To my dismay, I discovered that Media Encoder no longer exports mp4 files. Each time I try it now, it exports a file with the extension m4v instead of mp4, and it will not play. This is CS6 on a MacBook Pro running mountain lion. It was working previously before the latest update from Adobe. Anyone else experiencing this?
When I try and play back the m4v file, I am seeing this error.
thx
I am using a custom preset I tweak which is based off of one of the ipad 2 export presets for h:264. The multiplexer is set to mp4, not none. This preset previously worked fine. Now, the output files have a m4v extension instead of mp4, and do not play back. Looks like a nasty bug.
This also happens when exporting directly from Premiere Pro. Is there a work around?
I had this exact same problem, but when exporting using the Vimeo h264 tweaked preset. The tweak I made was not to export the audio. It then kept making .m4v files, not the .mp4 files and I couldn't play them. I too had no problems with CS5.5
I got around it by simply not unchecking the export audio. It then produced the correct mp4 file and I could play it.
Yes Keith, Mac OS X 10.8, and no, the m4v output did not play back at all (I tried Quicktime 7 & 8 and VLC), and the 'file' command line utility did not recognize the contents. A superficial hexdump check shows that the file does not have the typical header for 'proper' M4V video files (signature 00 00 00 14 66 74 79 70), so it really seems to be the bare video stream.
Ok, I have logged this as a bug. To me, it is a regression in functionality from 6.0.1 to 6.0.2. Hopefully it will get fixed; I can't fanthom that this would be acceptable by Adobe to leave as is, even if there is a workaround. However the workaround still gives a bigger file than what one without the audio track.
I'm sure glad I found this forum posting, because I have just wasted 3 days attempting to use AME to create MP4s for a customer! I have exactly the same problem reported here by others. I was not exporting audio. The workaround of exporting audio, even though there is no such track, seems to work, but I'm uncomfortable delivering this as a finished product to this customer.
I will have to try keeping the Export Audio box checked. I am having the same .m4v problem when trying to save as mp4, and my videos have no audio (screen capture tutorials) so I chose not to export the audio. I will see if keeping the box checked works.
I am using Windows 7 64-bit, CS6 Master Collection Student Teacher; I just downloaded the full version (paid for) a couple of days ago, so apparently, this is still a bug.
I had posted this same type of question earlier today, now I found this forum. I don't know if the problem was there before the update because I just bought my Adobe products the other day (November 10, 2012) and installed the updates prior to even opening any single one of the Adobe programs. Oddly enough, Handbrake does a fine job, so I am using that until I figure out the problem with AME.
UPDATE:
YES! Keeping that Export Audio box checked resolved the problem. What I did was (since there was no audio in the original) just take the audio settings down to the lowest possible quality so as to save on file size output.
Thanks for the pointer!
I seem to have the same problem after leaving the audio on but I check Best Render/Maximum render quality.
I have to also out put a 1440x1080 version for a certain mobile app interface and keep trying to find a built in preset but I always get the 16:9 format. Can't seem to find out how to output to 1440:1080 without stretching the image. and also rendering properly as an mp4 file
Just experienced this issue for first time today---just got cs6--when I exported a prppro sequence without audio to h.264 legacy format then it gave me a good .mp4 file that was playable-but the regular h.264 gave me an unplayable (in vlc, playable in windows media player) .m4v file
quick question
what's the difference between the h.264 and the legacy h.264--I guess the mainconcept codec is not used for the new h.264?--Is that it--is there some reason we should not use the legacy format anymore?--i just assume it's more compatible than the "new" h.264 in ame and the legacy still works well for me-so I'd like to continue using it until adobe works out the kinks on the newer version--any thoughts?
Tony
I do not want to be pathetic, but use x264. You will get better quality and smaller file. I do not encode to H.264 from adobe products anymore. I've asked them to implement x264 in Media Encoder by feature request, but it seems they do not feel the same as I do about the issue. May be it is hard to take that open source product is better than commercial ones.
