I am encountering Compiling Errors (error unknown) evertime I try to export media. I have footage from a Cannon XF100 (.xmf H.624) and I am using the correct settings (29.7 1920x1080, etc). I have read that others are experiencing these compiling errors. What can I do, or what is being done, to fix this issue? I have an earlier version of Premiere at work and I never run into these issues. However, my daughter and I are trying to create videos at home and this errors occurs 90% of everytime we try and export.
I have a brand new computer with more than adequate video, RAM, etc . . . it was sepcifically designed for video editing. Windows 7, etc. . . . brand new and powerful. Similar (if not better) than what I have at work and that machine has no problems, but it is also running a prior version of Premier.
I set each file up as suggested with . . . For editing Canon XF MPEG2 50 Mb/s formats - 16:9 progressive-scan - 1080p HD video at 29.97 frames per second. 48kHz audio. Drop-Frame Timecode numbering.
I export using the setting H.264 - HD 1080p 29.97.
Any suggestions? Help is greatly appreciated.
I recently was unable to export, turned out is was a black video and an effect.
Look at the time/clip in AME when it crashes.
Then go to Premiere and see if you can spot something unusually at that time or clip.
Or read this link: http://kb2.adobe.com/cps/906/cpsid_90670.html
Along with Ann's comments, and the link to the Adobe KB Article, on Error Compiling Movie, some other things to check for:
Good luck,
Hunt
I went through a compiling errors period recently as well. everything was working beautifully until i installed a quadro 4000 for mac video card and upgraded to 10.8 and 6.0.2. the problem was, my nvidia driver wasn't mountain lion friendly. i updated the driver and things got back to normal. i see you're not on a mac, and you may not have an nvidia card, but if i were you, i'd check my drivers to see if they're up to date. good luck, man, i've still got ptsd from getting so many compiling movie errors ![]()
I am having the same issues... I have a Canon XF100 and have just upgraded to a brand new imac (as powerful as you can get) and CS6 and am getting CONSTANT issues, unable to render, unable to export. Always saying "Error Compiling Movie - Unknown Error". I NEVER had these problems with CS5.5 on my MacBook Pro. Sometimes its fixed by removing a fade to black or sometimes I have to reboot. I have even started a new project and copied the footage across to a new project and exported and its worked fine... but each time there is a new issue and going through the troubleshooting is very time consuming. I am enjoying the new features of CS6 but I am not sure it's worth these headaches.
Grandchamp2012 wrote:
I am encountering Compiling Errors (error unknown) evertime I try to export media. I have footage from a Cannon XF100 (.xmf H.624) and........
What is .xmf H.624 ? I am using XF100 footage successfully since the 6.02 update.
Win7 64pro
Core i7-2600
16gb ram
GTX560 2gb
We have really put the machine through paces over the last month and it has been a champ.... finally.
Try posting your system specs. And do you have any .MXFs with visual or audio glitches?
