Flickering during playback in Premiere Pro (CS6)
Sep 20, 2012 8:23 AM
Hello everyone..  I work in the IT department, and I am trying to assist a user with a problem they are having with Premiere Pro.  Let me preface this by saying I know nothing about how to use Premiere.. I am not the user, I just install it and make sure it's there.
The problem they are having is that when they click the button to watch playback, the screens (dual display) flicker/flash/strobe, whatever you'd like to call it.  As soon as you click 'stop', it stops.
I've already tried re-installing Premiere, but I might need to just completely uninstall the entire CS6 suite and reinstall it.
Here are the specs: (I don't know why the images are blurry, but you can click on them to open them and they are clear)
And the video card info:
I've already been to AMD's website, and it says I have the current video driver.  Windows is also completely up to date.
This system has dual monitors.
Thank you in advance!
    Sep 20, 2012 8:51 AM   in reply to lelandgray
    What is the disk setup?
    Sep 20, 2012 8:52 AM   in reply to lelandgray
    The displays themselves flicker, or the video in the PP window flickers?
    Sep 20, 2012 9:28 AM   in reply to lelandgray
    A single disk is not enough. One needs AT LEAST 2 separate 7200 RPM SATA disks for minimal performance, preferably more. During use, the fill rate goes up and performance goes down and this happens more often than one thinks. Temp files, cookies, log files etc. are great to bring almost every system to its knees.
    Sep 20, 2012 10:04 AM   in reply to lelandgray
    Only one drive is a problem (see below) but... more information is still needed
    Is CS6 updated to the 6.0.2 version?
    What kind of video is being edited? (see below)
    Is there a red line over the timeline when the video is 1st imported and before any work is done?
    -if yes, that means the project sequence is not correct
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
    http://forums.adobe.com/thread/592070?tstart=30
    For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
    http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-gree n-render-bars.html
    Trying to use only ONE Hard Drive for Video Editing
    You are a music conductor, with a baton that you use to point to various parts of the orchestra... this is like Windows pointing to various parts of the hard drive to do Windows housekeeping or to load program segments for various functions
    Now, at the same time and with the same hand... while still using the baton to conduct the orchestra... pick up a bow and play a fiddle... this would be doing something with your video file at the same time as all the other work
    You as a person cannot do both at the same time with the same hand
    A computer is a LITTLE better, in that it can switch from one kind of task to another very quickly... but not quickly enough for EASY video editing
    You need AT LEAST two hard drives (separate drives, never a partition http://forums.adobe.com/thread/650708 for more) with Windows (or Mac OS) and software on your boot drive, and video files on a 2nd drive so the boot drive is not slowed down by trying to do everything
    Sep 21, 2012 8:49 AM   in reply to lelandgray
    There was another editor that ran into this before with the ATI driver that was out. I suggest you uninstall the current ATI driver and download a previous version. The way to test this is deactivate the full screen and just run the 1 and see if the playback is still flashing on the Program monitor.
    Eric
    ADK
    Oct 1, 2012 2:25 PM   in reply to John T Smith
    You are all giving this guy the wrong advice. This isn't about gear. His build may be a little weak but I am on a 256GB SATAIII SSD, INTEL i7(2.9ghz), RADEON HD6870, 16GB RAM, 3 internal 2TB HDD's and I had the same problem.
    While I don't have a solution I can say that this is for sure a software problem.
    I've been able to lock one of 3 monitors as a playback device with no problem for the few months I've been on CS6.
    After I recently reformatted my system and reinstalled everything, I got this flickering playback problem when I set a 2nd or 3rd screen as a playback device.
    I was able to patch the problem by uninstalling my graphics card drivers through device manager, restarting, and letting windows update install my graphics card drivers.
    Most Likely I installed the wrong drivers for my card when I reformatted.
    Will update if I get any further.
    EDIT: SOLVED!!!!!
    I went to this site and began rolling back my amd catalyst software 1 version at a time.
    I know that it used to work fine on the same hardware.
    After I rolled back 3 versions to catalyst software version 12.4 (Apr 25, 2012) the problem went away.
    Now I am using 3 monitors. All flickering stopped!!!!
