The Big InDesign CS5 "Features Off" Petition
Dec 10, 2010 3:12 AM
I'm very annoyed by a lot of so called handy new featues in InDesign CS5. Luckily some of these features can be turned off but still there needs to be turned off more in my opinion. I'm wondering how many of fellow InDesign users are not pleased with these new features as well.
Reply with an addition to the list, explain why it's annoying to you or just reply to add your name to the petition.
Features I would like to be able to turn off:
  • Edge Highlighting [it's just so annoying]
  • Bounding Box [not being able to resize individual items of a group of items drives me crazy, for example by double clicking a handle or dragging a handle of an item in the group]
  • Selection issues [not being able to select a text box on top of a selected box]
  • Corner Handle Rotation [try grabbing a corner of another box close to the one which is selected]
    Dec 10, 2010 3:48 AM   in reply to Studio57NL
    Make sure to make feature request
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    The more options the better.
    Dec 10, 2010 4:52 AM   in reply to Studio57NL
    The behavior of the selection tool has completely changed in CS5 (for the better, in my personal opinion). Double-clickiing withthe selection tool on a grouped object now toggles between the group and the individual object.
    Have you taken the time to read about new features so you can learn how they work? It's OK to be annoyed or want the old way back if you've tried to understand the new ways, but I see a lot of complaints that seem to me to be based on ignorance of what has changed, and how, and what you can do now instead (the new selection procedure saves me hours over the course of a week, I'm sure).
    Dec 13, 2010 4:55 AM   in reply to Studio57NL
    Have you tried the zoom feature when working with all of those small boxes? InDesign can zoom to 4000% making it pretty easy to work with very small objects.
    Bob
    Dec 13, 2010 5:26 AM   in reply to Studio57NL
    I wasn't calling you ignorant. I was asking a question about wheter you HAD read the information about new features. Since you have done so (and there was no way to know that without you actually telling us), you would fall into the category of users with possibly legitimate gripes. Most old techniques still work as they used to, even if there is also a new way -- the obvious exception being the behavior of overlapping or multiple selected objects.
    I don't use a Wacom pen, and that's something else we had no knowlege of, nor you operating system, (though both are probably irrelevant for this discussion). I'm not sure what you mean by "the transformation bounding box doesn't work at all so I want to turn it off." The only thing different that I can think of is that you can now rotate without having to change tools or move to a panel (and you can see the rotation amount in the content grabber if it's turned on). You can continue, as I'm sure you are, to use the rotate tool as you always have instead if you'd rather. In fact, if you want to ratoate around any point other than the center you would need to, though I think it's probably faster to rotate and reposition thant to switch tools and choose a new center of rotation. Of course, you are used to the rotation tool, use the shorcuts for the toolbox (something I've never managed to get comfortable doing in ID) so that may not be true for you. Nonetheless, the abilty to ratote without changing tools shouldn't be interfering with your ability to do it your way. I've not had any difficulty with using a mouse to access corner handles without rotating, so perhaps this is a pen driver issue, or simply a matter of where you position the cursor.
    And you can continue to group items and Cmd + Shift drag to resize -- that's the way I used to work, too, but now you don't have to group first to have all the selected objects scale together, which means you can work with objects on different layers more easily (groups must be on the same layer). Perhaps you are unhappy that you can no longer select multiple objects and scale only one while they all remain selected. This change was definitely made at user request and on balance I think it makes sense. Most times I have multple objects selected I don't want to transform only one of them. You may feel otherwise.
    As far as "persistent selection" of an item behind another, this takes a while to get used to and to understand the rules that govern how it works. If you are not able to reslect the front object, it means that the selected object is not completely surrounding the one in front that you want to select and you need to click instead on an area that is not overlapping. If the object is completely surrounded it should be selected as soon as you click inside it. Does this cause me to stumple on occasion and lose a beat? You bet. But on balance I lose a lot less time to that than I used to waste having to change the zoom, then Ctrl (I'm on Windows) Click back down through a stack to reselect the object I wanted to move, then grab it's center point so I could move it.
    And you don't want to know what I charge my clients. It's probably a lot less than you which is why I don't have money for a new printer. My rates haven't changed with the new version (increased productivity is a good argument for raising rates, right?), the clients just get more for the money now.
    Dec 13, 2010 1:55 PM   in reply to Studio57NL
    One feature I'd love to be able to turn off is background tasks. I have to say that at least 1/3 of the time my PDF export will stick @ either 4% or 9% if I do anything during the export process other than wait. (And that includes switching to another app, without doing anything else in InDesign.) When that happens the only solution is to force-quit INDD and relaunch, then re-export and sit patiently while it finishes.
    Dec 13, 2010 2:16 PM   in reply to bpylant
    That problem has been discussed extensively. Please search the forum.
    Bob
    Dec 14, 2010 11:52 AM   in reply to Bob Levine
    I personally would rather be able to just turn this off until they get it working right.
    Dec 16, 2010 5:05 AM   in reply to Studio57NL
    OK, I'll grant that's a big change, and you certainly have a right to be annoyed if it affects your workflow, but in all seriousness, how badly is it affecting you? How often do you select multiple objects with the intent to modify only one? That's a serious question. Do you select everything and move it a little, make an adjustment to one object, then move again?
