how to install PS CS2 on Windows 7 64 bit???
Sep 20, 2012 11:41 AM
Please do not advise me to buy or upgrade to CS4, 5, or 6 PLEASE!!!
I've read that there's a definite way to install CS2 (or any 32 bit version of PS) on Windows 7 64 bit successfully with some folder code "C:\progra~2\adobe" or... C:\program~2\adobe...or the same code but with the back slashes in the opposite direction like /.
I'm totally confused: why does the first code say "progra" and leave off the "m" and other say to spell out "program" entirely?
WHICH is correct "progra" or "program" and which way should the slashes go?
I'm very untechnical and don't understand how to do this at all so can someone please explain the install procedure in specific clear steps from inserting the CD to the end?
I saw a member named Marian Driscoll post about this install but don't understand how to do it each step of the way.
I need a new PC and was thinking I would be forced to get a used Windows XP machine to use CS2 but would prefer to get Windows 7 64 bit but won't unless I can install PS CS2 on it successfully.
Can someone please help with detailed install instruction using this floder code?
Thanks so much, I'm desperate!!!
  • Sudarshan Thiagarajan
    Oct 15, 2010
    Sep 20, 2012 12:22 PM   in reply to PSBoston
    The reason for using progra~2 on a 64 bit system while installing a 32 bit app is the 8 character limitation imposed by Windows. progra~2 totals up to 8 characters, program~2 is 9.
    You have 2 options:
    1. When installing, change your path to C:\progra~2\..... and install. It should work.
    2. Copy the installer to your local drive. Right click Setup.exe, Properties > Compatibility tab > Run this in compatibility mode. Choose XP SP2. Click OK. Run Setup.exe
    Either one should work.
    Oct 15, 2010
    Sep 20, 2012 1:21 PM   in reply to PSBoston
    When you install the software, one of the steps you will be asked where to install Photoshop. Instead of just clicking OK there, you should 'Change' that location as I had mentioned earlier.
    Or, have you tried Option 2 that I had posted in my earlier response?
    Oct 15, 2010
    Sep 20, 2012 10:47 PM   in reply to PSBoston
    Good luck, mate.
    Dec 26, 2012 12:28 PM   in reply to PSBoston
    Sudarshan's #2 worked fine for me and Win7 sees CS2 as XP software.   The program installed without a hiccough and works even better than before.
    How is that possible you ask?  Because the Render filter that allowed changes in lighting would not display any brushes in its prior incarnation, even after a CD repair.  Now the brushes are visible.
