InDesign CS5 crashing when exporting to PDF - large image?
Sep 24, 2012 7:36 AM
Tags: #pdf #export #crash #indesign
Hi can anyone help?
I'm working with some rather large files in InDesign - it's a layout for a vinyl banner. It contains one image, created at 1/2 size @ 600dpi - 1500 mm x 850 mm. The file size generating is 1.25GB. I can't save in any format other than tif, psb, raw. I've gone with tif.
So, I've placed the image above into my document and need to send to the printers to do a resolution test. Unfortunately, when exporting to a high quality PDF, it hangs and InDesign crashes.
I know the image is probably the cause of the issue, but really not sure what I can do about that?
Crash report is here - http://pastebin.com/EBNxE8fS
If anyone can offer any advice on a) how I can save the image as a print acceptable format that DOESN'T create a humongous file size OR b) whether there are any settings i can cgane in InDesign to handle this better?
    Sep 24, 2012 8:40 AM   in reply to vikkineal1980
    You could try saving it as a TIFF - and you can use zip compression on the TIFF - that should shrink the size of the image down.
    When you export the PDF make sure in the compression area of the PDF dialog box that you select ZIP there too.
    To be honest - the smallest file size you'll get is probably a JPG - if you're not too fussy then that's what I'd use.
    300ppi for a banner photo is pretty high - you only really need that much resolution for magazine - when you're reading it at arms length.
    You  could probably drop the resolution to 220 or even 150. The last pull up stand I did the image resolution was 30ppi and it looked fine from the distance it was viewed at.
    Sep 24, 2012 8:57 AM   in reply to vikkineal1980
    Yeh 300 ppi is a rule of thumb thing - it's not an exact number for all printing purposes.
    I wouldn't be too bothered with 250ppi it will look fine I'd imagine.
    Sep 24, 2012 9:08 AM   in reply to Eugene Tyson
    Your output service may have reasons for wanting to output with 300 ppi effective at print size, but I've never has a problem with banners output at 150 ppi at full size.
