Some more suggestions: if you are using a CSV file for the merge, try a TXT file. If you are using a TXT file for the merge, try a CSV file. If your data file is from Excel, examine the export (csv or txt) file in a text editor and look for anything that might have went awry, illegal characters, etc.
So it works when I export it to PDF, but I would really like to be able to make it into a merged document so I could edit the photo locations inside the frame. I'm assuming that was making it into a merged document does. I tried both a txt and a csv file. I even tried it on another computer. I tried changing the $ values to just a number and then just a general column in excel as well. I'm not sure what the deal is. Why would it make a PDF correctly but not merge the document into an editable file?
Did you try the new user?
Behavior there will tell us if the problem is user related, and possibly repairable by trashing the prefs (Replace Your Preferences) or if it a file or program problem.
https://www.dropbox.com/s/c1so4l15k1lvb88/LotPrices.csv Thanks in advance. This would really make my life better.
Actually, the only real justification for putting the merge fields on the master are if you have other master elements you don't want duplicated for each record in a mult-record merge, and more importantly the bilityt to update an already merged file when the data set changes.
I generally do my merges with a blank master, then apply the correct master after the merge to avoid any issues with master objects, and from reports here updating an existing file that has merged images is a lot less than reliable -- the images reportedly disappear. Given the ease of saving the merge temaplte and just rerunning the merge if the data changes, I don't see any compelling reason to use merge fields on the master page in most cases.