    I think I mentioned that you can now do things to multiple selections without grouping that used to require it, which I thought was an improvement, and this is sort of the corollary to that change. If you group all those objects, then you can double click one to edit it alone, then double click it again to reselect the group. I don't know if this was a necessary change in order to get other parts of the new selection behavior to work.
    I think the bottom line here is that suggested changes are weighed and decisions on implementation are made. Any change is going to make some users unhappy (for example I think they really screwed up the interface going from vertical tabs to horizontal and icons for docked panel groups), but that's life. If a feature could be turned on or off easily without affecting program operation -- like frame edge highlighing -- then there is a good case for making it a preference item or menu choice, keeping in mind that adding everything as a choice can get out of hand, too, but I suspect this just isn't one of those tings taht can be turned on or off. Ever buy a new car and have to learn a new set of controls for running the heater or windshield wipers? Same thing. Annoying, hopefully not fatal, and eventually we adjust.
    Dec 16, 2010 5:58 AM   in reply to Studio57NL
    My only complaint about the rotation feature is its lack of control. It always rotates from the center no matter what the proxy is set at.
    Bob
    Dec 16, 2010 6:22 AM   in reply to Studio57NL
    Studio57NL wrote:
    Next up: why the Corner Rotation sucks. I think this needs to be a user
    preference too.
    I'll bite. Why does the corner rotation suck?
    Would you mind turning off the autoquote when you respond by email?
    Dec 16, 2010 7:52 AM   in reply to Studio57NL
    Studio57NL wrote:
    Adobe has really reunid working with ID for me.
    Well, there are other options....
    But in my opinion, you're doing things in the wrong order. Your step 3 should either be happening before step 1 or after step 4.
    Dec 16, 2010 8:19 AM   in reply to Studio57NL
    You missed the point. Either resize the frame before copying, or do it after you've moved the whole copied block into position and you won't have to reselect anything.
    Dec 16, 2010 9:15 AM   in reply to Studio57NL
    Well for the moment all I can offer is group the copied frames, double click the one you need to resize, resize it, double click again, move into position and ungroup (if you feel the need). Or go back to CS4. This behavior is not going to change in CS5, and I sincerly doubt it's going to change in a future release, either. Other than you, I haven't seen a single complaint about it, and it will take a LOT of voices to get something like this altered.
    Dec 17, 2010 8:37 AM   in reply to Studio57NL
    You might find this topic ofer at InDesign Secrets of interest: http://indesignsecrets.com/indesign-cs5s-new-bounding-box.php
    Feb 27, 2012 8:59 AM   in reply to Studio57NL
    By "the transformation bounding box doesn't work at all so I want to turn it off" I mean the transformation bounding box which appears when I select multiple items which doesn't work for me
    Studio57NL: You are right, this is something that must be optional. My problem with this, when I choose several objects, and they get an additional frame that surrounds them all, it is so distracting, I often can not see any more if I did choose all the objects I wanted. Only when I move them, I note if one or the other is missing in the selection.
    Sep 21, 2012 7:42 AM   in reply to Studio57NL
    I agree wholeheartedly. These features actually get in the way of my productivity because selecting an item is actually trickier now. I have to pay more attention to make sure I don't grab the "bull's eye" by accident (which happens constantly, the bull's eye drives me bananas). I have to pay attention and make sure that when I have multiple items selected and I want to change one of them, I have to deselect all the others because they act like a "group" even though I haven't grouped them. I have to pay attention to make sure that if I want to select two items together, I have to make sure I first select the one on top because if I select the one below it, then the top one is unselectable. When I grab a corner I have to be careful that I don't grab the rotation item instead. It's a lot more to pay attention to and it slows me down.
    If people want these features they should be able to turn them on.
    And on top of that it's strangely exhausting that my layout keeps highlighting things as I mouse around. All that visual activity makes me think something is happening, like maybe I accidentally moved something or deleted something I shouldn't have. I keep telling my layout to "hold still!" haha!
    I will sign your petition
    Sep 21, 2012 8:01 AM   in reply to B_Louck
    You do know that there won't be any changes to the UI for CS5, right?
    You could always turn off the content grabber (bullseye), and frame edge highlighting became a preference in CS5.5, I think. I suspect the multiple selection changes are related to behaviors having to do with alternate layouts and CS6, and got introuced a bit early as they wrote the new code, but I don't know for sure.
    Sep 21, 2012 8:27 AM   in reply to Peter Spier
    I know it's the past. CS6 is the present. My company recently upgraded to
    CS5 and I was looking around for solutions- and it felt nice to find others
    who felt like me! Curious to know if CS6 has addressed any of these
    concerns, but odds are my company won't be upgrading again for another few
    years, so sort of moot point for me.
    Sep 21, 2012 8:28 AM   in reply to B_Louck
    You're wasting your time. This has already been addressed by Adobe so the voices that were raised when CS5 was released were heard. You'll need to upgrade to take advantage of those changes though.
    Bob
    Sep 21, 2012 11:18 AM   in reply to Bob Levine
    That's good to know. My company just updated to CS5 so it's new to me. I'll
    be very excited in 2 years when we upgrade to CS6, haha!
