Widget accordion states are not changing.
Sep 7, 2012 11:19 AM
Widget accordion states can not be altered individually. HELP!
    Sep 13, 2012 12:38 PM   in reply to HotPinkInk
    What are changes that you are making in different states ?
    - Abhishek Maurya
    Sep 22, 2012 5:26 PM   in reply to Abhishek Maurya
    I am having this problem too. I selected the top container of the accordion widget - a header tab. I selected the placeholder text and typed in my own. Then I selected that text that I just typed in and tried to apply one my paragraph styles from the paragraph styles menu. But it did not apply. When I select that text it corresponds to the correct style. However, it is definitely not the style at all. It is not blue - it's gray. Furthermore, I tried to select the next line of text to apply a different paragraph style and the same thing happened. It says it's that style, but it's clearly not. When I go to the preview tab - it shows exactly as it appears in the design tab. Please help.
    Sep 25, 2012 11:22 AM   in reply to scvdesigns
    Hello,
    I just tried it at my end and it seems to work fine. Please have a look  at the video in the link below :
    http://trainingwebcom.worldsecuresystems.com/SachinFTP/2012-09-25_2349 .swf
    Could you please try and create a new Accordian panel in a new test website and let me know if you are facing the same issue or not.
    Sachin
    Sep 25, 2012 12:50 PM   in reply to Sachin Hasija
    I found my solution after posting my problem. I was in the tutorials and found the font colors were not changing in the accordion widget header tabs when I assigned a new color - only to find out that they really did change - but ONLY when the state changed. So the problem was in my understanding. All is good! Thanks Sachin for trying to help.
Bookmarked By (1)
