQ previews off, and for some reason the embedded JPEG is very small and/or poor quality, this might explain the poor full-screen previews. In this case, clicking on the preview to make it 100% should generate an HQ preview.
    Unfortunately, it doesn't explain why Curt's test card preview is worse than mine, given the same source file and display size.
    Jan 29, 2013 9:12 AM   in reply to Omke Oudeman
    I run on two screens of differing sizes. My primary is 1920x1200, my secondary is 1280x1024. In Windows 7, you can select which screen is the "main display", and then decide whether to "extend" or "duplicate" the desktop (or use only 1 display). I would imagine that the only sensible option for photo work is "extend".
    "Duplicate" might be useful for projectors, but I have seen what happens when "duplicate" is used with two different-sized displays, and it isn't pretty.
    Guewen has two 1600x1200 displays, so, as long as this statement is correct, and both display sizes are set correctly in Windows then it should work just fine. Unless of course there is a graphics driver issue.
  • Omke Oudeman
    Nov 27, 2004
    Jan 29, 2013 9:52 AM   in reply to Yammer P
    Here are the results from a small test from someone taht seems to live in a perfect world... :-)
    Slideshow set to Centered:
    Slideshow set to Scale to Fill:
    And finally Slideshow set to Scale to fit:
    I can't spot any difference between them.
    There is always one that has something better then yourself, maybe that will be a little comfort to you??? :-)
    But sadly enough Apple discontinued the production of this wonderful screen and since this one is getting rather old I still have no clue with what I can replace it with. The new screens from Apple offer 'only' 27 " but main problem is they placed a glass in front of it which sometimes gives you the option to use it as a mirror.
    Jan 29, 2013 11:19 AM   in reply to Omke Oudeman
    Omke,
    On the new Thunderbird display, you can remove the glass and not have it. And you can use http://www.macframes.com/ to frame the monitor. I decided to go with an NEC MultiSync PA241w monitor because I am still using a MacPro. I had the 23" Apple Cinema Display. I can say that I too have to press the spacebar to get 100% previews and was part of this conversation but just got tired of looking for the reason. Prior to CS6 I did not have this problem. I have not tried Scaled to Fit versus Scaled to Fill. I just press the space bar. I blame Apple and just move on. But you can get the new monitor and remove the glass that is held on by magnets.
    Randal
Actions
