TommyD3
Project Files constantly becoming Corrupt - CS6
Sep 22, 2012 6:10 PM
Tags: #pro #premiere #cs6 #corrupt #project
I need all the help I can get. Ever since I've started editing on Premiere Pro CS6 (switch from FCP7) I've constantly run into the same problem. For every single project I have worked on, at least twice the project file will spontaneously become corrupt. There are no warning signs, it just happens at random when I open the project. I end up opening one of the auot saves but will usually lose time, and I should not have to rely on these backups as an everyday thing.
I've tried everything I can think of, I've gone so far as to load new harddrives in to my system. I've done fresh install of my OS (10.8.2) and fresh installs of the Creative Cloud. We use CS 5.5 at work with no problems and I've used PPro on and off since the very first Creative Suite and have never encountered an error such as this.
I've had absolutely no problems with After Effects, Photoshop, or Illustartor. Only PremierePro
Thanks.
Here are my hardware specs:
MacbookPro (10.8.2)
2.4GHz Intel Core 2 Duo
GeForce 320M 256MB
6GB RAM
120GB SSD (Holds only OS & Software)
720GB HDD (scratch disk)
Codecs: both H.264 and ProRes at 1080/24p
    Sep 22, 2012 11:10 PM   in reply to TommyD3
    You might check your computer's RAM. I had a similar problem, and it was due to a bad stick. I don't know Mac, but I'm sure there are free utilities you can run for a few hours to test the memory.
    Mar 1, 2013 7:45 AM   in reply to TommyD3
    The fix Adobe gave me was as follows (these are for a Mac but I'm sure archeticure would be similar on a PC)
    Go > Go to Folder > ~/Library/Preferences/Adobe
    Now you will see a collective of folders for whichever adobe suite you have. Go to Premiere Pro and the next folder you should have should be labeled "6.0" change that to "60_old" or some random different label. Try opening up your original project (not the recovery proj) and see if that helps.
    Mar 6, 2013 11:00 PM   in reply to tsdavis369
    My folder was in Documents/Adobe/Premiere/6.0
    But the tip didn't work for me =/
    Mar 7, 2013 9:49 AM   in reply to shuenwang
    That's a different file structure. Are you on Mac or PC?
    Mar 7, 2013 10:13 AM   in reply to tsdavis369
    I'm on Mac (OSX Mountain Lion). Is something wrong with my setup?
    Mar 7, 2013 12:24 PM   in reply to shuenwang
    What kind of media are you using?
    Mar 7, 2013 3:58 PM   in reply to shuenwang
    No you're setup is probably correct there is just a difference between the Adobe folder in your documents and the adobe folder in your preferences. Finder > Go > Go to folder > ~Library/Preferences/Adobe and see if that helps.
    Mar 7, 2013 7:25 PM   in reply to Kevin Monahan
    Hi, I'm using red giant magic bullet plugins & Canon 600d .mov files straight out of the camera
    Mar 7, 2013 7:50 PM   in reply to tsdavis369
    Ah, yes, found it. You are correct. I tried it but no luck yet.
    Mar 7, 2013 9:44 PM   in reply to shuenwang
    Are you using any other Red Giant plug-ins? Colorista, Lut Buddy, etc? I've found most of them crash my system. InstantHD, denoiser II, Looks and Grinder are the only ones I can have installed with out crashing premiere for some unknown reason.
    Mar 8, 2013 8:08 AM   in reply to tsdavis369
    Interesting....I have colorista, mojo, and looks. I've seen other threads about some problem beteween red giant plugins and adobe premiere. After they crash your system, do your files get corrupted?
    Mar 8, 2013 9:23 AM   in reply to shuenwang
    Mine did. It was giving me a "serious error" and then crash the project. Soon as I uninstalled colorista it would open the same projects again.
    Mar 9, 2013 12:12 PM   in reply to tsdavis369
    I feel like mine had some similar issues going on. I won't even bother installing colorista for the time being just to be safe. Anyways thanks for your help, maybe one day this will be solved for good.
    Mar 9, 2013 4:43 PM   in reply to shuenwang
    Good luck to you. I hope you have an easier time then me. I've resorted to cutting in FCPx until I can go 2 projects without a corruption
