dual resolution images
Sep 20, 2012 8:30 AM
watched the R23 update yesterday, understand that we create 2 images one at std res and another named exactly the same but in a different folder, Can someone let me know the naming convention and folder structure for the 2 differents image folders etc.
Hope thats clear!
cheers
Alistair
  • Bob Bringhurst
    May 29, 2007
    Sep 20, 2012 9:00 AM   in reply to mobly
  • Bob Bringhurst
    May 29, 2007
    Sep 20, 2012 12:22 PM   in reply to mobly
    When you create a 1024x768 v23 folio, the standard (non-interactive) images in PDF articles are output as 108 ppi instead of 72, which should result in improved clarity without affecting performance. Have you tried creating a folio with multi-rendition PDF articles? Let us know what you find.
    Sep 20, 2012 12:26 PM   in reply to mobly
    I haven't tested this yet but I would think that if you have an image that is absolutely essential to the presentation and want it to be HD on the iPad 3 you could create an image sequence out of it using two identical images for the SD devices and then add the HD assets. It would appear static but you'd get the benefit of HD.
    If you decide to try it let me know how it works.
    Bob
    Sep 20, 2012 1:05 PM   in reply to Bob Levine
    that is an awesome (but awkward) workaround, Bob L!
    —Johannes
    (mobil gesendet)
    Sep 20, 2012 1:39 PM   in reply to Johannes Eckert
    Let’s face it, Johannes…this whole damn thing is a workaround.
    Sure keeps the mind sharp though, no?
    Bob
  • Bob Bringhurst
    May 29, 2007
    Sep 21, 2012 9:41 AM   in reply to mobly
    At that time, there was only the iPad 1, so creating anything larger than a 1024x768 background image with 72 ppi was overkill. Now, with HD devices and PDF pinch/zoom, using a higher resolution for background images is warranted.
Bookmarked By (1)
