JumpinJehosephat
Print Book Produces Lo-Res Pages
Sep 20, 2012 2:52 PM
I am having a major headache trying to use the Print Book feature of INDD CS5. I have tried both exporting directly to PDF and printing to PostScript and using Distiller.
Any documents imported into the Book that contain imported PDFs materialize as extremely low-resolution images in the resulting PDF.
If I open the individual INDD files and export or print to PostScript, the result is perfect.
When I do it using Print Book, it is unreadable.
One possible hint: I run Preflight Book, and all the listed documents of the book check out OK, with little green buttons next to them in the panel. But as soon as I click on Print, these green buttons are replaced with dark question marks, as if the Book lost track of the documents' status.
Anybody have any clues about how to proceed?
Exporting the files individually defeats the entire benefit of using the Book feature.
Thanks in advance.
    Sep 20, 2012 3:33 PM   in reply to JumpinJehosephat
    That sure isn't a good sign. When you look at the links panel in the individual docs, are they all OK?
    What happens if you export all of the files to .idml, open and save as new .indd files, and add to a new book?
    And finally, why are you trying to print to PDF instead of exporting the Book?
    Sep 25, 2012 1:19 PM   in reply to JumpinJehosephat
    Something about the Print Book feature is unable to handle these files.
    It really seems more likely that something about your setup is causing ID to think the links need to be updated. Suitcase was doing some strange stuff like this no long ago, but I thought it was limited to .psd images. Any third-party plugins?
