Hey everyone. I use InDesign to create my resume for job apps and whatnot. I've found that many corporate sites only accept file sizes under a certain limit (usually 500kb or smaller). My resume is usually around 590-610kb. Is there any way that I can reduce the file size without losing significant quality, or even any?
Cheers.
Depends on waht's in the PDF and the current quality of the images.
Acrobat's PDF Optimizer can remove a lot of stuff that won't be needed, and downsmaple images or flatten transparency, and there's an Audit Usage button you can use first to see what are the major contributors to file size.
@rayza – you could go the other route creating PDFs: print to PostScript and use Acrobat Distiller for writing a PDF.
This usual yields in smaller file sizes compared to the export method with a similar PDF preset: about 10 to 20%.
If you have a CMYK workflow with CMYK images, converting to sRGB (not including any color profiles) should cut another portion of your file size without diminishing overall quality.
Uwe
rayzha wrote:
So I need to d/l adobe acrobat?
OK, so this sounds like you don't have a Creative Suite package, or perhaps you are using Creative Cloud and didn't install Acrobat Pro.
The free Adobe Reader will not help you to optimize a PDF, you need the full, paid, Acrobat application. Uwe's suggestion to distill might get you a smaller PDF, but again, without Acrobat you won't have Distiller. There are a few freeware Distiller clones that would probably work for plain text, but I doubt there's much that can be done to bring the size down on a file that has nothing but text in it without removing the non-graphic disposables like metadata, and the embedded page thumbnails, which requires the optimizer.
It occurs to me that one reason your exported PDF might be large is that ID always embeds fonts unless they are restricted. If you are using common system fonts that you know your viewer will have, you can distill PDF without embedding fonts and save a couple of bytes. I just pulled up a random page from a student paper, which has about seven fonts in use. The usage audit says they total a bit over 2mb.
I did use Smallest Size preset but it still is around 660 kb. I installed acrobat (I have the full suite, just never installed it) and the audit feature said that Content streams were 75%, Fonts were 10%, and document overhead was 13%. These were the biggest three. Is there anyway to reduce the size? Under 500kb would be the best. I used a custom font for my text. Would this be why? Is there any way around it?
I've never figured out what content streams means, but I don't think you're going to be able to reduce that, nor do you want to unembed a custom font.
Make a copy of the PDF, then run through the various Optimizer screens and see what other sorts of things you can delete or compress. Pay particular attention to the three categories Discard Object Data, Discard User Data and Clean up (Flate seems to have a significant impact, in my experience).
In addition to good Uwe's and Peter's advices:
after you ran your pdf through Optimizer (with optimal settings for you) and saved it, export from ID again - just one page of your work, with same settings. Run it through Optimizer identically. Save it. Open your first pdf and replace corresponding page with newly exported one. Do plain save (don't optimize!).
Strangely, the resulting file very often shows smaller size than original, just optimized. I noticed that doing small last-second corrections in already generated multipage pdf's for client.
not a big space saver, but if you're on the edge with your file size, it might help you sometimes.
Content streams are (apparently and largely) vector data from what I have read in the past.
Culprits from eons ago use to be placed EPS files whether the EPS file(s) were from AI or PS. Deleting meta data via the Optimizer, changing smooth lines to curves, etc., will lower the file size.
I would really be interested in seeing this file. I cannot imagine a resume would be so large...unless there is a lot of vector data in it.
Take care, Mike
Take care, Mike
I would have to agree. Perhaps the OP doesn't consider native ID shapes and color bars to be graphical. Fills in a text frame might add some heavy overhead, too.
If you would like to message me your email, I can show you the PDF file. The only fancy things I used are:
- A custom font I used for my text downloaded from dafont.com
- One line separating my header from the rest of my resume content
- Titles which have a .5 outline to bold the text because the custom font did not have a bold version
I don't have any other shapes or colors. It's a black and white colored resume. Perhaps I used a custom color? I don't really know. but I definitely can show you and maybe you can play with it to make it smaller?
