Hello,
We're attempting to connect to an xml feed using some CFHTTP code that has been working for some time. We moved to a new CF10 server and have started running into issue, now persistenly, where we receive a "connection failure" response.
I took a look at several related postings and added a number of cfhttpparam's as follows:
<cfhttpparam type="header" name="Accept-Encoding" value="*" />
<cfhttpparam type="Header" name="TE" value="deflate;q=0">
<cfhttpparam type="header" name="accept-encoding" value="no-compression" />
<cfhttpparam type="header" name="accept-encoding" value="deflate;q=0?">
<cfhttpparam type="header" name="te" value="deflate;q=0?">
No combination of the above has worked. i tried a CFdump and got this result:
| struct | |||
| Charset | [empty string] | ||
| ErrorDetail | I/O Exception: Permission denied: connect | ||
| Filecontent | Connection Failure | ||
| Header | [empty string] | ||
| Mimetype | Unable to determine MIME type of file. | ||
| Responseheader |
| Statuscode | Connection Failure. Status code unavailable. | ||
| Text | YES | ||
Does anyone have some suggestions?
It's an HTTPS URL you're hitting, right?
It is likely a certificate issue.
The certificate chain for that site was probably already loaded into the certificate store for your previous install, then when you installed CF10 you got a new JVM with a new cert store. You' ll probably need to import the cert chain again.
Instructions: http://helpx.adobe.com/coldfusion/kb/import-certificates-certificate-s tores-coldfusion.html
You'll need to figure out where your cacerts file is, and your keytool executable. But after you do that, the instructions should be the same.
Jason
