Is there any way to reset the PDFs Presets in Indesign. The High Quality PDF (that is a preset already in Indesign) started to crash ages ago. I just made up new PDF Presets. Now it seems that when making PDFS whether Press Quality or the ones I have made myself it crashes. I launch Indesign then can make a PDF but then when I open another document it crashes again? Any help greatly appreciated
SolaCrazyDog wrote:
It says version 7.
Where?
Go to either the Help menu on Windows, or the InDesign menu on Mac (and I still want to know which one you use) and hold cown the Ctrl or Cmd key, respectively, while you choose About InDesign. Tellus the full version number you see in the upper left of the dialog.
It really would help if you told us the OS, but I'm surmising it's some version of OS X...
your hang problem might be SING. YOu can try this: SING Removal
Please see Adobe Forums: InDesign CS5.5 Not Responding for directions to to produce a Hang report, then a forced crash and report, and put both of them on Pastebin.com, not here, and put links to both of them here. We may be able to pin down the problem from the reports.
I'm about to quit for the day, so either someone else will help you, or I'll pick up again in the morning.
Your crash report is not typical of SING, and doesn't look like anything I've seen before, but strikes me as a problem with the recovery data from a previous crash. Did you run these after a crash with a file open?
What happens if you empty the InDesign Recovery folder?
What version of Suitcase are you running? Try removing the autoactivation plugin from ID.
The recovery folder should be in your user library. Do you have the latest patch for Suitcase?
I don't recall for sure, but there may have been some capmaptibility issues with version 3 and CS5. version 4 would probably do better. I owuld definitely try removing the autoactivation plugin from ID.
Did you actually remove the auto-activation plugin, or just disable it? Do you have the latest patch for Suitcase?
Also see if this helps: Fix for applications (TextWrangler, Chrome, Evernote, iPhoto …) crashing on startup in Mountain Lion | Dae’s blog
