residentevil750
Repeat function for duplicated movieclip Help Please
Sep 20, 2012 11:39 AM
Tags: #duplicate #movieclip
In my game I have a button (fireBtn) that duplicates a movieclip of a fire(s).  I also have a water button (waterBtn) that fades out the fire and removes the fire duplicate movieclip(s).   Last there is a ‘Reset’ button (reset_mc) that also removes the fire duplicate movieclip(s) and resets all the other players.  Here is the code:
//Creates Fire
fireBtn.onPress=function(){
i++;
_root.fireMC.duplicateMovieClip("fireMC"+i, i);
waterBtn.onRelease=function(){
                waterBtn._visible=false;
//Fades and removes fire
waterBtn.onPress = fadeOut;
function fadeOut(){
fireMC1.onEnterFrame = function(){
if(this._alpha >= 0){
this._alpha-=5;
if (this._alpha>=100 || this._alpha<=0) {
for(var j:Number=0;j<=i;j++){
if(tl["fireMC"+j]){
tl["fireMC"+j].removeMovieClip();
//Also removes fire and resets waterBtn
reset_mc.onRelease=function(){
waterBtn._visible=true;
for(var j:Number=0;j<=i;j++){if(tl["fireMC"+j]){
This works fine the first time but after using the reset button the duplicate fire created does not fade or remove.  I think it has something to do with naming of duplicate movieclips (12th line of code).  I would like the duplicated fires to always fade no matter how many times you reset but I haven’t a clue as to how make the code do that.  I hope this makes sense.  Any help would be appreciated. Thanks in advance.
    Sep 20, 2012 11:46 AM   in reply to residentevil750
    try
    i=0; // <----- reset  i
  • kglad
    Jul 21, 2002
    Sep 20, 2012 9:10 PM   in reply to residentevil750
    you should use something like:
    var init:Boolean;
    if(!init){
        var i:Number=0;
    init=true;
    i++;
    function fadeOut(){
    tl.onEnterFrame = function(){
    for(var j:Number=i;j>=0;j--){
    if(tl["fireMC"+j]){
    tl["fireMC"+j]._alpha-=5;
    if(tl["fireMC"+j]._alpha<=0){
    } else {
    delete tl.onEnterFrame;
    break;
    if(tl["fireMC"+j]){
    } else {
    break;
  • kglad
    Jul 21, 2002
    Sep 20, 2012 2:43 PM   in reply to residentevil750
    you should still fix your code so it does not execute useless looping calculations ad infinitum.
  • kglad
    Jul 21, 2002
    i assumed you had tl defined elsewhere in your code.  but, if not, use the following to ensure tl is defined:
    var init:Boolean;
    if(!init){
        var i:Number=0;
    var tl:MovieClip=this;
    init=true;
