Hello all,
When I generate an RH html project for an FrameMaker document, all images that had an arrow or circle "added" to them in FM, are followed by a line in RoboHelp. See the screenshot below for illustration. When I remove the frames, no line is shown in RH. I guess there must be a setting that reacts to frames in that specific way - does anyone know where exactly this can be fixed?
Thank you.
Ok, now I'm seeing it - there was so much stuff going on in the first post that I couldn't figure what was the problem. What happens if you have just a plain anchored frame with a graphic in it (no call-outs, arrows, etc.)? Does it come across with the horizontal line added into RH? If not, then you know that it's something to do with multiple objects inside an anchored frame; if so, then it's something to do with the way RH is converting the FM source. We'd need to see you conversion settings then.
Have you taken a look at the HTML for that line on the page? Maybe it's triggered by something in the CSS.
