Preserving presets with a new install
Sep 21, 2012 8:01 AM
Tags: #cs6
I will be having an entirely new computer built. I am upgrading from Windows XP to Windows 7.  When I upgraded from CS5 to CS6 on my present computer, I said yes to preserving the old presets. But how will this work on a new computer? And, in fact, all of my versions of Photoshop going back I can't recall how far have been upgrades. How is this handled with a new computer? I have the CS3, CS5 and CS6 installation disks. I am not sure about the older versions.  So, two questions here: 1. How is the CS6 installation handled if all I've had for the past who-knows-how-long is upgrades. I started with one of the very first Photoshops. And 2. how do I preserve the presets it took me a year to work out on CS5, along with my gazillion actions and who knows what else?
    Sep 21, 2012 8:16 AM   in reply to ycardozo
    Simply save the presets using the flyout menus in the respective palettes for brushes, styles etc. to external files. When installing, you simply install CS6 - it will ask for the CS5 serial number for verification.
    Mylenium
    Sep 21, 2012 8:30 AM   in reply to ycardozo
    and as for the installation, cs5 was also an upgrade. i don't think i have the original version, whatever it was, of photoshop anymore.
    Doesn't matter. All the installer needs is one serial of a previous qualifying product, not all of them and that is the last version you bought, i.e your CS5 upgrade. And hang in there. The load/ save stuff in the flyout menus is way to go...
    Mylenium
    Sep 21, 2012 11:37 AM   in reply to ycardozo
    my special filters and a few other things that took me ages to figure out.
    If these are 3rd party Filters, and are the correct 32-bit, or 64-bit for you installation, many will probably need to be installed again. Some (do not see THAT many anymore), that are correct for your version, might just require the Copying of the .8bi files, to the appropriate folders. Exactly what needs to be done, will depend on the Filters. Can you give us a list of the ones, that you are concerned with, and mark all, that are 3rd party plug-ins. Someone will likely recognize many of them, and can give you specific instructions.
    Good luck,
    Hunt
    Sep 21, 2012 1:02 PM   in reply to ycardozo
    Digimarc was a trial Filter, that could be activated via a subscription, and that was shipped with, and installed with PS. I do not recall the details, but think (from a fairly recent thread on this forum), that it might not be available in PS CS 6. Maybe Search this forum for digimarc, and look for CS 6 threads.
    Some functions have been moved in CS 6, and I think that Contact Sheet is now part of Bridge. Check that out, and there was a fairly recent thread on Contact Sheet also.
    As for the Preferences, as those can become corrupted, I would not try to transfer it, but would instead manually set up my Preferences (Edit>Preferences) for the new install.
    As for the .8bi Filter files, their exact location will depend on several factors, such as your OS version, your PS version, and the Path chosen, when you installed PS. You can use Windows Search, and plug in *.8bi, to see where yours are located.
    Good luck,
    Hunt
    Message was edited by: Bill Hunt - Corrected spelling of Digimarc from "Digimark."
    Sep 21, 2012 1:03 PM   in reply to ycardozo
    That is wonderful. Right now, when in Bridge if I click tools/photoshop I then see contact sheet II. Is what what you are referring to?
    Yep, that is the one.
    I would take a look at a Search for Digimarc, just so that when you do get around to it, you do not waste too much time looking for it.
    Good luck,
    Hunt
