Hello anyone
This new Cloud Adobe CS6 is SO buggy.
not my first issue with it...
I am using
Cloud version of - but locally installed
Trial version of CS6 InDesign.
iMac - mountain lion 10.8.1
i7/12Gig RAM. SSD, and 1 T platter drive.
Anyway-
After many HOURS of InDesign work.
Many pages, lots of stuff.
I exported my work as PDF to send to my boss. Worked fine.
But I can't save the working file.
All Save menu items are grayed out.
The astericks is there in the window title.
When I just close the file- I am prompted to Save the file or lose my work.
I hit Save and get window
"can not save filename"
with no error code.
NOTHING!
This has happened twice. First time not a lot had been done to the file.
So I just re-started the iMac
This time I stand to lose some real work here.
Does this happen if I just use the free version!?!?!?!?
I will happily pay after my trial but if this is what the new CS6 has in store, then screw Adobe.
Can anyone help me???
There's no difference in fuctionality between paid and free versions.
There are two things worth trying, if you haven't already closed and lost the file. The first is to export to .idml, open that and see if you can save it with a new name: Remove minor corruption by exporting
The second is riskier as it depends on ID's amazing file recovery after a crash. If the method above fails you haven't got a lot to lose, though, so here here's the next thing I would try:
Force Quit Indesign. See Replace Your Preferences and use the manual method to replace the InDesign Defaults and InDesign SavedData files (and while you're at it, make a backup copy of the InDesign Recovery folder). Also see Adobe Forums: InDesign crashes at startup and delete the additional files in John's post. If you need to delete or copy hidden files and don't know how to access them, see Access hidden user library files | Mac OS 10.7 Lion
When all that is done, restart InDesign. With luck, autorecovery will open the file again with not much missing and you can try to save it.
The "why" is hard to know. I'm glad it worked out. Are you working across a network with a file? That's one major place where things can go bad.
Many organizations use a network workflow, but the networks need to be rock solid. Much safer to keep the files you are writing and saving on the local hard drive if you can, then copy back to the network when you are done.
Peter
Once again thanks.
No, no network.
At first I was hopeful my cloud account would hijack the file and push me to save to the cloud :)
But alas :/
No such luck.
It was very unclear how to save to my cloud account
My save ended up on the desktop.
I usually save to Dropbox to work on file from either iMac or air
But this time: desktop.
Yeah I wonder if I have a RAM issue
Or SSD
I do hope that it's not CS6.
I am happy with the new model of pricing
And use of cloud as service. :)
I will do hardware diagnostics before any more blame is levied.
As I did not see any other posts for this issue.
Thanks again
b
I hope you are moving the file from the dropbox (yeah, that's a network, and you're relying on an iffy internet connection) onto your Mac or PC before opening for editing, saving locally, then moving the new version back to the dropbox. Working directly from the dropbox is not a safe thing to do.
I disagree. It's no different than working locally and having an auto backup.
In fact, I usually work on current projects in a dropbox folder to protect them. Saved my neck a couple weeks ago when I overwrote a file. Went to DB on the web and chose the prior version for restoration.
Saved me hours of work recreating the file.
Bob
That’s the point…I went to my Dropbox folder on the web and from there you can pick any version of the file that you’ve saved. I simply picked the previous version and it was instantly restored.
I love Dropbox. It’s a backup and versioning tool all in one.
I have no problem paying for the 100GB service and with all the referrals I got I’ve gotten to 132 GB for $9.99/month. Worth every dime.
Bob
Does it do the version for you, or are you saving new versions yourself?
I have to say I personally found Dropbox to be very clunky and annoying when I tried it, so I've not given it much of a chance. But I stand by my opinion that working on files over the internet is asking for trouble.
